Thread Tools
Old 4th August 2006, 21:01   #1 (permalink)
Angry Gash in Tyre at the edge of the tread...safe or trash the tyre ?
Hi folks....
long time...I've been busy....work...also been holidaying in Manali/Kasol and then visiting Bombay to spend some time with my fiancee.
Anyway...I have a bit of a problem .... I was at the bank today and while reversing my right rear tyre got a small gash in it by a piece of iron.
the gash is a couple of mm deep and so far no air has leaked out as far as I can tell...
I've taken a pic of it :
Now, is the tyre safe to use or should I just suck it up and relegate this to use as a spare and only use my other 4 tyres...
cheers
zaphod
in case anyone wants to know, the tyre's a Michelin MXF Sport 195/60R14...
__________________
Six Hamburgers and Scotch all Night,
A drive in a Mustang just to put me right
zaphod is offline   Reply With Quote
Old 6th August 2006, 18:14   #2 (permalink)
Originally Posted by zaphod
Hi folks....
A 2mm deep cut should not really matter, if your tyre is new, which means the actual tyre depth should be around 8mm. A 2mm cut means you still have 6mm of tread and about 6mm of rubber between the tarmac and the steel cords.
12mm of rubber is quite a safe position and should not offer any trouble in your city running. Suggest that you shift it to spare wheel when you are on the highway doing high speeds for a considerable lenght of time, just to breathe easy.
So long....
varunroy is offline   Reply With Quote
Old 7th August 2006, 09:46   #3 (permalink)
Why take a chance? Use it as the spare, and use the spare in its place for regular use.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 7th August 2006, 11:08   #4 (permalink)
condor's Avatar
If a tyre is kept as a permanent spare, it is still going to age [chemically] and degrade.
IMO, might as well use it, atleast in city, by using all five tyres in the rotation.
Old 30th August 2006, 18:23   #5 (permalink)
Life just gets better...doesn't it...
2 weeks ago... had to pick up my fiancee from the airport.
Got in and drove off. climb the dnd and as I cross the tollplaza I hear a faint thumpingt sound over the stereo...
I get out and damn...tyre's cut and dead.....
and teh spare tyre ? it's fine but somehow the tread at one place has been cut :( minor but annoying.
- It was in fact the first puncture my car suffered in the year and a half since i bought it ... and it had to ruin my tyre....
...and then had to change the tyre in the rain
...and found that one of the bolts was stripped so had to drive off with 3 fitted
...and met an angry fiancee at the airport
So i went to BK Tyres in Lajpat Nagar , spoke to Atul (?)
yep, the tyres dead but at least teh other 4 are fine according to him.
unfortunately the MXF SPort is not available that easily and he says that it's unlikely he'll be able t find one in 195/60 - 185's are available but that doesnt really help me.
/me is very very pissed.
__________________
Old 30th August 2006, 18:53   #6 (permalink)
Shan2nu's Avatar
I had a gash on one of the S322s on the Vtec, used it normally till i upgraded to GIIIs. Nothing happened.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 30th August 2006, 19:39   #7 (permalink)
iraghava's Avatar
If it's simply one tyre you want why don't you just get a good condition (mildly-used) tyre & keep it as a spare. One it will save you a lot of money & two it will still do the job. If you buy all 5 new + alloys it's gonna be expensive. And yeah the MXF's have been discontinued by Michelin & have been replaced by the new Pilot Precada's.
P.S. If you need help finding a good-condition used tyre in your size i.e. 196/60 PM/Call me I have some tyre dealer friends who might be able to help you out!
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 30th August 2006, 19:53   #8 (permalink)
condor's Avatar
Suggest you use the four currently good tyres as your regular set, and rotate these only.
Get a spare tyre, if possible used, and keep that only as a spare. You already have Ishan offering help for that. If you have a flat, use the spare, but swap back to the original tyre asap.
You can get a full set of 5 tyres when you replace your tyres next.
Old 31st August 2006, 13:24   #9 (permalink)
Thanks for the advice folks - I won't be replacing the whole set - that was just the regret of going in for 14" not 15" I 'll look for a MXF Sport in the same size, if i cant find that, I'll just get a used tyre in the same size and use it as a spare as you guys are saying.
Thanks Ishaan, It would be great if you could find out about the MXF Sport or else any other tyre for use as a spare in 195/60R14. I'll be back in Delhi in Mid september and would probably change the tyre then. I'll also be going to BKTyres/Tyres Shoppe then.
cheers
zaphod
__________________
Thread Tools
Puncture (tubed tyre) and tyre type/age rex_varghese Tyre & Alloy wheel Section 2 13th November 2007 19:19
Stones in tyre tread gopinathann Tyre & Alloy wheel Section 5 8th July 2007 22:40
Help: one rupee tyre test and tyre sizes amit Tyre & Alloy wheel Section 14 22nd October 2006 08:18
paint-safe adhesive for door edge guard? condor Modifications & Accessories 0 13th August 2006 19:39
tyre up, tyre down? Captain Pings Shifting gears 12 7th July 2006 19:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
