Old 8th January 2017, 14:53   #16
blackbandit's Avatar
Thanked: 237 Times
Default Re: Strange issue with acceleration
Sometimes the engine does tend to idle at higher rpms in the event of a cold start.
When it's cold, combustion requires much more fuel in the air fuel ratio because it does not sufficiently vaporize from liquid into a gaseous form. Too much fuel through the engine at a low speed will cause it to stall. Hence the ecu bumps the acceleration to push fuel out more quickly until a desirable temperature is attained. Once warm enough, the fuel vaporizes as it should, the ecu dials back the fuel mixture and the rpms come down. Now this might be the issue you are facing since the problem doesn't return throughout the day.
blackbandit is offline   (2) Thanks Reply With Quote
Old 8th January 2017, 16:34   #17
So, keeping engine on for sometime should help ? What I observed was I had to stop the engine for sometime and start again to get rid of it...
Revention is offline   Reply With Quote
Old 8th January 2017, 17:10   #18
Thanked: 237 Times
A little more insight on your issue would be helpful. The phenomenon i stated in the previous post happens only when the car is left to idle or coast, You will notice a slightly higher idling rpm which settles down once the temperature is reached and its normal. This doesn't hamper driving and is not intrusive of any sorts.
Would like to know if your issue is the accelerator pedal getting stuck or the engine rpm being held after accelerating the vehicle like for eg. if you rev the vehicle to 2k rpm does the rpm get held in that region itself? if so i would suggest you get it checked at ASS might be the accelerator cable or a faulty sensor. if its just a higher idle rpm i wouldn't be worried considering Bangalore does get pretty cold.
blackbandit is offline   Reply With Quote
Old 8th January 2017, 18:29   #19
Jaggu's Avatar
Thanked: 7,659 Times
Does your car have an RPM meter? Have you noted what would be the RPM reading when the idle is raised? During cold start the MPFI cars do have an idle compensator which will raise the RPM by about 200-300 RPM to aid faster heating of engine to operating temperatures. This is normal.
Only if this raised RPM prolongs for more than few minutes/ the engine temperature starts to climb, then you need to check the throttle body. Throttle body idle circuit there would be a stepper system that would need a clean up.
Jaggu is online now   (1) Thanks Reply With Quote
Old 8th January 2017, 18:43   #20
Will check the RPM reading if it happens tomorrow morning.
The raise lasts only few seconds (max 4-5) , everytime, but is unnerving even then...
Also this is something I never encountered in past 8 years
No , its not when left to idle, but when driving and when pedal is pressed.
So its intrusive ( I press clutch immediately for safety)
I did suspect the pedal, but the way it goes off after car restart and never happens again throughout the day, makes pedal issue much doubtful.
I haven't checked RPM reading, which I will do tomorrow, but I believe it must be rising over what I pressed for ....
Last edited by Jaggu : 9th January 2017 at 10:46. Reason: Back to back posts, please use Multi Quote [Quote +] or Edit original post to add reply. Thanks.
Old 8th January 2017, 19:32   #21
Thanked: 237 Times
As per your description it does seem like the issue is of the accelerator cable assuming swift petrol is not equipped with drive by wire. Dirt or fraying(must be dirt in your case) of the cable can cause the accelerator to get stuck for a very short period and return back to normal. You not seeing the issue later through the day might be due to the dirt freeing up on usage. The problem going off after a restart might be a pseudo feel in my opinion, it might be that the accelerator returned to its normal position by the time you restarted. Would suggest you to get it checked and cleaned or changed if the issue persists or has occurred multiple times recently.
Anyways do note the readings and post your observations.
Old 9th January 2017, 10:48   #22
Jaggu's Avatar
Seems like a faulty acc cable as others mentioned or the throttle body idle controller getting stuck momentarily. Try to take a video of the phenomenon on your phone, that will make it easy to explain at service center.
Old 9th January 2017, 11:19   #23
_chikku's Avatar
Thanked: 45 Times
Hi all,
I have a strange issue with my 2008 Maruti Swift ZXi.
Thanks!
I have the same issue in my 2010 Alto K10.
This issue comes up when i drive in rains too. It feels like there is some play in 'A' pedal, but it is not says my SA.
_chikku is offline   (1) Thanks Reply With Quote
Old 9th January 2017, 11:23   #24
Thanked: 375 Times
Hi all,
In the mornings, which I start the car first time, the accelerator has a strange issue. For first few 1-2 kms , the raise seems to "stick" for sometime
I had similar issue in my Santro around 6 months ago. Like many others have said, it was the sticky accelerator cable that was the cause. I did the below experiment and the issue was gone.
Suggest you do the following to validate whether it is accelerator cable issue: Two people are needed to do the below exercise. If this does not solve the problem, you can consult ASC.
1. Before starting the car, Open the bonnet and stand in front of bonnet.
2. Ask the second person to press the accelerator repeatedly(Car should NOT be started. Suggest do not even insert the ignition Key to be on safer side !)
3. When the second person presses the cable, you can observe one lever moving near the engine
4. Once you locate the exact lever, you can directly grease the lever and put some oil inside the cable outer.
I think and wish this will solve the issue.
gkveda is offline   (1) Thanks Reply With Quote
Old 9th January 2017, 12:05   #25
Didn't happen today ! Maybe happens with longer gap in the cold starts...
Accelerator (pedal travel ) meter Sudarshan 4x4 Technical 29 10th August 2011 16:31
Accelerator Pedal of a Jeep Parm 4x4 Technical 6 20th August 2010 03:37
swift diesel accelerator pedal issue RJ555 Technical Stuff 5 23rd November 2009 14:47
Santro: Return spring for Accelerator and brake pedal? ajith Modifications & Accessories 18 2nd April 2008 20:20
Vibration on accelerator pedal while using the horn kaushik_s Technical Stuff 2 8th September 2007 13:59
