Old 1st August 2006, 20:48   #46
tazz_rules's Avatar
i have a esteem vx 1996 without PS and i have also experienced this kind of problems in my esteem. when im at high speeds and i break hard i get a feeling as if my front end of the car is not in contact with the road... and the car feels unstable.
tazz_rules is offline   Reply With Quote
Old 1st August 2006, 22:55   #47
rks
rks's Avatar
Originally Posted by rks
If I remember correctly, my Santro manual recommends an increase of tyre pressures for extended highway runs -- will check out the details and get back later.
Well, my manual only seems to recommend 30 psi for all tyres. I couldn't find any reference to load conditions or highway driving.
Old 2nd August 2006, 00:59   #48
extreme_torque's Avatar
Thanked: 1,489 Times
Originally Posted by WhiteKnight
You are pardoned !!
It is worth knowing that a F1 car weights around 600Kg-including the driver. Do I need to explain more?
Thank you all. Let me implement your suggestions and I shall get back with the results
Dont compare apples with oranges.
Would you care to explain what aerodynamics are used in Esteem to keep it "glued" on the road!
extreme_torque is offline   Reply With Quote
Old 2nd August 2006, 01:58   #49
roms's Avatar
Thanked: 22 Times
"Apples and oranges"?? Thats more like a comparison between Watermelons and grapes..
Well the F1 car may be aerodynamic and all,but I'm sure the F1 car cant be as "air-o-dynamic" as an Esteem!!
roms is online now   Reply With Quote
Old 2nd August 2006, 08:52   #50
prince85's Avatar
Thanked: 117 Times
Chill guys, i think our friend White_knight just wanted to give an example of an F1 car so as to show that weight factor has little to do with handling, stright line stability et al of a car.
BTW, i don't think aerodynamic features of a particular car be explained, can they????
prince85 is offline   Reply With Quote
Old 2nd August 2006, 10:24   #51
WhiteKnight's Avatar
Thanked: 76 Times
Can you see my white flag? Peace man
Well, with your comparison of Esteem with Santro in drag, aerodynamics and handling capabilities, I can take the liberty of comparing Esteem with F1 car.
All I mean was weight does not determine the aerodynamic capability of a car.
Originally Posted by prince85
Chill guys,
Thank you for clearing the air
WhiteKnight is offline   Reply With Quote
Old 2nd August 2006, 13:31   #52
esteem_lover's Avatar
Thanked: 451 Times
guys, guys,
i think u need to have ur heads examined..lol..sitting up in the middle of the night & discussing apples, oranges, watermelons, grapes....go to sleep maan...go to sleep...
Old 23rd August 2006, 04:41   #53
SLK
SLK's Avatar
Thanked: 192 Times
@whitenight... did you try some other esteem.. if that also feels flying?
I would tend to agree with 1100D that less than perfect balancing has a part to play in the free float feeling at 100+ speeds.
SLK is offline   Reply With Quote
Old 23rd August 2006, 10:13   #54
Thanked: 76 Times
Thank you SLK. I am implementing the suggestions one by one.
I reduced tyre pressure to 29 psi. A very marginal improvement, may be.
Based on comments from fellow TBHPians and my testing, I feel my right front tyre is having a toe-out and +ve caster (My assumption). How? On a straight road, the car has a very marginal movement to right. Also, on full right U turn, the right tyre has started scratching the wheel bay
I was planning to do alignment and tyre rotation (didn't know, I crossed 5000Kms in 2 months). Couldn't spare enough time .
Shall keep you all posted
Old 31st August 2006, 10:03   #55
Thanked: 76 Times
Default Back on Earth!!!
Guys,
(Mods- Please modify the title of the thread to say I am back to Earth!!)
Finally I did wheel alignment and balancing. The car is well planted on the road. So I feel the issue is finally settled.
Special thanks to Psycho, Viper, Tifosikrishna, Esteem lover, 1100D and all the rest.
I did the stuff at a MASS, and they didn't do the wheel rotation properly(I had numbered my tyres). All they did was moving my right rear wheel to right front and viz versa. Also my power window stopped working after the service. I tried to talk to the service adviser, and immediately realized he doesn't know anything about wheel rotation. So I escaped before he started putting out his "gyan"
Btw, +ve reading for Toe mens what- Toe in or Toe out?
Old 31st August 2006, 13:09   #56
1100D's Avatar
Thanked: 2,503 Times
Positive Toe Toe-in
1100D is online now   Reply With Quote
Old 31st August 2006, 13:10   #57
1100D's Avatar
Positive Toe means Toe-in
Old 31st August 2006, 13:17   #58
Thanked: 451 Times
Guys,
you are welcome, whiteknight. the pleasure was mine. thanks
Old 8th November 2006, 10:30   #59
Thanked: 76 Times
Recently I took my car service center owned my my family.
They serviced my steering box and changed 2 ball joints. According to my cousin, who is the chief mechanic, the wheels had devoleped play, leading to wobbling.
Anyway, after the changes, the car is handling even better
Old 9th November 2006, 08:15   #60
bayuin2004's Avatar
change your rubber and upgrade them to 185..
bayuin2004 is offline   Reply With Quote
Toyota Corolla 2008 - Wobbling at 110 kph colwyn Technical Stuff 7 29th July 2009 15:08
Bentley Launches Flying Spur facelift, along with 610 bhp "speed varient" sidindica Super-Cars & Imports in India 5 12th October 2008 10:37
Need Esteem above year 2000model in Chennai gump Shifting gears 9 11th December 2007 09:01
