Old 26th September 2014, 08:41   #1
Sankar's Avatar
Thanked: 4,655 Times
Default Absence of Oil Cooler in New Swift - How important is it?
How important is an Oil Cooler? The new Swift doesn't come with the oil cooler like the old Swift did. Fiat cars with the 1.3MJD's do come with it even now. The new swift has the oil filter assembly but minus the oil cooler in front. The old one had the oil filter assembly with a small cooler in front.
The only reason i can think of why Maruti removed the cooler unit was because of few cases of oil mixing with coolant and expensive engine jobs when it goes undetected. Coolant and oil mix because of the cooler core damage due to corrosion.
Old Oil Filter Assembly with Cooler
New Oil Filter Assembly without Cooler
Absence of Oil Cooler in New Swift - How important is it?-20140704_150845.jpg
Oil Cooler Core Cross Section
Is the absence of oil cooler one of the reasons why Maruti changed the oil spec from 15w40 mineral to 5w40 Synthetic? The synthetic oil can handle higher temperatures better.
Sankar is offline   (6) Thanks Reply With Quote
Old 26th September 2014, 09:21   #2
deetjohn's Avatar
Thanked: 8,008 Times
Default re: Absence of Oil Cooler in New Swift - How important is it?
Don't know whether that is the reason for the switch to synthetic. And its no longer mandatory. The onus is with the customer on the choice for oil.
I just checked our Nov 2011 ZDi and the oil cooler is missing. The car came with 15w40 mineral from the factory and had the first oil change at 1000 KM. I have always continued with the same, although at 5K interval.
deetjohn is offline   (4) Thanks Reply With Quote
Old 26th September 2014, 09:27   #3
aaggoswami's Avatar
Thanked: 1,542 Times
The Oil Cooler is aluminium made, which means corrosion is not the matter, but rather if coolant mixes with oil, the chemical properties change which leads to erosion of aluminium. Its bit difficult to explain for me, but what happens is that the thickness of aluminium used will get reduced over a period of time and may get accumulated in the plumbing.
aaggoswami is offline   (3) Thanks Reply With Quote
Old 26th September 2014, 09:33   #4
kutlee's Avatar
Thanked: 202 Times
what about Hyundai CRDI engines? do they have similar oil cooler designs?
I feel it is removed to avoid coolant, oil mixing.
I guess good design of Sump is enough to keep oil temps down.
kutlee is offline   (2) Thanks Reply With Quote
Old 26th September 2014, 09:59   #5
Thanked: 765 Times
Maruti is recommending an oil change at 10000 km against 15000 by both Fiat and Tata for the same engines even with 5W-40 synthetic oil. This is probably due to the absence of the oilcooler.
Rahul
Rahul Rao is offline   (3) Thanks Reply With Quote
Old 26th September 2014, 10:45   #6
Sankar's Avatar
Thanks i wasn't aware the owners could choose to fill mineral even when the factory fill was synthetic. I thought all cars which had syn should opt for syn during the changes. This is good news as it will bring down the service cost when combined with the cartridge only change for diesel filter.
Originally Posted by aaggoswami View Post
The Oil Cooler is Al. made, which means corrorion is not the matter, but rather if coolant mixes with oil, the chemical properties change which leads to erosion of Al. Its bit difficult to explain for me, but what happens is that the thickness of Al. used will get reduced over a period of time and may get accumulated in the plumbing.
Thanks aaggoswami, by mentioning corrosion (incorrectly) i meant the damage of metal which you have rightly pointed out as erosion.
No idea as of now, i will need to find out if Hyundai CRDi engines has an oil cooler. While on the subject will try to find out if VAG 1.6/1.5 TDI engines too have an oil cooler. Will also need to find out if the sump design remain the same or if there are any differences between the 1.3DDIS with and without oil cooler.
Maybe Suzuki has found out the driving cycles in India doesn't warrant an oi cooler and the associated risk and may have decided to do away with it.
I am thinking of retrofitting the oil cooler in my car because its running a slightly aggressive remap and i have topped it off with a tuning box (temporarily).
Rahul
Maybe, or maybe because they decided to keep the same intervals for both petrol and diesel motors.
Sankar is offline   (1) Thanks Reply With Quote
Old 26th September 2014, 11:29   #7
sagarpadaki's Avatar
Thanked: 1,337 Times
Hyundai diesels , atleast the 1.4,1.6L CRDi mills dont have oil cooler.
sagarpadaki is offline   (3) Thanks Reply With Quote
Old 26th September 2014, 11:43   #8
tharian's Avatar
Thanked: 3,174 Times
What about a Swift 1.3 P engine?
Just the other day a colleague was telling me that MASS has diagnosed coolant mixing with oil in his car and recommended a expensive job to replace the head gasket. He wanted a second opinion before he went ahead with it.
His car has run less than 50k kms. But there is no engine overheating or any other noticeable issues while driving.
tharian is offline   Reply With Quote
Old 26th September 2014, 11:49   #9
Jaggu's Avatar
Thanked: 8,693 Times
How important is? Well depends on the temperature range, under normal tropical range of 20-40 deg C might not really matter. Only if the weather gods decide to jack upto to 50 deg then one has to keep an eye out on the temperature gauge.
Jaggu is offline   (3) Thanks Reply With Quote
Old 26th September 2014, 11:57   #10
Sankar's Avatar
There is no oil cooler in the Swift Petrol - 1.3 or K12M or K14B.
Old 26th September 2014, 12:02   #11
kutlee's Avatar
Thanked: 202 Times
The old Getz CRDI had a similar oil cooler and one of the cars i had seen had oil mixed with coolant. Get an oil temp gauge and see what temps you run. Then you can see. I guess Unless you are driving through TN or AP aggressively, you would not require one. I had fairly high oil temps passing through TN. But that was mostly due to insufficient engine coolant. I am in process of changing some designs to get even cooler engine temps.
Old 26th September 2014, 13:53   #12
kutlee's Avatar
Thanked: 202 Times
Default Re: Absence of Oil Cooler in New Swift - How important is it?
The turbo Vtec running 220whp (more hp more heat) does not have oil cooler. Get an exhaust wrap to keep hood temps down. and a liner under the bonnet to keep heat away. These are done on the Vtec to keep temps down. A nicely drafted cold air will keep cylinder temps down which in-turn keeps all other temps down.
kutlee is offline   (1) Thanks Reply With Quote
Old 26th September 2014, 13:57   #13
tharian's Avatar
Any idea how coolant can mix with oil in a 1.3 P ? The MASS said something about replacing the head gasket.
Old 26th September 2014, 14:41   #14
Sankar's Avatar
In the Swift D i have seen water temps peak upto 96degC through OBD. Unfortunately oil temp is unavailable unless i plug in a gauge. I'm getting an EGT gauge installed soon. The exhaust wrap will be done on the new downpipe i'm getting. Wrapping the log manifold will not be easy because of the lack of clearance.
A bad headgasket will allow the coolant to mix with the oil. In case of the Swift P which doesn't have an oil cooler the headgasket is a possibility, head also needs to be checked for any warping.
Sankar is offline   (2) Thanks Reply With Quote
Old 26th September 2014, 16:21   #15
VeyronSuperSprt's Avatar
Thanked: 1,664 Times
The oil cooler has not been removed. It is only the rectangular box with the fins which contained the heat sink that has been removed on account of the corrosion as mentioned.
For reference, the oil cooler of the earlier swift (with the fins) has the part number 16500M86J20 and oil cooler of the new swift has the part number 16500M86J60.
VeyronSuperSprt is offline   (5) Thanks Reply With Quote
The Unusual Oil Cooler - How Effective? dhanushs 4x4 Technical 17 11th April 2014 16:45
Fiat 500 delivered in U.S. - ends 27 year absence camchennai The International Automotive Scene 9 14th March 2011 15:06
Oil cooler for 350 mankamble Motorbikes 9 8th February 2010 13:55
Turbocharged 800 Oil Cooler racerdabba Technical Stuff 36 30th October 2008 17:36
Spark, Santro, i10 or others - FE important - 1500kms/month, Rear seat not important monishdesign Hatchbacks 7 11th March 2008 12:27
