Old 19th June 2015, 16:55   #16
hortons15's Avatar
Thanked: 7 Times
Default Re: Chevrolet Cruze: Clutch / Gearbox problem
Originally Posted by Rahul Bhalgat View Post
Disheartened to hear this.
Even in the ASS, it is not easy to re-produce the original fit and finish. But I think ASS can solve your problem of hard gear shift and stronger clutch push back....
Thanks for such an informative post. I'll take it up with the A.S.S., probably talk to them about this now and request them to fix all this in the next scheduled service. I'll be heading home on Monday, and check the damping material for now.
This replacement happened in Nov 2014, which coincided perfectly with the time I got the new petrol i20 elite. Everything in that car feels so soft, light and silent (oh the power steering), that I thought maybe I started feeling that the Cruze felt 'hard/rough' after driving the new i20 everyday in those two weeks. You gave me an idea actually: I should get somebody who owns the Cruze to drive my car and tell me if it drives normal.
hortons15 is offline   Reply With Quote
Old 26th June 2015, 20:49   #17
lancer_maniac's Avatar
Thanked: 15 Times
Any one has any idea how much it will come for overhauling the cruze engine? My 2011 cruze which is driven for only 30k is having some engine related issues as per the mechanic(A.S.S).The symptoms of possible engine issues are positive.And its out of warranty too
lancer_maniac is offline   Reply With Quote
Old 31st January 2017, 18:06   #18
darthvader's Avatar
Default 2011 Cruze LTZ flywheel/clutch plate problems
I'm posting on behalf of my father who has a 2011 Cruze LTZ. The car broke down in traffic in the middle of the road yesterday, after slowing due to traffic. After somehow managing to get it to start again, it was brought back home. The workshop sent people to pick it up from home and advised us not to try and drive it back to them.
The only symptoms prior to this breakdown were: a whining sound when the car would be started, and some difficulty in switching gears (the gears would become hard to operate when the car was cold, and the problem would gradually go away as the car got warmer). During the last servicing, the mechanics pointed to an issue with the flywheel, but they advised us to just let it be until it would blow up in our face because the cost to repair/replace it would be very steep and it might just live on.
The car is in the workshop now, and we plan to visit them to figure out the exact course of action. However, they have given us an estimate of about Rs. 78,900 to fix everything. This includes:
Clutch/Brake Oil
Transmission Oil
Plate Kit CLU Press DRVN W CVR
Cylinder CLU MAS INCL 6
The third component is the costliest (Rs. 58,000) and then of course, there's Value Added Tax (VAT), "sublet charges", other taxes, etc. which jack up the cost.
I'm a bit out of touch with everything now, but I have two questions:
1. Is it possible to claim insurance for these repairs?
2. Is the cost quoted above (Rs. 79,000 or so) reasonable?
All inputs are welcome and greatly appreciated!
darthvader is offline   Reply With Quote
Old 31st January 2017, 23:05   #19
hothatchaway's Avatar
Thanked: 562 Times
Default Re: 2011 Cruze LTZ flywheel/clutch plate problems
Hi
I doubt you would be able to claim insurance as the clutch and related components are 'wear and tear' parts. You have not mentioned the odo reading but unless its clocked a gazillion miles with a bit of clutch riding, does appear to be a little premature. In hindsight, it was unwise to ignore the warning on the flywheel; has the transmission oil been changed at least once in the almost 6 years of ownership?
If the car is no longer in warranty, get a 2nd opinion from an FNG, you could get a more reasonable estimate
hothatchaway is offline   (2) Thanks Reply With Quote
Old 31st January 2017, 23:18   #20
darthvader's Avatar
Thanks! This is what the workshop manager just told us a couple of hours ago while I was waiting for replies on this thread. I guess we have no option but to go ahead with the repairs as quoted. The silver lining is that the quoted amount may be a worst case upper bound.
The car was purchased in August 2011 (so it's been a little over 5 years), and the odometer reading is 55630.00 -- sorry I forgot to mention it in my post. The car has not been driven extensively, but a case can be made for excessive wear and tear in Kanpur traffic. Most of the wear and tear is from "stop and go" at low speeds, i.e. in the first or second gear.
Yes, we coaxed the workshop to have a look at the time. But they said as long as the car starts up fine, we should live with it because it would be difficult to assess the damage until the whole assembly is opened up and examined -- after which the most likely solution would be a complete replacement.
Since the cost of that replacement was high, when this discovery was first made a few months ago, they advised us to just see how it goes and get the items replaced only when absolutely necessary.
I don't think so. The assumption always was -- judging from the odometer -- that since the car is not driven extensively, there's "no need". The workshop that originally managed the vehicle shut down, and responsibilities were transferred to a new workshop which is doing a much more careful and responsible job. That being said, I guess the damage had already been done by the time the new workshop took over.
Thanks again!
Old 31st January 2017, 23:21   #21
Catalyst_delhi's Avatar
Thanked: 149 Times
I can bet you can get 1/2 at an FNG with quality parts. Clutch plate + flywheel + bearing + Fluid + Slave+master. Get a 2nd opinion from an FNG first. The extra part you have is the Gear Oil and i am not sure why they want to change that now.
Catalyst_delhi is offline   (2) Thanks Reply With Quote
Old 1st February 2017, 00:02   #22
itwasntme's Avatar
Thanked: 1,721 Times
Being an owner of a 2011 LT, I don't think there is any major cause for worry. 55k is around the time the clutch pack ( and possibly flywheel) needs to be changed anyway. I changed mine at 40k km due to b2b BLR traffic which costed ~30k. Chevy were generous enough to replace the flywheel (~30k more) as a goodwill gesture.
This is of course assuming you haven't changed the clutch earlier? Also 60k km is around timing belt replacement time. Better get some competent advice on that too!
itwasntme is online now   (2) Thanks Reply With Quote
Chevrolet Cruze stolen from the Treo Chevrolet (Okhla) service center! wilful Street Experiences 16 1st August 2014 13:55
Choosing to Cruze - Chevrolet Cruze LTZ AT. (First 500 kms) a.sundaram Test-Drives & Initial Ownership Reports 47 22nd April 2014 16:46
Chevrolet Cruze or the Chevrolet Optra - Which car and why? blueorchid Sedans 105 18th November 2011 10:03
Hyundai Verna Fluidic Vs. Chevrolet Optra Magnum vs Chevrolet Cruze soulweaver Sedans 55 3rd October 2011 10:48
