Old 2nd August 2006, 22:50   #1
vipul261's Avatar
Question Accent Viva CRDi Fuel meter prob.
Hi i hv accent viva which i got just a week back!
i noticed somethin strange!!.. while i was goin i noticed dat my fuel meter dipped fastly ( but not noticable) to the E mark, and reserve ligth flashed.
Then after some time it got back to the 1/4th mark, where it was originally n again after some time it went to E mark!!
i checked for diesel leak... no sign.
i checked it to service station also, they opened the fuel pump n checked meter also... no probs!!
Can ny 1 explain the phenomena??!!
n 2nd ly... can any 1 tell me the appropriate Gear shift speeds??!!! coz i remain confused.. wats the idle RPM range??
vipul261 is offline   Reply With Quote
Old 2nd August 2006, 23:35   #2
kpzen's Avatar
Thanked: 1,655 Times
Change gear at 2K rpm till the running in period....After that u can enjoy the neck breaking torque of CRDi..
The fuel meter problem is very strange may b an electronic fault....
Old 3rd August 2006, 10:48   #3
Hi:
Ask the Hyundai service station to check the earthing on the car.
I had a similar problem with temperature gauge, and it was fixed after they added a new earthing wire. No problems after that.
giri is offline   Reply With Quote
Old 20th December 2006, 11:11   #4
hi newbie,
did u get any resolution for fuel meter dip problem? This is happening for me in my newly bough accent CRDI as well. For me it happens when fule meter is around 1/4th mark. Can anyone help?
delhiboy_78 is offline   Reply With Quote
Old 20th December 2006, 12:36   #5
sreenivass's Avatar
Default Possible while going uphill or downhill
I think it is possible to have this while going uphill or down hill. I see this kind of changes, not necessarily from 1/4 to E and back, but comparable.
Also my petrol car low fuel warning light comes on once the available fuel is about 11/10 Lts, goes off after I start the engine. The light will be on continuously only if the fuel goes down to 6/7 lts kind.
sreenivass is offline   Reply With Quote
Old 20th December 2006, 14:05   #6
rajismine's Avatar
Thanked: 252 Times
Hey,
Ask for REPLACEMENT of the "FLOAT". Float is a resistance- an equipment which is ligher than the feul and floats in teh fuel tank over the fuel.
Its resistance meter can go bad and hence such a problem. I had a similar problem in my earlier INDICA and got it fixed.
I assume the concept would be the same for all the cars so go and "Replace the Fuel Tank FLOAT"
Hope this helps.
Rajeev
rajismine is offline   Reply With Quote
Old 21st December 2006, 12:45   #7
esteem_lover's Avatar
Thanked: 451 Times
try replacing the float. that should fix it, hopefully.
Old 21st December 2006, 13:12   #8
msandeep's Avatar
HI,
take the car to hyundai service center and tell them to check the fuel meter, and also the float inside the fuel tank
msandeep is offline   Reply With Quote
Old 21st December 2006, 17:56   #9
kpzen's Avatar
Just confirmed the problem faced by Vipul has been solved during the periodic service of his Accent....
Mods pls do the needful..
Old 23rd December 2006, 19:15   #10
vipul261's Avatar
Yeah Prob. Kinda Solved, now the meter is more linear.
but again starts Dipping at 1/4 th Mark.
They adjusted the Float.
Old 9th January 2007, 17:23   #11
mobike008's Avatar
Thanked: 8,319 Times
I too have the same problem with my 3 month old viva crdi
The fuel indicator goes down upto almost E and the warning lamp shows and when i refill after driving after 50km+ is only 30 or 31 litres of diesel ( tank capacity is 45 litres). They changed my fuel assembly but this problem remains.
After the fuel warning lamp showed, i went to hyundai service center and removed the fuel in the car manually and measured the fuel, tank had 15 litres of diesel ...whereas the fuel warning lamp was almost on the letter E and was continously staying ON when driving. i definetly there is an error in the fuel indicator, probably the float or something else.
Throw some light on what could be the problem guys
Customising / Accessorising - Accent Viva CRDI sats Modifications & Accessories 7 6th July 2006 21:03
hyundai accent viva crdi lamborghini The Indian Car Scene 35 25th May 2006 19:28
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
