Old 23rd July 2006, 20:39   #1
Thanked: 53 Times
Default what turbo for esteem?
I m trying to modify 1.3L esteem engine (carb) with a turbo, which turbo can be used for this engine with an intercooler?
dinar is offline   Reply With Quote
Old 23rd July 2006, 22:37   #2
viper's Avatar
Thanked: 9 Times
You can fit a Garrett T20/25 or equivalent size of another brand.
Viper
viper is offline   Reply With Quote
Old 24th July 2006, 11:34   #3
Psycho's Avatar
Thanked: 95 Times
Originally Posted by viper
Viper
Will be good enough till about 12 PSI... however I do hope that you have access to a couple of good people to do the install as CARB turbo installs can quickly turn to nightmares.
Old 24th July 2006, 16:01   #4
Thanked: 53 Times
what sort of problems can i face? can the same turbo be used with MPFI engine from the esteem?
Old 24th July 2006, 20:12   #5
viper's Avatar
Thanked: 9 Times
You need to get your AFR mixtures right or you will end up frying your pistons.Yes you can.
Viper
Old 26th July 2006, 22:45   #6
Thanked: 53 Times
what size is indica turbo can that be used with esteem engine?
Old 16th August 2007, 16:03   #7
Thanked: 54 Times
Hi Psycho/ viper,
Where do we get these turbos in India? what the approx price?
Would you be able to install it on a MPFI Esteem?
What would be the overall expenditure?
Does anyone have a used esteem turbo for sale?
Even looking for a second hand automech exhaust for esteem.
jagadeesh.b is offline   Reply With Quote
Old 16th August 2007, 16:15   #8
adman77's Avatar
You can get these turbos in Mumbai at K.S Motorsport and at Bangalore from Psycho (Keshav). For a used esteem Turbo, ask Psycho (I doubt he'll ever part with his, if he does, please lemme also know).
adman77 is offline   Reply With Quote
Old 16th August 2007, 20:36   #9
Ford Rocam's Avatar
Thanked: 16 Times
I recommend you go through this thread first. read it from beginning.
http://www.team-bhp.com/forum/modify...-your-car.html (ARTICLE: Points to consider before TURBO-Charging your car) (ARTICLE: Points to consider before TURBO-Charging your car)
Ford Rocam is offline   Reply With Quote
Old 16th August 2007, 20:38   #10
cheap_deal's Avatar
thread over a year old folks
cheap_deal is offline   Reply With Quote
Old 16th August 2007, 20:42   #11
Ford Rocam's Avatar
Thanked: 16 Times
quote=cheap_deal;534531]thread over a year old folks
So What?
Indica V2 Turbo - Turbo Failure abhik Technical Stuff 15 30th November 2017 17:24
Twin Turbo GTO or Turbo MR2 spiff Luxury, Imports & Niche 32 29th September 2014 01:52
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
Indica Turbo vs Non Turbo lbhavani Technical Stuff 0 5th September 2006 22:22
New Indica Turbo - is the turbo on? gakudva Technical Stuff 5 15th July 2006 23:00
