Old 10th August 2006, 18:28   #16
i have got my Palio converted to LPG....
its a Lovato LPG kit.......
its awesome.....i have a got a sepaerate ECU installed for additional 6k from the LPG guy itself....
but it does make a diff.....mileage is app same....power has reduced.....but only while driving uphill....top speed acheived is 165kph...
n its damn smooth..........
Sagarpradhan85 is offline   Reply With Quote
Old 11th August 2006, 09:47   #17
subbarao's Avatar
Thanked: 39 Times
Default More input required
Originally Posted by Mpower
You can fit a timing advancer module to get more pickup.
M.power, please give us more details about TA Module, is it available here B'lore, i too retrofitted LPG kit to my ZEN mpfi, my dealer have no idea about this module.
subbarao is offline   Reply With Quote
Old 12th August 2006, 12:35   #18
shineshine's Avatar
Thanked: 37 Times
Hi Everybody,
Is there any difference in LPG Conversion kits for MPFI and Non-MPFI vahicles. What are the additionals needed for MPFI engines
shineshine is offline   Reply With Quote
Old 12th August 2006, 18:31   #19
harmon_bro's Avatar
My 99' model Lancer is fitted with a Lovoto Kit. I got it tuned last week. And have a new problem, in a stp and go situation the car literally holds back even when I step on the throttle to the floor. The engine just gives up on me. I will have to press clutch and then pump the throttle a little bit a little bit and later the engine responds.
What could be the problem, at times the engine stalls...
harmon_bro is offline   Reply With Quote
Old 13th August 2006, 17:30   #20
gr8guzzler's Avatar
Thanked: 38 Times
Does that happen in Petrol or Gas mode?
gr8guzzler is offline   Reply With Quote
Old 13th August 2006, 19:17   #21
MADMAX111's Avatar
Thanked: 23 Times
Can the experienced people here tell me
1) How much does Auto LPG costs/litre
2) How much mileage would a car like zen give per litre/ kg of LPG
3) How much is the difference in running costs if any
4) Does the petrol FE drops after fitting LPG kit and driving on petrol.
MADMAX111 is offline   Reply With Quote
Old 14th August 2006, 02:56   #22
nitrous's Avatar
Thanked: 285 Times
Obviously, she's bogging down...Needs more power.
Try giving her a richer AF mixture.
Old 14th August 2006, 04:36   #23
mithun's Avatar
Thanked: 59 Times
Originally Posted by shineshine
Hi Everybody,
Do an Advanced Search for LPG and your question will be answered...
Old 14th August 2006, 11:45   #24
esteem_lover's Avatar
Thanked: 451 Times
that is typical of lovato kits...tuning by an expert could help in the short run, but the problem will be there for ur life...it has something to do with the kit itself...pm me if u r interested, i will give a right contact who will rectify ur problem
Old 14th August 2006, 13:08   #25
I am back.. Got my cars fine tunning done this week. now its giving me better performance...barely diff betwn Petrol and LPG (well climbing uphill still exists but with lesser effect)...
mechanic 1st tsted my acr with petrol..tunned it up with the filter adjustment to ive max eff and speed....then the LPG setting was tunned to give better results...
Mechanic also suggetsd he can even better the speed if required on long drives but have to spend a bit og more gas (wel no need to do this while driving in city like mumbai and specially on WE highway...u never touch a speed of 100 anyhow)...
I tsill have my fingers crossed..lets wait for a week or 2 to make sure the setting is permanent and do not ahve to visit the mech every now and then...
[FONT=Tahoma]"Never let yesterday's disappointments overshadow tomorrow's dreams"[/FONT]
tvsakpal is offline   Reply With Quote
Old 14th August 2006, 16:13   #26
Thanked: 451 Times
1. Costs around 24-25 per litre
2. Should give around 11kmpl, if ur car gives 12-13kmpl in petrol
3. Calculate this urself (Savings of Rs.27 per litre - 1 km drop in mileage)
4. Normally, it should not.
Old 14th August 2006, 16:16   #27
Thanked: 451 Times
is that a carb or mpfi model ????
Old 16th August 2006, 01:37   #28
MADMAX111's Avatar
Thanked: 23 Times
Thanks Esteem lover,
Actually by running costs i meant any additional expenditure due to LPG like earlier oil change, increase in service costs etc.
Old 17th August 2006, 13:32   #29
Thanked: 451 Times
nothing that i know of , except that the kit has to be serviced regularly for optimum performance.
Old 17th August 2006, 15:58   #30
I have a 2004 Fiat Palio 1.2, want to get converted to LPG/CNG, You suggest which one is better. More over what kind of mileage i can expect after conversion as cost per km with petrol is around 4.00 with a/c on. I am from New Delhi. Too hot here to drive w/o a/c.
Please also mention the total cost for everything. I wannna go for automatic changeover kit which after a certain rpm changes from petrol to LPG/CNG.
Regards.
jdutt is offline   Reply With Quote
Know about LPG Conversion.... sonycs Technical Stuff 173 17th April 2014 09:13
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 58 2nd July 2010 21:39
Fiat Palio 1.2/1.6, Is LPG conversion advisable. Dhanan Hatchbacks 9 27th September 2006 18:09
LPG conversion for a FORD 1.6 wannaplay Technical Stuff 4 2nd June 2006 04:34
Esteem 95 LPG conversion-Bangalore sriramraj Modifications & Accessories 3 23rd May 2006 07:09
