Old 6th November 2014, 08:27   #16
jfxavier's Avatar
Thanked: 1,262 Times
Default re: Volvo S60 instrument console failed. Repair or replace? Volvo to replace under Goodwill!
Some new information has come to light WRT the Volvo DIM speaker failure.
In the sweedespeed forum someone had given me the below info.
Looks like I am not the only one with a bad speaker in DIM.
Now I am beginning to see a reason behind Volvo service not responding to my mails regarding the issue. They just keep quiet when I raise this issue. Otherwise they have no problems when I ask about accessories etc.
quote
Technical Journal
TITLE:
DIM speaker does not work
CAR MARKET:
United States and Canada
ISSUING DEPARTMENT:
Technical Service
REF NO:
TJ 25164
ISSUE DATE:
YEAR
2013
MONTH
01
DAY
11
PARTNER:
3 US 7510 Volvo Cars North America
FUNC DESC:
Combined instrument, complete
FUNC GROUP:
3811
DIM = Driver Information Module
DESCRIPTION:
Warning sounds from the DIM for the seat belt reminder, Forward Collision Warning and Lane Departure Warning may not occur due a faulty speaker.
PRODUCT MODIFICATION:
An improved speaker has been introduced at the DIM supplier from August 31st, 2011. DIMs produced from that date and with serial number 0854798 and higher have the improved speaker, see attachment.
SERVICE:
Replace the DIM.
VSTG OPERATION NUMBER:
38130-2 Driver information module remove - install/replace, see VSTG
36004-2 Software control module downloading, see VSTG
unquote
jfxavier is offline   (1) Thanks Reply With Quote
Old 8th November 2014, 12:34   #17
Thanked: 6,217 Times
I hope you can get it repaired. If you cant and it needs swapping have a look at this thread
http://www.matthewsvolvosite.com/for...c.php?p=346285
Appears these DIMs are not all interchangeable and even if they do work there might be a problem with the mileage.
On the upside, I also read it is a 10 minute job to pop the DIM out. So I would say pop it out, open it up carefully and who knows. If you can see the speaker you can check the speaker and you can replace the speaker if need be.
Good luck
Jeroen
Jeroen is offline   (2) Thanks Reply With Quote
Old 8th November 2014, 17:34   #18
jfxavier's Avatar
Good luck
Jeroen
Thanks Jeroen
I am am member of that forum & have gone through that earlier.
It will be very rare that there is an S60 DIM available here in India.
Since the car is imported fully built, I guess the S/N might match the ones available in Europe etc. if required.
This week the jobs in hand are the tyres replacement, paint polishing etc.
Checking the speaker is the next step and will be done, maybe in a week or so.
On the various forums, the results have been mixed after changing the DIM, there is a thread somewhere in US someone is trying to swap the analogue cluster with the TFT type 2014 DIM.
http://forums.swedespeed.com/showthr...r-DIM-Retrofit
I am keeping a track of that too. Looks like that needs extensive work on the CAN.
Old 10th November 2014, 20:28   #19
jfxavier's Avatar
This is the culprit, I believe.
No information on the speaker regarding the impedance, wattage etc.
If anyone in this forum is familiar with the speaker as shown in the picture, please do let me know the specifications such as the impedance, wattage etc.
Thanks in advance.
Volvo S60 instrument console failed. Repair or replace? Volvo to replace under Goodwill!-imag1046.jpg
jfxavier is offline   Reply With Quote
Old 12th November 2014, 23:49   #20
jfxavier's Avatar
Update:
The micro speaker was removed from the card.
Could not find a replacement in my place.
Got one of the speaker re-winding specialist to re-wind the coil.
The diaphragm is special and was not available & was replaced by a normal one.
Now the sound is ok, but the volume is low.
Anyone who knows where I can get a micro speaker of 100 ohms and 0.5 W power, please advise.
At least the sound is back, now the search is for a replacement.
Old 13th November 2014, 20:39   #21
Thanked: 2,072 Times
Can't you get just this speaker from abroad?
Old cellphone speakers?
Sutripta
Old 13th November 2014, 20:47   #22
jfxavier's Avatar
Sutripta
I am looking at the various options as to how I can get the speaker.
The cell phone speakers are about 0.1W I believe, and I am looking for at least 0.5W.
Have seen a few options on the net, but since I am going to be at Singapore next month, I am procrastinating.
At least the problem is solved, some people say now the alarms sound better since the volume is low.
Thanks to the paper diaphragm instead of the original Mylar one.
Old 10th December 2014, 15:35   #23
jfxavier's Avatar
Latest update:
Volvo has informed me today after a detailed discussion on their end, they have decided to replace the DIM free of cost. I had taken it up with the management of Volvo Cars India.
This is befitting the standard that I wish to see from a responsible manufacturer.
jfxavier is offline   (3) Thanks Reply With Quote
Old 12th December 2014, 10:15   #24
Thanked: 9,723 Times
Default Re: Volvo S60 instrument console failed. Repair or replace? Volvo to replace under Goodwil
THats very good to hear. Have updated title to reflect this. Please confirm when done
ajmat is offline   (1) Thanks Reply With Quote
Old 12th December 2014, 19:54   #25
Great! And there I was thinking Chinese companies honour warranties, let alone goodwill ones, only as long as their products have not left their premises!
Sutripta
Old 12th December 2014, 20:02   #26
jfxavier's Avatar
Thanks. Will do.
Sutripta
I think Volvo is as much Chinese as JLR is Indian.
Old 13th January 2015, 10:49   #27
jfxavier's Avatar
Smile Re: Volvo S60 instrument console failed. Repair or replace? Volvo to replace under Goodwil
Had the DIM renewed yesterday at Kochi Volvo ASS.
I had to go to Kochi for some work and hence took the opportunity.
Kochi Volvo had informed me about two weeks ago that the DIM had arrived, but i was out of station and hence the delay.
Also, had to replace the brake pads as they were found to be close to limit during last service.
Like I mentioned in the earlier post, Volvo replaced the DIM at their expense.
Very pleased with the outcome.
Checked and can confirm all alarms are loud and clear.
They have transferred the odometer readings and all user defined settings onto the new DIM and hence there is no difference practically except the loud alarm sound.
Hero Karizma ZMR - Fuel pump failed. Rs. 12,000 to replace! sam_sant2005 Motorbikes 36 27th April 2015 11:13
Odometer / Instrument Cluster Repair? Palio_2005 Technical Stuff 21 1st November 2014 04:43
Volvo S60 & XC60 : Cheaper variants. EDIT : S60 now starts at 23.90 lakh & D3 engine .anshuman The Indian Car Scene 74 16th August 2014 21:53
Palio goes to Wasan for wiper repair. Ends up with a failed aircon amit Technical Stuff 14 31st May 2008 10:12
