Old 16th December 2006, 22:53   #61
esteem_lover's Avatar
Thanked: 451 Times
First we need to know if the car is a carb or MPFI, then whether this happens in petrol also, if so, is it with the same intensity ? if it happens in petrol too, then MASS better fix that. they cannot just blame it on the LPG install. it is their job to rectify the problem while in petrol. of course, they would rather prefer your friend to spend more money on replacing silencers.
Old 16th December 2006, 23:05   #62
ECM
ECM's Avatar
Thanked: 9 Times
Sure dear E_L will post feedback if I manage to get hold of that person,infect he is unknown to me and I met him last week when he was there to get his prob sortout.Will try to find his trace but one thing is sure that this problem he never had and he told me that after kit install all started.Thanks for chipping in to help this poor chap,i still recall his face when bigbang used to hit his car,so scray he was
ECM is offline   Reply With Quote
Old 20th December 2006, 07:58   #63
ECM
ECM's Avatar
Thanked: 9 Times
It is a carb car and not mpfi got this info last night,still in a process to establish a contact with owner though.
Old 21st December 2006, 19:00   #64
mail4ajo's Avatar
Thanked: 261 Times
I think the simplest method would be to empty fully and fill to only the capacity it can take. For example the tordial tank can take 28 litres(ie 80% of its 35 litre capacity).
So we can empty and fill exactly 28 litres. At Palakkad reliance bunk, I filled 30 litres for a 28 litre capacity. I lost 50 Rs and learnt this lesson. This may be an issue on long drives with few bunks on the route.
mail4ajo is offline   Reply With Quote
Old 21st December 2006, 20:35   #65
nikkibike's Avatar
Question Q.
How important is the maintenance of airfilter in an LPG kitted engine??!
nikkibike is offline   Reply With Quote
Old 21st December 2006, 22:43   #66
autozealot's Avatar
Where can I get a list of the cars which could be officially (govt. approved) converted to LPG.
thanks in advance
autozealot is offline   Reply With Quote
Old 22nd December 2006, 00:11   #67
gigy's Avatar
Thanked: 41 Times
maintenance of air filter is very important as far as lpg is concerned. you can immediately notice the change in pickup after you install new filter. so best is to get a free flow for small engined cars and extreme for larger cars.
gigy is online now   Reply With Quote
Old 22nd December 2006, 07:11   #68
nikkibike's Avatar
Question Q
ok!!! so for a Swift, can I use the K&N replacement filter incase I install an LPG kit?!!
Also, cud you pl explain the reason for this?!! Thanks in advance!!
Old 22nd December 2006, 08:15   #69
Thanked: 451 Times
a clean air filter is vital in LPG cars. almost 75% of complaints in LPG cars are because of unclean filters.
Old 22nd December 2006, 17:49   #70
nikkibike's Avatar
Question confused!!
OK!! So in that case, using free flow/k&N filters for LPG cars is recommended or what?!! Thanks in advance for your inputs!!
Old 22nd December 2006, 23:03   #71
gigy's Avatar
Thanked: 41 Times
i am using extreme free flow in baleno without any problems, all my pickup and power issues are solved. but in santro its not able to sustain idle rpm with lpg. i have to increase the gas flow to make it run. now its not picking up speed as it does in petrol. on 4 th gear at 40kmph if i slam the accelerator the engine starts dying down. any one has idea on this? thinking of going for ecu control for both the cars to prevent damage to cat converter
Old 23rd December 2006, 08:38   #72
Thanked: 451 Times
the idea is, no matter what filters you use, unless they are free of dust, the pick up will drop drastically. yes you can have free flows etc in a LPG car
Old 23rd December 2006, 21:38   #73
nikkibike's Avatar
Default Thanks esteem_lover
Thanks for that!! One more apprehension... Will K&N filters provide dust free clean air into the cylinders?!!
Old 24th December 2006, 10:50   #74
nitrous's Avatar
Thanked: 285 Times
Oh yeah! Thats why they sell like hot cakes!
Old 24th December 2006, 22:59   #75
nikkibike's Avatar
Smile Thanks
Thanks for that confirmed reply Nitrous!
Know about LPG Conversion.... sonycs Technical Stuff 173 17th April 2014 09:13
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 58 2nd July 2010 21:39
Fiat Palio 1.2/1.6, Is LPG conversion advisable. Dhanan Hatchbacks 9 27th September 2006 18:09
LPG conversion for a FORD 1.6 wannaplay Technical Stuff 4 2nd June 2006 04:34
Esteem 95 LPG conversion-Bangalore sriramraj Modifications & Accessories 3 23rd May 2006 07:09
