Old 13th December 2012, 14:21   #421
msaudf's Avatar
Thanked: 151 Times
Default Re: Chevrolet Beat ghungroo like sound from front driver-side wheel
Originally Posted by hellmet View Post
At parking speeds only, there is a tink-tink sound like what comes from a ghungroo, from the front driver-side wheel. As soon as I cross about 25kmph, it vanishes. You can't hear it with the windows rolled up, but is pretty audible windows rolled down.
as you had your car inspected and no serious problems were found i think its safe for you to drive around.
please check if something is stuck to your car's tyre.
Ok so does the sound come at a consistent frequency and increase with speed and then disappear after 25 kmph?
if so then its from any of the rotational components like the wheel or drive shaft. you could take a look at the underpinnings of the car at your local car wash that has a car lift.
if the sound is heard when you are going only on uneven surfaces then its the suspension.
msaudf is offline   Reply With Quote
Old 13th December 2012, 14:34   #422
hellmet's Avatar
Thanked: 637 Times
Originally Posted by Samir Taheer View Post
As silly as it sounds have you checked the tyres? There could be something like a stone or nail stuck in the thread! Its happened to me before!
Pretty sure that's not the case. The sound is continuous unlike what you'd hear if a nail was stuck in one place on the tire. Sounds somewhat like there's something moving along with the tire, metal-on-metal.
Sound comes at consistent frequency and increases with speed upto 25kmph and then disappears.
hellmet is offline   Reply With Quote
Old 13th December 2012, 14:55   #423
msaudf's Avatar
Thanked: 151 Times
Aman, Samir could be right, if a nail or screw is stuck to the tyre you could be hearing the nail hitting the road surface on each rotation.
As i suggested you could ask a Local Mechanic to inspect the underpinnings by hoisting it up a car lift.
A DIY method is to Jackup the side from which you hear the sound in such a way that you can rotate the tyre by hand and try rotating the tyre and listen for any sound.
Please be carful to take necessary precaution while doing so as any nail or screw stuck in the tyre can cause deep cuts in your palm. and as a team bhpian you would know what precautions to take while jacking up the car.
Old 16th December 2012, 00:04   #424
sudeep11787's Avatar
Thanked: 65 Times
Default Re: What's that sound ??
Hey Guys !
I drive a 2007 esteem (50 K). Recently i have started to hear a chirpy kind of cyclic noise from front right tire. Kind of metal to metal chirpy noise. The type you hear when you rub the glass. And it's directly proportional to tire rotation. If the speed is low, noise interval is higher, & if it's high then the similar effect. What can it be? Is is something major or just a noise that can be ignored?
sudeep11787 is offline   Reply With Quote
Old 16th December 2012, 01:09   #425
msaudf's Avatar
Thanked: 151 Times
Originally Posted by sudeep11787 View Post
Hey Guys !
have you checked your brake pads? there could be something stuck in between the pad and the rotor/disc.
oh and what happens to the noise while braking?
msaudf is offline   (1) Thanks Reply With Quote
Old 16th December 2012, 09:44   #426
Thanked: 65 Times
Brakes are fine and apply evenly across. In the mornings, they are a bit screechy for a few mins, else fine. Is it possible that it's the belt noise coming from RHS somehow. Can it be bearings also? There is no reduction in speed also.
Old 16th December 2012, 15:13   #427
msaudf's Avatar
Thanked: 151 Times
its less likely to be belt slippage because you will start hearing the noise from the moment the engine is running. bearing mostly produce grinding and booming sounds. i still suspect the brakes, it could be a simple case of brake dust accumulation.
BTW when was the last time you got the brake pads replaced and how about the rear brake shoes?
the best thing to do right now is to give the car a good pressure wash, full water service.
Old 16th December 2012, 18:05   #428
Thanked: 65 Times
I got this from true value at 40k, now its 10k kms old with me. It has been serviced twice. One was a minor one and the last one was a major one. Wheel alignment & balancing is pending. Next weekend i'll go for the same & get the pads & rear drums checked as well. Will keep you posted mate. Thanks !
Old 2nd January 2013, 22:41   #429
Unknownsatan's Avatar
Thanked: 1,482 Times
Hi all, i have an OHC with 195/55 R15 tyres. I am getting some kat kat type sound when i take turns. Any clue as to what is this? i remember reading some thread for this , but cant find now.
Unknownsatan is offline   Reply With Quote
Old 2nd January 2013, 23:12   #430
swarnava.m's Avatar
Thanked: 256 Times
Does this noise increase over uneven terrain?
Might be the ball joints, or worn out boots on the steering assembly.
swarnava.m is offline   Reply With Quote
Old 2nd January 2013, 23:17   #431
Thanked: 284 Times
I have posted a question here - http://www.team-bhp.com/forum/techni...ml#post3004226
msaudf has suggested a few things which I will try over the weekend, but if any one else has any more ideas or suggestions, that would be great.
carboy is offline   Reply With Quote
Old 2nd January 2013, 23:32   #432
Thanks Swarnava. No its there only while turning.
Old 2nd January 2013, 23:58   #433
msaudf's Avatar
Thanked: 151 Times
could it be from the drive shafts? description kinda fits for a worn CV joint bearing.
is the frequency if the kat kat noise proportional to speed?
Old 3rd January 2013, 15:31   #434
Its more like a U turn time. So speed s not a thing to consider in this.
Old 13th January 2013, 16:07   #435
Thanked: 284 Times
Well, my squeaking noise stopped all of a sudden without me doing anything. I had the squeaking for a few weeks. Now it's not there for a week. I don't know whether to be happy or scared.
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Cant afford a Turbo? Buy JUST the sound GTO Modifications & Accessories 15 7th January 2006 17:03
My Vtec's Sound system! GTO In-Car Entertainment 55 12th February 2005 22:36
wanna know how the ENZO, F50, F40, 280 sound _Crazi4Speed_ The International Automotive Scene 0 6th July 2004 12:56
