Old 23rd July 2014, 23:37   #31
::CMS::'s Avatar
Thanked: 470 Times
Default Re: Dzire security system fails, unlocks all doors!
The verdict given by nippon was manufacturing defect. There was problem in the wiring and the module both.
I think you havent got the issue yet. The question is if there is any issue with the wire / module or whatever it is, does it interfere the locking system of the car by unlocking it? If its unlocking by itself then its a serious security threat.
Originally Posted by rockporiom View Post
he cleared all the confusion.
No, not yet. Do you think the module / wires are fool proof for ever?
::CMS:: is offline   Reply With Quote
Old 23rd July 2014, 23:40   #32
rockporiom's Avatar
Thanked: 761 Times
The ASC didn't have an answer to that question as to why it unlocked all doors. The cause of the problem was manufacturing defect and wiring problem. It is a security hazard that it opens all the doors and deactivates the alarms. You only have the immobilizer to save you. But the radio and things kept inside are at risk
rockporiom is offline   Reply With Quote
Old 23rd July 2014, 23:44   #33
::CMS::'s Avatar
Thanked: 470 Times
No, immobilizer is also not going to save, if "they" have a spare ECU, its only a 5-10 minute job for an expert.
Old 23rd July 2014, 23:48   #34
rockporiom's Avatar
Thanked: 761 Times
So in short people that have this issue and don't have proper parking area or security are doomed. I think I should write a mail regarding this issue and would add this link to it. What says?
Old 23rd July 2014, 23:57   #35
::CMS::'s Avatar
Thanked: 470 Times
What says?
You can try and also be prepared to get surprise replies in return, if any..
Old 24th July 2014, 10:07   #36
audioholic's Avatar
Thanked: 6,149 Times
Dont diesel engines have injector pairings which will be required every time a new ECU or injector is added? I dont think the car will crank up as soon as the ECU is swapped.
Moreover, Rockporium, stop worrying too much since in this way, any car can be stolen irrespective or a maruti or a hyundai or anything. They should have a spare ECU, which will crank up the engine, along with a key with similar pattern that can turn the car ON. Even if they hotwire the ignition and fuel pump, the electrical systems should be turned on by the key. Hence ECU + Similar Key is not worth for a small car and perhaps such high end thieves would gain better by stealing high end cars
audioholic is online now   (2) Thanks Reply With Quote
Old 24th July 2014, 14:30   #37
rockporiom's Avatar
Thanked: 761 Times
So moral of the story maruti saves you by not being high end the greatest security feature
Old 24th July 2014, 14:39   #38
Thanked: 14,610 Times
No one can come, change the ECU and steal a car. The immobilizer, key transmitter are all coded with a common one to the immobilizer so relax.
Do write a mail but expect to reach Nanda and also the Nippon service engineer who has done the job.
Spot on buddy.
Anurag.
a4anurag is online now   (2) Thanks Reply With Quote
Old 24th July 2014, 16:33   #39
::CMS::'s Avatar
Thanked: 470 Times
Check other online forums, eg some Bimmer forums, people are able to do that.
::CMS:: is offline   (1) Thanks Reply With Quote
Compatibility of Viper 3-Channel Security System with Keyless Entry anachronix Modifications & Accessories 6 31st January 2008 11:01
Car alarm when all doors closed gururaj Modifications & Accessories 15 2nd December 2007 13:03
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
Car Security System Irwin Technical Stuff 7 15th September 2005 18:59
a shocking security system? cooldude585 Modifications & Accessories 16 24th April 2005 00:33
