Old 2nd August 2006, 22:23   #1
raghuram.cg's Avatar
Thanked: 20 Times
Default 98 ZEN starter not working
Gang,
I have a 98 Zen , was working perfectly fine till today morning.Right now, it is just not cranking.The ignition lights come up, I turn the Key more, but no luck..no cranking noise, not even the tuk tuk noise that normally comes when the starter is stuck.
I have checked the following, was wondering if any DIY tips are there before calling the service station
1)Battery is fine, the headlights are bright and they dont go low when I turn the key.All electricals are working, so I dont think its a battery problem.
2)I checked the main fuses in the bonnet bay, the 40A one looks fine, but the 60A one, I am unable to make out..are there any tell tale signs.?
3)Push starting the vehicle starts it just fine..
4)No evidence of rats eating off the wire anywhere.
5)I havent checked the fuse box under the dash, will do it in the morning..anything specific to look for there?
Any help is appreciated.
Raghu
raghuram.cg is offline   Reply With Quote
Old 2nd August 2006, 23:17   #2
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Well , unless u have a central locking system with an engine immobolizer .. Which means u cant start it by pushing either ?? Weird .. Could it be a case of a loose contact on the battery terminals ?? Or improper earthing ??
Old 2nd August 2006, 23:20   #3
kpzen's Avatar
Thanked: 1,655 Times
Has happened to me once n in my case the central locking system was the culprit??? If u can, disable it n check....
Old 2nd August 2006, 23:49   #4
autozealot's Avatar
Hope your fuel pump is working fine buddy
autozealot is offline   Reply With Quote
Old 2nd August 2006, 23:56   #5
gr8guzzler's Avatar
Thanked: 38 Times
Chk the ignition solenoid....see if you get a tick sound when you turn the ignition from start to run position.
gr8guzzler is offline   Reply With Quote
Old 3rd August 2006, 12:09   #6
turbo_c's Avatar
Thanked: 7 Times
Happens on my Esteem once in a while (usually if I give some girl inside the car more attention than her, but that's another story ) ...
I described the problem to my neighbourhood mechanic and he showed me another car with a similar problem... there is this cup shaped and sized relay that pushes a 1/4" thick bar across big metal terminals when you turn your key to the "Start" position... it is responsible for feeding the starter motor it's huge current requirements. That much current can't be sent thru the puny ignition switch. With age, the bar and the terminals wear off and eventually, the bar can't make proper contact with the terminals... You may be able to squeeze some more life out the relay by getting it cleaned and lubricated, but it will eventually fail completely. Should also mention: It is quite expensive to replace! (Experts on the forum, please enlighten us with the technical name and approx. price for this "Cup-a-relay" thingie!)
When you twist the key to the "Start" position, do any of the lights in the dash etc. dim slightly?
If they don't then that relay is probably the culprit... if they do, then the problem is elsewhere... possibly loose battery contacts, low battery charge or if you are really unlucky, a jammed starter motor.
- T u r b o C -
turbo_c is offline   Reply With Quote
Old 3rd August 2006, 14:15   #7
Thanked: 20 Times
Default Its working now:-)
Thanks everyone for the tips..actually the battery seems to have gone low.I push started it and drove the car for 10kms , it fine now.
I think the roof light was on inadvertantly and may have caused the battery to go low.
Anyway, its fine now..I will check for a few more days and see.
The last post about the relay was useful - Thanks again.
Raghu
Old 3rd August 2006, 14:15   #8
Default Crank it twice
Hi Raghu
I am not sure whether you have any heater plug in ZEN.
I have seen in Europe, in cold conditions, people crank the car twice and it works. Engine in cold may face this problem.
It works really well for diesel cars.
Try this and revert
Originally Posted by raghuram.cg
Gang,
Raghu
sukheshkumar is offline   Reply With Quote
rear lights not working 2fast4u Technical Stuff 10 7th June 2015 12:53
Rear defogger not working Venkat Technical Stuff 48 22nd January 2014 16:34
Team-BHP e-mail Subscription service not working mithun Shifting gears 3 8th April 2006 11:13
mp3 cd not working in player a4_attitude In-Car Entertainment 2 15th September 2005 23:04
palio 1.2: starter not working properly... amitverma Technical Stuff 14 3rd April 2005 00:34
