Old 12th March 2013, 14:15   #451
vasanthn21's Avatar
Thanked: 306 Times
Default Re: What's that sound ??
Originally Posted by sameerg001 View Post
Any updates on this ? Got it rectified ?
No Sameerg, have not got it rectified yet. The reason partly being that this noise vanished for a few days. It is ery difficult to get it rectified unless I can "reproduce" the noise when SA is listening.
In the last month or so, I could hear this noise only once.
Are you facing similar issues?
vasanthn21 is offline   Reply With Quote
Old 12th March 2013, 14:43   #452
devil_klm's Avatar
Thanked: 187 Times
What Sound? Squeaky sound from all over dashboard
Where? It's coming from the dashboard and glass piece in front of speedo
When? Mostly on bad stretchs
Car? 2012 Swift ZDI
Kms? Approx 10000 kms
Realy an irritating sound. Went to 2 service centers and they are not interested in solving or finding the cause
devil_klm is offline   Reply With Quote
Old 12th March 2013, 21:46   #453
sara.ramli's Avatar
Thanked: 327 Times
Reposting my question here as I did not get any replies in the Figo thread :
My TDCi Figo's engine sound has been becoming more prominent in the cabin over the past few weeks. This is post a 1200km+ highway trip with some amount of hill driving involved. It has done about 9.7k on the odo and is due for the second service. The sound is a groan noticeable at around 1800+ rpm. There is no noticeable loss of pickup or any other driving characteristic change.
Is this something normal for a car nearing its service schedule? Or should I be worried?
sara.ramli is offline   Reply With Quote
Old 12th March 2013, 22:02   #454
sameerg001's Avatar
Thanked: 424 Times
Yup, kinda got same noise, Once when i took my accent over 5k on the rpm. But i do not remember hearing the same recently, as i rarely rev her now a days.
sameerg001 is offline   Reply With Quote
Old 13th March 2013, 13:23   #455
Thanked: 72 Times
I am totally out of options and have banged my head in all possible directions to find out the source of a knocking sound that comes from my "2006 Wagon r". The noise resembles a metallic tak-tak only when the engine is warm, there is no sound in the morning.
This is how I began debugging it
1. Removed fan belt the noise was still there
2. Removed AC belt and the noise reduced. MASS told me that I could be the tension bearing so I changed it also changed the timing belt. It gave a feel good factor for few hours but the noise returned.
3. The noise is prominent when there's load on the engine ( with AC and around 4 passengers)
4. My car is fitted with CNG and the I've noted the noise is more when run on petrol.
5. Since the noise is prominent when the ac is ON this makes me think if this could be due to crank OR the big-end bearing. Since ac belt is directly attached to crank.
Just wanted to let everyone know that the sound was there even before installing CNG so it is not the probable cause
I'll be glad if some one can give me some pointers to the possible source
akhilesh is offline   Reply With Quote
Old 14th March 2013, 09:53   #456
arun_josie's Avatar
Thanked: 4,325 Times
Check the below post, I was getting a similar knocking sound from my Dzire which is resolved now. You can give it a try.
http://www.team-bhp.com/forum/techni...ml#post3044122 (What's that sound?)
arun_josie is offline   Reply With Quote
Old 14th March 2013, 10:08   #457
sudeep11787's Avatar
Thanked: 65 Times
I also faced a similar noise issue in my old esteem. metallic clattering.
On inspection, the mechanic asked me to change the wires connected to the spark plugs, complete wiring system for around 1500-2000 rs as the car had already completed 1.2 lacs kms. Stopped using it after a while though.
sudeep11787 is offline   Reply With Quote
Old 14th March 2013, 10:10   #458
paragsachania's Avatar
Thanked: 10,940 Times
Next time you get such noise, try and hold the clutch at that moment and check if the noise/knocking vanishes.
It is a very common issue with WagonR and Alto ( Pre K-Series Engine) and caused by the clutch and more prominent for VALEO make clutch (other OEM is Ceekay where this issue is almost negligible).
Try that and let me know.
paragsachania is offline   Reply With Quote
Old 14th March 2013, 11:35   #459
Thanked: 72 Times
Thanks Arun but that's not the kind of noise I'm getting , the noise is coming from inside the block , not even from the gearbox and doesn't resemble the tappet noise too
Thanks Parag : I remember the sound stays even if I hold the clutch but I'll still give it another try. I see come correlation as I've had 2 clutch replacements, first at 55K (Ceekay) and second at 81K (OEM Ceekay) the odo is at 89K now. The noise started coming within 1 year of ownership but was intermittent. I attributed it to a knock due to bad fuel and I also knew older gen wagonr's had similar sounds so I thought its common and never got it checked from MASS. But now the sound is prominent and stays
Just exploring the possibility : If the problem is due to big end bearing or crank , will it require a complete overhaul ? I think it should be possible just to change the big-end bearing by opening the sump ?
Old 15th March 2013, 21:47   #460
joybhowmik's Avatar
Thanked: 1,909 Times
krrrr krrrr
where : from the engine bay
when: stepping on the accelerator and giving more gas. Not everytime though. only sometimes.
car: 2003 Hyundai Santro Xing AT, done 63000 kms but lovingly cared.
Is it a frayed accelerator cable?
Old 22nd March 2013, 13:42   #461
sudipt123's Avatar
Thanked: 20 Times
The AC compressor bearing noise will come if the bearing is going bad. Until the bearing fails, you will not feel loss of cooling. Since the pulley is always rotating, this noise will come even when AC is off.
Thanks for the advice about the compressor- got the ac compressor overhaul work done and problem is rectified. I think the cost of replacing the compressor was saved with timely detection of the issue- thanks to the sound analysis done on this thread. As sound tells us the state of health of the car- timely preventive maintenance can save all of us some good bucks. Tanveer- i think this thread deserves to be Sticky!
Thanks for the thread
sudipt123 is offline   (1) Thanks Reply With Quote
Old 22nd March 2013, 22:09   #462
sourav9385's Avatar
Thanked: 742 Times
Hey there fellow Bhp-ians!
I think I might have the same kind of noise from my car as well.
Need your help in trying to understand the cause of this noise.
I've taken a video recording that clearly illustrates the noise coming from the engine.
What Sound? Clattering noise from a warm engine.
Where? From the engine bay.
When? ONLY when the engine is warm. The noise never comes during a cold start. Not dependent on Clutch, AC, load either. Noise is quite audible when the engine is idling.
Car? 2004 Chevrolet Optra 1.6 LS, Petrol
Please Note: The car has had its entire engine rebuilt from scratch, in august last year.
Every thing, apart from the con rods, was thrown away & new parts were put in.
This noise was not there when we rebuild was complete.
The noise has been rising steadily for quite some days now.
Any pointers will be greatly appreciated!
Thanks in advance, fellas!
sourav9385 is offline   Reply With Quote
Old 22nd March 2013, 23:05   #463
NPV
NPV's Avatar
Thanked: 4,871 Times
Symptom:Heard mild screeching from tyres on normal slow speed braking this morning (when driving on a smooth road).
Car, Odo:Swift Dzire, has done about 37K Km
Could this be brake pads needing replacement or the tyre tread wearing out and needing replacement ?
(I'm planning on getting this checked during the 40K service, do let me know if I need to go earlier).
NPV is offline   Reply With Quote
Old 23rd March 2013, 00:07   #464
Blow Horn Ok's Avatar
Thanked: 371 Times
From few days I am noticing the following:
Whenever I fire up the engine, I hear a metallic 'clunk' kind of noise just before it starts. Also same kind of noise comes when its being shut off. It appears as if the engine is touching something when it shudders/shakes before coming into life or when it is switched off. What could be the reason? Engine mounts?
Car: Ford Figo Diesel
Kms: 20000
Year: 2010
Blow Horn Ok is offline   Reply With Quote
Old 23rd March 2013, 00:16   #465
msaudf's Avatar
Thanked: 151 Times
Kms: 20000
Year: 2010
too early to have failed engine mounts but hey you never know. obvious signs of engine mounts failure is increased vibration throughout the car when the engine is in idle rpm. well, as you suspect them its best you check them out, also check the transmission mounts as well.
My guess is exhaust mounts either dislodged or perished.
msaudf is offline   (1) Thanks Reply With Quote
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Cant afford a Turbo? Buy JUST the sound GTO Modifications & Accessories 15 7th January 2006 17:03
My Vtec's Sound system! GTO In-Car Entertainment 55 12th February 2005 22:36
wanna know how the ENZO, F50, F40, 280 sound _Crazi4Speed_ The International Automotive Scene 0 6th July 2004 12:56
