Old 16th November 2014, 17:59   #16
Thanked: 8,994 Times
Default Re: Heat Sink for the engine oil filter?
Most of the above discussion is in my opinion not relevant unless we answer this very simple question first:
Does the oil need cooling?
If the answer is no, there is no reason to add these contraptions, other then they might look cool to some. Good enough, I've added any number of bits of pieces to my cars to make them look cooler/smaller over the years.
If the oil needs cooling, my first question would be why? There is something seriously wrong with the engine design. If it does need cooling I would rate this gadget next to useless. Google "how to design an oil cooler" and you will find quickly that it takes a bit more then this gadget.
Jeroen
Jeroen is online now   Reply With Quote
Laptop performance enhancement by cleaning air cooled network (Heat sink) dharmeshmahajan Gadgets, Computers & Software 15 26th May 2013 00:37
Alto's engine oil filter mounting came off! Gansan Technical Stuff 9 26th December 2009 08:49
Oil filter can cause engine knock? kikuma25 Technical Stuff 17 12th April 2009 13:11
Is Oil filter and Fuel filter different? finneyp Technical Stuff 10 25th July 2008 11:45
