Old 2nd August 2006, 13:57   #1
Ironmarine's Avatar
Default 2001 Accent Clutch problem
Hi Guys,
This is regarding the clutch problem with Accent. While driving sometimes the clutch stops responding and can't **** to any other gear. have to stop abruptly on the way and sometimes its very scary.
Showed this with the service station(Hyundai Service Station) and the first time they said that the problem is with clutch setting and after that it was fine. I use this car for travelling to office and back to home and sometimes within city or else for fun ride I use my Alto.
The problem seems to have occured again and I am not sure what needs to be done. Please suggest.
Ironmarine is offline   Reply With Quote
Old 2nd August 2006, 14:32   #2
viper's Avatar
Thanked: 9 Times
Originally Posted by Ironmarine
Hi Guys,
Can you explain the problem more clearly. Does the gear engage but no movement or the gear does not engage/slot in.
As far as the answer you got from Hyundai I think he has fooled you. The Accent comes with a hydraulic clutch which does not have any setting. The problem maybe somewhere else.
Viper
viper is offline   Reply With Quote
Old 7th August 2006, 08:00   #3
Ironmarine's Avatar
Originally Posted by viper
Viper
The problem is that once the gear is engaged and the vechile is moving the the clutch problem starts. Can engage or disengage the clutch nor change to another gear.
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Gettings brothers Accent VIVA CRDi but a mysterious issue and clutch plate problem... ajai_dev Technical Stuff 1 3rd December 2009 22:17
2001 Zen axle, clutch, bumper queries Perakath Technical Stuff 6 10th March 2009 17:48
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
2001 Hyundai accent tornado cheatingdeath Shifting gears 9 16th November 2004 14:39
