Old 4th October 2011, 20:19   #286
Thanked: 36 Times
Default Re: What's that sound ??
I own a Fiesta S petrol which has clocked 17000 km on the odometer.A few days back, I noticed a little problem.Just today, I investigated a little better by opening the hood.Here's what I can make out.When I start the car first time in the morning, there is a faint krrrrrrrr noise from near the serpentine belt.As the engine starts to warm up the noise starts to decrease in loudness and frequency. On revving the engine, the noise vanishes.Help me please.
abhipuru16 is offline   Reply With Quote
Old 6th October 2011, 17:51   #287
Post Re: What's that sound ??
Originally Posted by shrjun View Post
I have a 2005 Swift Petrol which has done around 30000 kms.It's been serviced around 5Ks ago.Over the last week,I've noticed a loud boomy whining noise coming from the engine bay region ( can also feel it through the gear shift) when the car's speed goes over 60 kmph.The sound increases in intensity as speed/revs increase and becomes unbearable at around 100 kmph.
I would be glad if someone diagnose this quite unnerving development - the petrol Swift sounds like a very badly maintained helicopter readying for takeoff !
Turned out to be sound from a worn out rear wheel bearing.Replaced it at the Maruti Service Center and all is well again!
shrjun is offline   Reply With Quote
Old 21st October 2011, 14:42   #288
Chetan_Rao's Avatar
Thanked: 4,348 Times
Mine's a 2006 Accent 1.5 Petrol. A few months ago, I noticed a creaking noise when the car leans on the right rear suspension. No sound while running on flat tarmac, or while taking speed-breakers in a straight line.
Got it checked at Hyundai A.S.S., and they said it's fine. When I persisted, they said they'll replace a few components if I wanted, to which I said NO. Now the sound has increased, I mean it's evident even on a bad road, while earlier it was happening only when the car leaned completely on the right rear.
What can be wrong? I don't want to change the entire assembly just because the Hyundai jokers can't find what's wrong.
Chetan_Rao is online now   Reply With Quote
Old 31st October 2011, 17:28   #289
Jaggu's Avatar
Thanked: 8,695 Times
Have you checked if all the suspension bushes are in tact? And have you checked for the sound after a good under body pressure wash? If the sound vanishes for few days after a wash it might be a worn out or badly lubricated bush.
Hope you have ruled out issues like a badly aligned door/door hinge, they also can cause creaking sounds especially at certain odd angles.
Old 31st October 2011, 17:35   #290
Chetan_Rao's Avatar
Default Re: Hyundai India, unreasonable long term maintenance and service practices!
Originally Posted by SPIKE ARRESTOR View Post
Is this sound ^^ coming from the suspension or the wheel ends?
Spike
Difficult to say, as I haven't been able to replicate it while stationary. It's most evident if I take a tall speed-breaker at an angle. A sound very similar to a creaking joint. But I have no issues while normal driving.
Important to mention, I had my car transported on a trailer last November, and those guys normally tie the car down using belts on shafts. Would that have caused an alignment issue?
Old 31st October 2011, 17:40   #291
Chetan_Rao's Avatar
I got the entire right-rear checked at H.A.S.S, and the guy who took the test drive before-and-after, said nothing's wrong. But the issue seems to be getting worse. H.A.S.S. want to change the right-rear suspension parts, but that seems more like a ploy to make me go away, rather than sorting the issue out.
Old 31st October 2011, 17:56   #292
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Jaggu's input is genuine but I guess this sound is different. Bush sound is similar to a squeaking rat, this seems like a metallic noise (Chetan please elaborate further).
Have you checked the cars underbody? If not please do this first to see any abnormalities (something loose etc)? As you say the noise has increased it can also be something which was just loose became more loose and causing more fouling. I have noticed such failure pattern while we used to test vehicles (hand brake cable fouling with propeller shaft, shock absorbers etc). Also, you say the sound is prominent while taking turns while going through a speed breaker this is a typical failure mode of suspension articulation leading to fouling-- so check if there are any rubbing marks underneath. If all this is cleared, I would suspect the wheel ends then.
As it is the rear suspension, we can keep this on hold for time being (less chances of happening), front suspension would be more prone to such damage. This is what I feel, exact diagnosis is possible if the noise pattern is first ascertained.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 31st October 2011, 18:05   #293
Jaggu's Avatar
What part do they want to change? Any idea?
Get all the doors including boot lid checked for proper alignment, sometimes it can be as simple as that. Get someone to sit behind and figure out the sound, that should be the easiest way to identify the culprit if its one of the body parts.
Old 31st October 2011, 18:26   #294
Chetan_Rao's Avatar
@Jaggu: The SA did mention a specific part, but the name's slipped my mind. I'll check with them again and revert. I do seem to remember he quoted about 3K+ labor for the repair, which I refused in the absence of a firm diagnosis. I'll also get the doors and boot-lid alignment checked.
@Spike: I did do a cursory visual and tap-check on the under-body to check for loose parts, but everything seemed fine. I'll get a mechanic to do a detailed inspection.
Old 31st October 2011, 18:42   #295
anonymous's Avatar
Thanked: 15 Times
I am hearing kind of hollow sound (घों घों type of sound, sorry but couldn't find appropriate word for this sound so used Hindi). It doesn't have any pattern, some time it comes at very low speed 30-40 kmph, some times at very high speed though on high speed, the sound level is very promising.
It stays on for few minutes and then disappears.
The car is Tata indica v2 2004 Model.
anonymous is offline   Reply With Quote
Old 14th November 2011, 15:41   #296
Steve_Austin's Avatar
Unhappy Re: What's that sound ??
Friends,
Since this morning, on my i-10 Sportz Kappa-2, less than 5000 Kms done, i have been hearing this metal scraping noise for like 2 seconds...as part of shifting gears.
To be more precise, it's right at the moment, when i start removing my foot of the clutch (after having slotted to the intended gear) and start pressing on the gas.
Has me concerned a bit, any pointers guys ?
Steve_Austin is offline   Reply With Quote
Old 17th November 2011, 10:19   #297
thoma's Avatar
Thanked: 1,112 Times
Question Re: What's that sound ??
Yet another query on sound, not one, but two.
1) Whenever I am buckled up and the car sways over an uneven patch, I hear a squeaking (as rats do) sound from inside where the seat-belt is buckled. I do not think applying grease or oil is advisable as those will dirty our dress. Any body else experiencing this? This was not present when the car was new. Is there an alternative?
2) The muffler on my in-laws 3 year old i10 is producing a sports car like vroom these days. I guess one or two plates inside the muffler has rusted. Although I enjoy the sound, I wanted to know if running thus is bad for the car in the long run?
thoma is offline   Reply With Quote
Old 17th November 2011, 11:41   #298
libranof1987's Avatar
Thanked: 4,225 Times
It might be coming from the buckle i.e. where you lock in the belt.
Na, it won't harm the car in any way. But one fine day, the car will sure sound like a tractor climbing a hill!
libranof1987 is offline   Reply With Quote
Old 18th November 2011, 13:55   #299
thoma's Avatar
Yes, but is there any solution for it? Have anybody else been through this irritating noise? I am experiencing it in a 3yr old i10 and a 6yr old Baleno.
Old 18th November 2011, 15:02   #300
My 1 year old Honda City has it :P
I spent 2 hours at the A.S.S. trying to explain the noise, let the mechanics drive the car in the lousiest of roads and yet there was nothing. The moment I got out of A.S.S., dad buckled his seat belt and the noise popped up! By then, we were in no mood to go to A.S.S. again.
I really don't know if there's a solution apart from replacing it. If your car's under warranty, try it! Maybe a couple of drops of oil might help.
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Cant afford a Turbo? Buy JUST the sound GTO Modifications & Accessories 15 7th January 2006 17:03
My Vtec's Sound system! GTO In-Car Entertainment 55 12th February 2005 22:36
wanna know how the ENZO, F50, F40, 280 sound _Crazi4Speed_ The International Automotive Scene 0 6th July 2004 12:56
