Old 10th August 2006, 15:03   #16
Thanked: 57 Times
THanks all of U guys for Ur input. And I can always rely on my buddy Samurai :-)
Puffdamgcdragon is offline   Reply With Quote
Old 10th August 2006, 15:13   #17
Samurai's Avatar
Thanked: 15,766 Times
Hey Thanks, but I didn't do anything more than others.
My suspicion was right, you are using too much brakes instead of engine braking. Other than wearing it out faster, the brakes will also get hot and become less effective. Therefore start using engine braking my friend. Here is a thumb rule, if you use 2nd gear while climbing an incline, use 2nd or 3rd gear while coming down the same incline. Same gear or one higher. Since Gangtok roads are full of closely placed hairpin turns, you will rarely get to drive above 3rd gear. Any higher gear on the declines, you won't get engine braking.
Old 11th August 2006, 13:19   #18
Thanked: 57 Times
Domo Arrigato, Senseii!
What is Brake bleeding???? fiery enzyme Technical Stuff 21 8th July 2013 12:03
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
DIY Gravity Brake Bleeding honeybee DIY - Do it yourself 12 13th October 2011 15:00
Rear Pads Worn Out Faster Than Front Pads! How is this possible? Tripod Technical Stuff 13 29th April 2009 22:16
