Old 28th July 2006, 09:58   #1
WhiteKnight's Avatar
Thanked: 76 Times
Default "I am Flying" feeling on Esteem above 110 KpH
Above speeds of 110-120 KpH, my Esteem gives a feeling as if it is going to lift off. The front becomes so light, that does not inspire confidence.
1) Is it common for Esteems?
2) I think this could be partly attributed to steering (Mine is HPS). But then, could this also be due to airflow really creating a lift?
3) A spoiler would help?
4) The MGA spoiler is costly. How to get a spoiler that does the work also?
Please advise
WhiteKnight is offline   Reply With Quote
Old 28th July 2006, 10:02   #2
viper's Avatar
Thanked: 9 Times
Originally Posted by WhiteKnight
Please advise
Whilst I have owned 2 Esteems in the past have never experienced this. Maybe because I have upgraded my rubber from day 1.
1> I do not think so.
2> Maybe a combination of very windy conditions and over inflated tyres.
3> NO
4> A spoiler will not help, but better fatter rubber will.
Viper
viper is offline   Reply With Quote
Old 28th July 2006, 10:16   #3
Thanked: 352 Times
Perhaps, you will find the solution here (Baleno levitation at 125+)
tifosikrishna is offline   Reply With Quote
Old 28th July 2006, 10:54   #4
s.prashanth's Avatar
Thanked: 60 Times
2 reasons,
1. the power steering in esteem is hyper sensitive, air gets in under and the car being light and tall on oe rubber causes this
2 Solution= lower the car with 185 section wheels, problem should be solved, anything over 185 would make the car sluggish, heavy to steer, this is appropriate section or if possible get hold of the pe series of tyres from jk
s.prashanth is offline   Reply With Quote
Old 28th July 2006, 11:47   #5
naveendhyani's Avatar
Thanked: 7 Times
completely agree with viper, fatter rubbers should do the job. even then if u feel the "float" u can add 1" spacers at the back.
naveendhyani is offline   Reply With Quote
Old 28th July 2006, 12:22   #6
speedsatya's Avatar
Thanked: 712 Times
MGA spoilers are only for cosmetic purpose and maruti cars dont need any spoiler.get better tires and check your suspension...is your rear suspension too soft ??
speedsatya is offline   Reply With Quote
Old 28th July 2006, 12:32   #7
islero's Avatar
I dont understand. What do spacers have to do with this stability thing? I thought they were merely for cosmetic purposes.
islero is offline   Reply With Quote
Old 28th July 2006, 12:35   #8
Thanked: 76 Times
Thank you all for the inputs
I got to check this out. Psycho had comments on raising the rear on the Thread pointed out by tifosikrishna. I also got to check the front struts being soft?
The tyre pressure is 30 ps(?) on all 4.
I am running on new 175/70 R13 MRF VT. Further upsizing/changing tyres are not supported by my pocket.
Also, how would spacers help?
Old 28th July 2006, 12:46   #9
speedsatya's Avatar
Thanked: 712 Times
your present tires are more than enough ...raising the rear would be oversteer ...dont modify anything ...just check if everything ok ...so many esteems are running on the roads at higher speeds on stock suspensions
Old 28th July 2006, 13:14   #10
2fast4u's Avatar
reduce air pressure to 28
since u have changed tyres recently hope u have got the wheel aligned when job was done. improper wheel alignments can show up sometimes after speeds of 100kmph below that it seems non existant.
cheers
2fast4u is offline   Reply With Quote
Old 28th July 2006, 13:14   #11
rks
rks's Avatar
Above speeds of 110-120 KpH, my Esteem gives a feeling as if it is going to lift off. The front becomes so light, that does not inspire confidence. [...]
I don't know about Esteem, but the same complaint has been made of the Santro too, which has hps. The question in my mind is whether your problem is a real problem or just a case of getting used to the feel of the car. When you say that the "front becomes so light", what specifically is the handling problem that you experienced? Did you feel that the tyres are not gripping the road, say, while cornering or changing lanes at 110-120 kph? Does the car fail to hold a straght line at these speeds under normal driving conditions? Do you sense any problem with the hps?
I personally have ignored this complaint against my Santro (with stock tyres) and just got used to its feel - no problems at these speeds under normal conditions. But under *heavily* rainy and windy conditions on the Mumbai-Pune Expressway, I could sense a genuine handling problem at speeds in excess of 110 kmph -- tyres failing to grip, super-light steering, the hps gave small tugs to the left and right, the car was failing to hold straight line, especially when hitting small puddles on the Expressway.
In your case, you have already upgraded the tyres, so you probably need to pay attention to wheel alignment, balancing, tyre pressures, suspension-- then maybe check your HPS too. If these are functioning normally, my gut feeling is -- just get used to the feel of the car, don't meddle any further with the tyres or suspension.
Old 28th July 2006, 14:24   #12
Psycho's Avatar
Thanked: 95 Times
Would recommend that you do the following
1) Align your tyres, key problem is that it looks like you have excessive toe out.
2) Decrease pressure to 29 psi
Old 28th July 2006, 14:40   #13
esteem_lover's Avatar
Thanked: 451 Times
i've had that feeling many times...as was said earlier, it could be due to the tyres...come to think of it, everytime i had that feeling. it was when my tyres were really bad....however i have a new set now & am going to blore for the weekend...will let u know after my return....BTW i do 165 on my baby on the chn-blr road. will let u know my experiences this sometime around...
cheers
Old 31st July 2006, 05:45   #14
pramodkumar's Avatar
Thanked: 947 Times
I totally agree with psycho that reducing the tyre presure will do the trick and slso check is the car is bit higher from the front. I own an esteem and have never experienced such a thing. and if it is a problem with wheel balancing then the car will vibrate a lot at the above mentioned speed but ususlly higher tyre pressue makes the car a little bouncy. And the MGA spoiler is not just an accssory it is wind tunnel tested. And a spoiler helps if your cars throws at sharp turns.
Old 31st July 2006, 07:40   #15
headers's Avatar
Thanked: 464 Times
how come you guys are suggesting reducing tyre pressure now..I had a difference of opinion in reducing tyre pressures while on the highways..and there was a HUGE opposition to that..
Reducing tyre pressure by a pound or two is CORRECT..or the least you could do is leave it at factory setting and NOT INCREASE..
Toyota Corolla 2008 - Wobbling at 110 kph colwyn Technical Stuff 7 29th July 2009 15:08
Bentley Launches Flying Spur facelift, along with 610 bhp "speed varient" sidindica Super-Cars & Imports in India 5 12th October 2008 10:37
Need Esteem above year 2000model in Chennai gump Shifting gears 9 11th December 2007 09:01
