Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 7th April 2008, 15:04   #61 (permalink)
Chevy_lover's Avatar
Default Noise from 3rd row seat!
Dear Team, I own a Tavera NY LT 2 triple AC 2006 model. After my drive to Kerala, a metallic (click-click) noise is coming from the third row seat (front facing). I tried to solve this problem with the help of GM mechanics, but they have failed to pin point the problem.
I tried tightening the screws in the seat, but still the problem persists. Can anybody advice me on this? Anybody faced this sort of a problem? Any suggestions on how to stop this noise?
__________________
Travelling ten thousand miles of world is better than reading ten thousand scrolls of books!!
Chevy_lover is online now   Reply With Quote
Old 7th April 2008, 15:24   #62 (permalink)
Nimz's Avatar
There is a possibility that some gravel is lying on top of this metal plate.
Thanks for the reply TSK.. will clear it out and see..
Nimz
Nimz is offline   Reply With Quote
Old 9th April 2008, 18:51   #63 (permalink)
Default Humming sound from front wheel
Originally Posted by Roshun View Post
Is it a grinding / rumbling sort of noise which increases with speed? I'm assuming you've already checked your tyres throughly for any lodged stones/debris.
Try taking the car above 70kmph, shift to neutral and let it coast and listen for the sound. If it is present and decreases as you slow down, then I would suspect a worn wheel bearing. Also is the noise more when you turn slightly?
Put the car on the jack & hold the tyre at the top and bottom and try shaking it to check for play. If there is play - it's the wheel bearing - get it replaced, it's a two-hour job max. Check both front wheels.
Rgds,
Hi Guys,
I pulled it out from under 3 years of posts on this thread! actually my Hyundai Accent is making this humming (woonwoonwoon) noise from the front wheel. it has nbew michelin tyres in the front. the noise increases as i increase the speed. i think it does get pronounced over turns, but i will have to recheck that. but the front wheel bearings have recently been changed by the previous owner (6 months ago). I was told by the Hyundai guys too that it has to be changed but i couldnt believe it! how could it be possible that the bearings would've gone off so fast? Hyundai *** would charge me 4.5 grand for this. is it advisable to get it done outside? What's the OEM? Please advise me on this as this is taking away from the pleasure of driving.
Thanks,
Harsha
__________________
If you're incompetent you have to be honest, and if you're crooked you have to be clever.
harsha.cs1 is offline   Reply With Quote
Old 15th April 2008, 15:50   #64 (permalink)
Nimz's Avatar
Nimz
Bhpians.. just to update.. went under the car with a broom and cleared out the gravel but the noise persisted which broke my heart everytime I took the car.. Spark has a near noiseless operation and this sound felt so pronounced. So took it to Sundaram, Pls note - never go to Sundaram between 1 and 2 PM. Lunch time and no one bothered to talk to me. Lunch time sir.. literrally no activity.. like the govt factories of yore.. and similiar to that at 2 PM a siren.. ppl moved in.
Got a mechanic to come.. the poor gal had to literally bargain with 2-3 ppl to get one to come and take a look. He went under. The metal plate had bent and was hitting the silencer assembly. So vibrations from the silencer were transmitted to this plate causing the sound. He took it inside. Raised it on that hydraulic jack. Used a metal rod to straighten that plate and off I went. No charge nuthing.. now no noise and me and Sparky all happy happy
Old 1st May 2008, 05:29   #65 (permalink)
Wow, all sorts of sounds! I am getting this really weird sound everytime my car starts going above 60. Its like a "wheeeeee" which changes pitch depending on the speed, somewhat like a siren. Maybe the sound exists at all times but i dont hear it low speeds because the frequency would also be low. My friends kid about it saying that the cops are after me! I have a Swift VXI with ABS and its done about 30k kms. The service guys also could not pinpoint anything. Any suggestions?
neerajtrehon is offline   Reply With Quote
Old 2nd May 2008, 15:57   #66 (permalink)
Default Thanks Anyway
Hi friends,
I had posted this message about the humming sound coming from the wheels, but found no response. i got the trouble sorted out. they were worn out bearings. saved 2.5K by getting it done out of showroom. now the car is running fine.
Thanks anyway,
cheers!
Originally Posted by harsha.cs1 View Post
Hi Guys,
Thanks,
Harsha
__________________
Old 5th May 2008, 05:04   #67 (permalink)
ankitahuja's Avatar
Hi friends,
Thanks anyway,
cheers!
Hey Harsha,
The sound indeed is the bearings. Just like you said, it increases when you accelerate and decreases/deadens when you take turns. I've to get these replaced on my girlfriend's accent too. How much did you spend for all this? Labour etc?
ankitahuja is online now   Reply With Quote
Old 9th May 2008, 15:59   #68 (permalink)
Originally Posted by ankitahuja View Post
Hey Harsha,
Dear Ankit,
The A.S.S. quoted 2k for each side front bearing and 500 for service.
I got it done outside, got the parts myself and took it to the hydraulic etc. I paid 625 for each side and 700 for service outside (including 300 for the hydraulic press).
How much did you pay for the job and where did you get it done?
Cheers,
Harsha
__________________
Old 11th May 2008, 20:29   #69 (permalink)
ankitahuja's Avatar
@Harsha - Thanks man, I will keep these prices in mind. I haven't got the job done yet like I said, so wanted to get an idea about this from you.
Will update once I get the job done.
Old 6th August 2008, 02:35   #70 (permalink)
ankitahuja's Avatar
BUMP!
Just wanted to update that I got the original bearings for Accent a month ago but have got no time to get them fixed
The bearing sound has become life threatening but the good thing is that it's driven maybe just once a week for about 7-10 kms.
OT: Any nice place in/around Central Delhi who can do the job for me?
__________________
åĐïğŧėđ Tŏ Ÿoů...
Old 10th August 2008, 14:01   #71 (permalink)
devnull's Avatar
I have been getting this noise since the last 2 days in my 8 months old Spark:-
When: Just after slotting to 2nd or 3rd gear. Just as I release the clutch and press the accelerator. But the sound does NOT occur every time I do this. Some 2 or 3 times in a 7-8 kms drive.
Noise type: It's a shrill "screeeeeeeeeeeee". Just happens once (no repeating). Dies down as I go on accelerating. I have heard this noise from other vehicles as well.
Note - this noise started two days back when I was driving in real water logged streets of Hyd, what with the continuous pour here since 3 days. I found some similar descriptions in this thread but not sure if they are the same.
Please advise as to how bad this problem is.
Thanks,
/dev/null
devnull is offline   Reply With Quote
Old 17th August 2008, 10:07   #72 (permalink)
vivekiny2k's Avatar
Location: Loveland, OH (cincinnati area), jabalpur, chennai
probably your belt. use a spray called belt dressing to improve it's condition. stream it on the inside of the belt.
EDIT: something like this Find Belt Dressing, 6 oz and other Shop Equipment at Aubuchon Hardware
__________________
______________________________________
with great power, comes great responsibility.
bigger the car, longer the cleaning time.
vivekiny2k is offline   Reply With Quote
Old 17th August 2008, 10:17   #73 (permalink)
nirmalts's Avatar
The driver seat belt on my Aveo makes some noise whenever it stretches (ride through a bumpy road etc.). Whenever I take it to service centre, the noise disappears and hence cannot prove it to them. Anyone faces similiar problem? The noise is coming from the buckle.
Nirmal
nirmalts is offline   Reply With Quote
Old 20th August 2008, 23:42   #74 (permalink)
condor's Avatar
four_tire : ThunkThunkThunk
WHERE: One or both front corners of the vehicle.
WHEN: Going around slow, sharp corners under light throttle.
WHAT: A CV joint that allows your front wheels to turn and still be powered is loose. The boot has failed and let out all the CV joint’s grease, or maybe it’s just time for it to wear out.
Car : a 5 yr old M-800.
Run : Approx 65k.
Symptoms : as described above. Only front right side, when steering's turned fully, and at a little speed. If the turn is gentle & slow, no sound heard.
Thunk Thunk Thunk or katd katd katd .. :-)
The mechanic said axle's the problem.
Q1: Any other causes possible ?
Q2 : Do I need to replace both half axles ?
Q3 : Approx cost, pls.
TIA !
__________________
Life is Analog. Digital is an approximation.
Old 21st August 2008, 03:06   #75 (permalink)
iraghava's Avatar
It's the axle Condor, pretty simple to replace & not to expensive either. And you only need to replace the one that's making the sound, don't touch the other side.
__________________
Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water.
Thread Tools
Surround sound raajsree Ask the Gurus 4 4th July 2008 18:09
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Rhythmic sound from some where... DRC Technical Stuff 7 18th September 2006 17:26
HU ---> Sound panky12345 Ask the Gurus 18 28th July 2006 12:34
What could this sound be?! Zappo Technical Stuff 14 20th December 2005 18:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
