Old 6th August 2006, 19:31   #1
ajinkya's Avatar
Default No camber to avoid wandering?
Something has been bothering me for some time now:
A couple of weeks ago, on a news channel, they were telling people about how one can maintain one's car(s) well, and they said that the wheels should be exactly perpendicular to the road and have absolutely no camber, to avoid wandering.
Is this true?
Please shed some light...
ajinkya is offline   Reply With Quote
Old 6th August 2006, 20:44   #2
Shan2nu's Avatar
Thanked: 87 Times
While camber reduces contact area, i don't think it should affect straight line stability that much.
As long as both front tyres have the same toe angles, the car shouldn't wander. Toe-in is preffered for straight line stability while toe-out is prefered for cornering stability.
On an Oval track, you can use toe-in on one tyre and toe-out on the other (depending on which way the track turns). Usually seen on Indy cars.
Shan2nu
Camber Adjustment query & Camber Adjusting Bolts? hell_rider Technical Stuff 18 2nd January 2009 22:43
Perplexed with camber readings swathyd Technical Stuff 12 23rd June 2008 21:47
Inward Camber for rear wheels of 3 wheelers PVS Technical Stuff 6 1st April 2008 21:23
Negetive Camber in Rear Wheels: Indica extreme_torque Technical Stuff 4 12th December 2006 20:39
Help With Camber / Castor readings moralfibre Technical Stuff 7 22nd October 2005 10:34
