Old 20th January 2014, 12:13   #46
audioholic's Avatar
Thanked: 6,107 Times
Default Re: Rear defogger not working
Originally Posted by Sandman689 View Post
A single strip of my rear defogger seems to have failed. I have the materials required for soldering. But what is this 'conductive paint' and how do I procure it?
I dont think its advisable to try soldering on a glass. The enormous heat applied on a small area may crack the glass. But are you aware of where exactly the continuity is lost?
audioholic is offline   Reply With Quote
Old 20th January 2014, 15:44   #47
sgiitk's Avatar
Thanked: 3,882 Times
I repaired something similar with my Peugeot 205 in the UK in 1989. Getting conductive paint was no sweat since as Physicists it was a very common item around the lab. First I used Isopropanol (normal rubbing alcohol, also sold for injections) to clean the area. Then I put two strips of cellophane tape outlining the strip to be patched. Now I painted over three times with thin layers of silver paint, allowing it to dry between applications. Once fully dry I carefully peeled off the cellophane tape and got a very clean fix. Impossible with a brush wielded freehand.
Conductive paint is available in India as well.
sgiitk is offline   (1) Thanks Reply With Quote
Old 20th January 2014, 23:28   #48
Sandman689's Avatar
Thanked: 25 Times
Yes I am cautious of this fact and hence want to know about this conductive paint before I try anything. I have a multimeter, so finding the gap in conductive strip shouldn't be a problem.
Wow. It seemed from here that the conductive paint itself was sufficient to do the fix and no heat was required whatsoever. Given the options, I will definitely try to avoid using heat on a glass. Thank you so much for sharing this Sir.
Sandman689 is offline   Reply With Quote
Old 22nd January 2014, 16:34   #49
Thanked: 606 Times
is you use paint (& thin brush) the chances are still there of uneven coat and effect the conductivity (/resistance). better use a pen, copper 'ink' based.
http://www.chemtronics.com/c-275-cir...-and-inks.aspx
and this is really interesting ! : http://www.kickstarter.com/projects/...uits-instantly
pcpranav is offline   Reply With Quote
Defogger not working / damaged after sun film fitting razor4077 Modifications & Accessories 56 21st May 2014 02:52
Retrofitting Rear Defogger in i10 allwheeldrive Modifications & Accessories 8 3rd November 2011 15:41
Looking for Rear Defogger for Esteem Kar krazy Modifications & Accessories 10 27th December 2009 20:29
Effect of solar film on the rear windshield (with Defogger) hbaruas Modifications & Accessories 1 11th March 2008 14:44
Wagon R under warranty defogger not working , glass needs to be changed ! akhilesh Technical Stuff 9 27th June 2007 01:37
