Old 21st October 2014, 17:19   #1
stable rock's Avatar
Thanked: 38 Times
Default Hyundai Elantra: EGR Error code 402 (Excessive Air Flow)
Hi Firends,
The check engine light in my car is glowing and when scanned got an error code 0402 (Excessive air flow in EGR). Other symptons are black smoke when at sudden acceleration/ high RPM. Pick up is also less. The A.S.S asked me to change the EGR without even checking the EGR unit. What will be the cause for this. Please suggest a good mechanic or workshop in Bangalore to rectify this.
Vehicle Details -2005 Hyundai Elantra CRDI.
Odo Reading - 2,17,000 kms.
SR
stable rock is online now   Reply With Quote
Old 21st October 2014, 17:34   #2
Zappo's Avatar
Thanked: 2,080 Times
Default re: Hyundai Elantra: EGR Error code 402 (Excessive Air Flow)
Has the ASS checked the Differential Pressure Sensor? If not please ask them to check the voltage on the sensor both at idle and when the EGR is open. In my opinion, the sensor has a bigger chance of failure than the EGR valve itself.
Zappo is offline   (1) Thanks Reply With Quote
Old 21st October 2014, 21:45   #3
Thanked: 9,017 Times
I would agree a few more checks need to be done, before starting to swap parts. Easy enough just google Hyundai Elantra error code 402
Here is the result:
http://repairpal.com/OBD-II-Code-P0402
Note that this site also lists the "common misdiagnoses" one of which is the EGR valve!!!
Jeroen
Jeroen is offline   (3) Thanks Reply With Quote
Old 21st October 2014, 23:39   #4
rocky080's Avatar
Thanked: 35 Times
Originally Posted by stable rock View Post
Hi Firends,
SR
Are you running any performance mods like K&N/green cotton filter or tuning boxes? and does your engine RPM get stuck at a particular RPM while accelerating.
rocky080 is offline   (1) Thanks Reply With Quote
Old 22nd October 2014, 09:01   #5
Thanked: 38 Times
Hi Rocky,
I have not done any modifications. Car is in stock condition. RPM is not getting stuck too. Only excessive black smoke during acceleration.
@Zappo - Is Differential Pressure Sensor same as Mass Air Flow Sensor.
Please suggest a good mechanic or workshop in Bangalore to check this.
SR
Old 22nd October 2014, 11:43   #6
rangakishen's Avatar
Thanked: 96 Times
I would suggest going to any Bosch Service center close to your area. In my experience they are quite straight forward and well versed with cars from many manufacturers.
rangakishen is offline   (2) Thanks Reply With Quote
Old 22nd October 2014, 14:08   #7
rocky080's Avatar
Thanked: 35 Times
Hi Rocky,
SR
Hi Stable rock
I asked the same cause I had the same error code issue on my elantra when my MAF sensor and performance filter were chocked. But the only difference was that my engine RPM used to get locked at a particular RPM while revving. This issue got sorted out after cleaning the MAF sensor. There are multiple reasons for black smoke and lack of pick up, my suggestion would be to:
1.Change the air filter and get the egr valve along with MAF sensor cleaned at the A.S.S(Please supervise the work being done)
2. While at it check if there is excessive oil in the pipe that connects beyond the MAF sensor.
3. Get your Intercooler plumbing checked for cracks or leaks in all the joints.
4. Check if there is excess oil in the inter cooler.
Please report you findings after this, if the A.S.S refuse to check this and maintain the egr valve has to be changed, then take a writing from them that they will refund the amount if issue fails to get fixed before replacing the part.
Pioneer Head Unit Errors. Error 11 and error 17 in pioneer MP3 rajivanoj In-Car Entertainment 33 8th March 2018 12:58
EGR system - What's it purpose & when does the EGR valve open/close? rranjith_kum Technical Stuff 60 14th August 2017 20:15
Pune : 402 road deaths this year and counting sajo Street Experiences 12 16th December 2010 17:47
effect of grinding EGR valve in diesels reachbennym Technical Stuff 1 23rd December 2008 09:05
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
