Old 14th September 2014, 16:40   #1
StepUP!'s Avatar
Thanked: 393 Times
Default Duke's small, light & valveless axial engine
I came across this video about Duke engines:
I found it impressive and different than gnome or rotary engines. Piston follows a path of a sinusoidal wave producing power, rotating central crankshaft.
As claimed, 5 cylinder engine is equivalent to produce power of 6 cylinder conventional engine with only 3 spark plugs, fuel injectors! This is achieved at 30% reduction in weight! Other benefits being higher compression ratio and less space.
Mods: Request you to merge this thread with existing if I have posted in a wrong section. I couldn't find any thread on this.
StepUP! is offline   (6) Thanks Reply With Quote
Old 14th September 2014, 17:20   #2
nitin.rai's Avatar
Thanked: 243 Times
Default Duke Engines!
Wow! This just may be the next revolution for IC engines which seemed to not have improved by leaps and bounds for the last 2-3 decades.
This also may be a breather for petrol engines over diesels due to a higher compression ratio possibility for petrols as there are no exhaust ports causing detonation.
Thanks for sharing!
nitin.rai is offline   (2) Thanks Reply With Quote
Old 16th September 2014, 14:13   #3
Jaggu's Avatar
Thanked: 8,682 Times
Default Re: Duke's small, light & valveless axial engine
Very interesting design, so what is the downside of such a design? Looks quite complex with that spinning design. Vibration and how it is controlled comes to my list of concerns.
Jaggu is offline   (1) Thanks Reply With Quote
Old 16th September 2014, 14:43   #4
mayankk's Avatar
Thanked: 3,559 Times
Seems to have a much larger surface moving against another. Friction, and seals, wonder if they have some new products to deal with that. I'm sure in the pre nanny state f1 days, someone would have picked it up and developed the heck out of it.
mayankk is offline   (1) Thanks Reply With Quote
Old 16th September 2014, 14:52   #5
srishiva's Avatar
Thanked: 929 Times
Can it do variable timing etc with that design or its not required? Looks very compact compression ratio is very good for a petrol.
srishiva is offline   Reply With Quote
The Duke of Direwolves - Lisbeth, my KTM Duke 200 theexperthand Motorbikes 344 3rd July 2018 15:23
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
KTM Duke 200 : Baby Duke 222 unites with her new family! ebonho Motorbikes 931 17th November 2015 16:02
The Duke Finally arrives! (KTM Duke 200) Shubz Motorbikes 76 4th April 2013 10:57
boston co axial Driven Shifting gears 1 27th February 2007 23:13
