Old 22nd August 2015, 19:47   #706
sudev's Avatar
Thanked: 2,433 Times
Stuck brake in rear drums? If you have been wading through puddles and slush this could happen.
Try engaging and then disengaging handbrake. Then move the car in reverse great a bit. Any change?
Or could be rusted hand brake cable.
sudev is offline   Reply With Quote
Old 22nd August 2015, 19:58   #707
parth.jain's Avatar
Thanked: 100 Times
Default Re: What's that sound?
Actually, I have to travel around 500 meters everyday in broken roads with a lot of craters filled with water.
I tried disengaging and engaging the handbrake, moving in reverse and everything. Maybe one of the rear brake pads have broken?
I know I will sort out this problem, but what I am more worried about is the engine power loss problem. Even once the car also stalled in traffic!
parth.jain is offline   Reply With Quote
Old 22nd August 2015, 22:07   #708
parth.jain's Avatar
Thanked: 100 Times
Exclamation Re: What's that sound?
@mods, sorry for back to back posts but the edit option has vanished now. Please merge this one with the previous post.
I just went out to check what's wrong with the car. I started the car and the rpm was fluctuating like it was missing, so I opened the hood to see if there is any problem I can identify. But as soon as I opened the hood, there was a sound like 'bhuk' and the engine stalled
The sound was somewhere from near the throttle body or where the injectors are. I couldn't see it properly as the hood was just halfway opened when this happened.
Will be going to the mechanic tomorrow morning. I suspect something is wrong with the air filter or throttle body. What do you guys think?
Old 2nd September 2015, 01:21   #709
prkiran's Avatar
Thanked: 72 Times
Car: Fiat Punto Evo MJD; 2 weeks old, 400 kms on the ODO
Sound: A hissing noise from the underbody towards the exhaust whenever the car is idling. This is noticeable only if I stand by the side or right behind the car and not at all noticeable from the inside. This is the first diesel car I am driving so not sure if this is normal. Experts?
prkiran is offline   Reply With Quote
Old 9th September 2015, 11:34   #710
sidzz's Avatar
Thanked: 99 Times
I head a thud-thud sound when my grand i10 passes over small potholes at speeds of 30-40 or above. It is very smooth at lower speeds. The car has done only 1200Kms. What could be the reason?
sidzz is offline   Reply With Quote
Old 9th September 2015, 14:52   #711
saket77's Avatar
Thanked: 4,596 Times
Check cold tire air pressure. Since your car is new (1200 kms on odo), it should be a good candidate for check as dealerships have notorious reputation of over-inflating car tires kept in their stockyard.
Saket.
saket77 is online now   (1) Thanks Reply With Quote
Old 9th September 2015, 15:05   #712
knp
Thanked: 18 Times
I had the similar issue in my 2009 i10 for last 3 months. Authorized service center guys could not figured out the problem and they were suggesting me to change the suspension and all, which were costing more than 20k. Somehow, I was not convinced with their diagnosis. Finally, went to my local trusted mechanic and after test driving for 1 km, he pulled the vehicle onto ramp and identified the issues with the Lower arm on the right side. The bushes/joints of the lower arm are damaged and finally, we had changed at the both the sides, which costed 2300/-. Now, I don't hear that sound. So, please have it checked the lower arm in your case also.
knp is offline   (1) Thanks Reply With Quote
Old 9th September 2015, 15:19   #713
sidzz's Avatar
Thanked: 99 Times
Can this happen in a new car?
If I keep driving like this, since the SA said its normal, will it cause more damage?
Saket.
I keep the tire pressure as 33. That's the manufacturer recommend pressure.
Last edited by Gannu_1 : 9th September 2015 at 15:28. Reason: Back to back posts merged. Please use the multi-quote feature (QUOTE +) to quote and respond to multiple posts.
Old 9th September 2015, 15:22   #714
autocrat's Avatar
Thanked: 537 Times
Saket.
1200 km is way too early for lower arm bush wear and tear, unless its taken a very rough hit. Cant rule out as the cars are driven by showroom guys before delivery.
Whatever it is, pursue till you get the solution and make sure you get it done under warranty.
autocrat is offline   (1) Thanks Reply With Quote
Old 17th September 2015, 21:44   #715
sidzz's Avatar
Thanked: 99 Times
Update: Got the car thoroughly checked. The SA was really confused and gave up. Requested me to come the next day as I didn't want to leave the car in the service station.
Next day: While cleaning the car I don't know why I lifted the boot floor. And voila, I spotted the loosely fitted spare tire. Tightened it without a thought and took the car for a spin. There was no sound. I had a wide grin on my face. Still have it, while writing this post. Sometimes, stupid things mean a lot of trouble.
Old 18th September 2015, 13:37   #716
sudev's Avatar
This is great. You keep scratching your head to figure out and...... LOL
Old 27th September 2015, 05:26   #717
sumeethaldankar's Avatar
Thanked: 1,049 Times
Car: Civic
Sound : Typical whup whup sound while driving post 40 to 50 kmph. Sound is heard better if accelerator is let off.
Is this related to tire, wheel bearings or drive shaft ?
I noticed this sound coming after a wheel alignment and balancing job.
sumeethaldankar is offline   Reply With Quote
Old 7th November 2015, 09:16   #718
Thanked: 219 Times
Default Weird Noise in First Gear : i20
My i20 (2011 model) which has been driven ~15,000 km is making this weird "tak tak" noise when in first gear. It started last week. I am not sure if this is the reason, I got the tire pressure checked at a pump, and it started. I went to another pump after this (few minutes later) and verified that the pressure is fine. What could be the reason for this. Noise is coming, somewhere from the back of the car. I am not able to identify the source. There is nothing in between the tire guards and tires. They have a free way to rotate. As soon as I upshift, the sound diminishes to nothing. Anything I should inspect to get a root cause..?
asingh1977 is offline   Reply With Quote
Old 7th November 2015, 11:39   #719
humyum's Avatar
Thanked: 2,238 Times
Default Re: Weird Noise in First Gear : i20
Checked if you have locked the rear seats properly, secondly if you have the seat belts behind, see if their buckle is not touching anything.
Lastly check the lock of the rear hatch, also hit the rear glass lightly from inside and see if its shaking.
humyum is offline   (1) Thanks Reply With Quote
Old 7th November 2015, 11:48   #720
Thanked: 454 Times
Hi asingh1977,
Hope that this is not anything significant.
Do you hear the "tak tak" only once or it continues as long as you are in the first gear?
You can take a trial in 1st gear (do not shift to 2nd) and make one person sit in the rear, to locate the source.
I have noticed that the kids are very sharp to observe and locate the sources of such sounds. They are also small and flexible enough to turn front - back or lean to observe.
Do you get this sound when you shift from 2nd to 1st? Or when you take reverse?
Rahul Bhalgat is offline   (1) Thanks Reply With Quote
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Cant afford a Turbo? Buy JUST the sound GTO Modifications & Accessories 15 7th January 2006 17:03
My Vtec's Sound system! GTO In-Car Entertainment 55 12th February 2005 22:36
wanna know how the ENZO, F50, F40, 280 sound _Crazi4Speed_ The International Automotive Scene 0 6th July 2004 12:56
