Old 30th January 2015, 11:32   #16
HimuraKenshin's Avatar
Thanked: 183 Times
Default Re: VW Vento: Contaminated MAF sensor
Originally Posted by jethari View Post
There is no tubing between the filter housing and the throttle. ...
I dont quite agree with SHOULD NOT spray any cleaners into the intake manifold. The STP carb cleaner is a water based cleaner that breaks up the carbon deposit (soot) in the tubings and helps vapourize it.
Hari
My mistake, there is a tubing before the air filter. This goes to the front of the car, near the grill.
The MAF sensor should be in this part..
STP the company name stands for Scientifically Treated Petroleum. All the carb cleaners i have used including ones form STP are solvent based.
but, i may be wrong, if some new product has been relased.. please share the details..
Ive sprayed a fine mist of water in old carbureted cars for cleaning the engine while running(old trick)
But this should not be used in EFI engines which have a plathora of sensors..
HimuraKenshin is offline   Reply With Quote
Old 30th January 2015, 11:58   #17
jethari's Avatar
Thanked: 17 Times
There is nothing on the ducting between the grill and air filter housing. I have a feeling they have located the MAF sensor remotely with a suction pipe.
The carb cleaner can be found at http://www.ebay.in/itm/261695415253?...84.m1423.l2649
Hari
jethari is offline   Reply With Quote
DIY : Cleaning your MAF Sensor for Rs 120 ajmat DIY - Do it yourself 84 13th July 2018 16:08
How do you deal with water contaminated petrol on highways Sudipto-S-Team Technical Stuff 19 31st July 2016 21:31
Is Cleaning the MAF Sensor A Good Idea ? Bomi Technical Stuff 8 6th July 2013 12:33
Fiat Linea or VW Vento--Vento Finalized ! mailmaldi Sedans 58 15th March 2011 13:26
Cam Sensor-Crank Sensor-TDC Sensor. Are They The Same Thing? genesis Technical Stuff 8 5th October 2009 11:17
