Old 7th August 2014, 03:04   #1
Sprucegoose's Avatar
Thanked: 38 Times
Default Skoda Octavia vRS - Power window issues
Hey Guys,
All of my power windows recently stopped working along with central locking.
The Driver's Power Window was malfunctioning, but the rest were working.
I replaced the Power Window module, but now the other windows and central locking aren't working at all.
Do i need to reconfigure the car [coding] to the new module?
I seriously doubt all the other modules just happened to fail at this time.
Sprucegoose
Sprucegoose is offline   Reply With Quote
Old 7th August 2014, 07:37   #2
dark.knight's Avatar
Thanked: 2,963 Times
Default re: Skoda Octavia vRS - Power window issues
The service station should be able to rectify this, since this is a purely electrical issue (related to BCM) I'd suggest first to get the on board system scanned and see what problems are displayed on the scanner. That will give a good idea on what has to be done.
Possibilities could be something related to the convenience module, or relays or a simple fuse that would need either cleaning or replacement. This maybe related to the module that you got fixed as there's no chance that all windows will fail mechanically at the same time. Seems like jammed up electronics this time. Take it to the station and get it scanned, those would be the ideal first steps as replacing the p/w module hasn't worked.
dark.knight is offline   (1) Thanks Reply With Quote
Old 7th August 2014, 09:04   #3
Thanked: 9,728 Times
The module sits in the drivers door, quite possible that dampness or moisture is causing this to malfunction.
ajmat is offline   (1) Thanks Reply With Quote
Old 7th August 2014, 09:09   #4
VW2010's Avatar
Thanked: 2,045 Times
I sense only two possibilities. Coding issue or battery condition. I wish i can help you with the VCDS. The service station will be able to fix coding issue in few minutes.
Usually when you swap a new module or the old module breaks an error code is generated and it may require a clearing of the error code.
And all these electrical signals that inturn turn into these modules/codes are controlled by voltage coming from these circuits at specific sensors. While replacing and rewiring even a taping instead of soldering can cause differential voltage that is not what the sensor is expecting to report as working.
Could be wiring, or coding or battery issues I made it to three now.
VW2010 is online now   (1) Thanks Reply With Quote
Old 7th August 2014, 12:03   #5
Thanked: 38 Times
Thanks guys, my local mechanic has a scanner [G-scan]
Will Scan it and see.
Want to Avoid going to Authorised Skoda, as they are frighteningly expensive and i've heard horror stories about them.
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Honda issues recall for faulty power window switch on 2nd-Gen City Achyuth Vaibhav The Indian Car Scene 13 3rd July 2013 09:46
Skoda Rapid Warranty Issues: ICE blamed for Power Window Failure veeru27 In-Car Entertainment 93 23rd June 2013 12:14
Skoda Octavia II vRS skodaboy The International Automotive Scene 19 7th May 2006 20:17
Hot Skoda Octavia vRS nikibusa The International Automotive Scene 11 21st September 2005 12:58
