Old 15th January 2015, 15:05   #16
ilangop's Avatar
Thanked: 591 Times
Default Re: My Premier 118NE Journey: Mechanical restoration in process
Originally Posted by bikertillidie View Post
A faulty master cylinder was suspected. A trip to Nanapeth proved futile as no one seemed to have a TVS Girling tandem master cylinder & the vacuum servo unit in stock. Promises such as "doh deen ke baad confirm karenge" etc were being made by the sellers.
Had the same problem in my 118NE. Was lucky to find a brand new brake booster and Tandem Master Cylinder (TMC) at Kalpana Motors, Nanapet. Was a little expensive though. Replaced the rear wheel cylinders at the same time. Now the brakes grab like in a new car.
Could you post a picture of your new foglamps?
ilangop is offline   Reply With Quote
Old 15th January 2015, 15:43   #17
bikertillidie's Avatar
Thanked: 764 Times
Hi ilangop,
The fog lamps on my car are not new. I have merely replaced the wiring and one fused bulb.
Will post photographs tomorrow !
bikertillidie is offline   (1) Thanks Reply With Quote
Old 16th January 2015, 23:23   #18
Thanked: 764 Times
Hi ilangop,
Here's a picture of my NE with the fog lamps switched on.
Updates as of 16-Jan -
The sway bar bushes at the front have been replaced. One of the studs had to be replaced because of the jammed nut. Wish I had a nut splitter handy.
Other pics -
  • The Sound Boss head unit.
  • And the damaged bushes ...
My Premier 118NE Journey: Mechanical restoration in process-dsc_0077.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0079.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0080.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0083.jpg
Old 17th January 2015, 01:08   #19
Thanked: 1,052 Times
Infractions: 0/1 (9)
Congratulations on owning a very good example of a very good car.
Spares are getting quite hard to find these days. The nature of the car scrap trade makes it very unorganized, and spares difficult to locate.
It would be great if these scrapyard owners could list their products on a portal like snapdeal or ebay, and thus make the process of maintaining the vehicle simpler.
Nissan1180 is offline   (1) Thanks Reply With Quote
Old 17th January 2015, 01:19   #20
FINTAIL's Avatar
Thanked: 1,116 Times
Hi
How much did the HU cost? The Delight has a hole inside the glovebox- i.e open the glovebox lid, and there'll be a cavity inside. Now, this cavity has been cut thru. , and a small rectangular looking jagged cut is evident, with cut wires on the other end, signifying that a radio once existed there.
Of course, the radio would've gone before 1984. So- I'm hunting for something to fill up that gap. 31 years on.......
More importantly- How did the Missus accept the car?
You still in IIT BTW? I needed some assistance pertinent to the IIT's, and was wondering if you could assist slightly?
FINTAIL is offline   (1) Thanks Reply With Quote
Old 17th January 2015, 07:59   #21
Thanked: 764 Times
FINTAIL, the HU was priced at the princely sum of Rs 744 inclusive of all charges.
Mrs. is yet to accept the car but some compromises were made.
bikertillidie is offline   Reply With Quote
Old 19th January 2015, 00:00   #22
Thanked: 764 Times
Updates as of 18-Jan -
Plenty of progress was made over the weekend.
The handbrake cable was changed. The previous cable had rusted solid owing to disuse and even liberal application of penetrating oil failed.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0087.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0090.jpg
The rubber channels holding the rear quarter glasses was allowing ingress of water and had to be changed.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0086.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0085.jpg
I always felt that the brakes lacked bite (despite changing the booster and TMC assembly). It was found that that the rear drum brakes were not doing their job. Hence, the wheel cylinder kits were replaced. The brakes feel like new !!
My Premier 118NE Journey: Mechanical restoration in process-dsc_0093.jpg
Valve clearances were set to 0.25 mm under cold condition. The inlet valves were too tight in cylinder 1 & 4.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0105.jpg
The instrument console was repaired. A few dysfunctional LED indicators and the clock now work.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0109.jpg
Re-checked the compression this morning. There is a healthy improvement. Reset the C/B point gap & the ignition timing.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0113.jpg
The plumbing for the AC was checked for leaks and compressor oil was added. This was followed by introduction of approximately 450g of R134a refrigerant. The interiors felt really cool within a few minutes of powering on the AC. The chap was all praise for the Sanden compressor unit though I didn't quite understand why.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0115.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0110.jpg
I have found a donor 118 NE destined for the scrapyard which I intend to cannibalize for parts/trim. Discussions with the owner are on.
Here are a few of my tools. This is indeed a Sunday morning really well-spent
Took the car for a longish drive down Solapur Road. The engine is a real gem. It was absolutely soundless and I touched 100 kph on a rather desolate stretch. The car felt capable of doing at least 25-30 kph more.
The ball joints on the tie rod were greased up en-route. Later, the car was cleaned up thoroughly.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0108.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0118-copy.jpg
Signing off for now.
bikertillidie is offline   (2) Thanks Reply With Quote
Old 19th January 2015, 15:13   #23
Thanked: 764 Times
Updates as of 19-Jan -
The damaged panhard bar on my car was swapped with one from the donor NE.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0122.jpg
The same approach was followed for the left disc rotor after due clean-up and repacking the existing bearings with grease (as opposed to inserting a helicoil)
My Premier 118NE Journey: Mechanical restoration in process-dsc_0123.jpg
A new set of pedal rubbers.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0124.jpg
The water in the radiator and galleries was drained out and coolant was added.
The only thing pending diagnosis is the source of the screeching noise. I suspect the pillow block bearing but might be mistaken. Its intermittent nature makes it all the more difficult to troubleshoot.
Old 19th January 2015, 15:51   #24
ilangop's Avatar
Thanked: 591 Times
Attachment 1330601
Are these pedal rubbers of Maruti 800?
Old 19th January 2015, 16:05   #25
Thanked: 764 Times
Could be, I am not sure.
But fits equally well.
Old 26th January 2015, 23:33   #26
Thanked: 764 Times
Updates as of 24-Jan -
Decided to get the petrol tank & the fuel filter cleaned up. The filter was cleaned up by blowing compressed air in reverse direction.
The tank was removed from the car, the sender unit was removed and the entire unit was cleaned. A leaky float was also replaced during the process.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0131.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0133.jpg
Later, the pillow block assembly and one UJ cross was replaced. The pillow block bearing was badly worn. Fitting the new pillow block was really easy. The smaller shaft was held in a vice and the pillow block assembly was slid in using two fingers. The flange meant for holding the UJ cross was slid in (ensuring correct phase) and the locking nut was tightened. The new UJ cross was then fitted.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0135.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0137.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0140.jpg
A test drive revealed major problems. Significant propeller shaft vibration was observed as soon as the car touched 50 kph.
Updates as of 26-Jan -
The propeller shaft was removed from the car and checked for true-ness at Riaz bhai's workshop at Gadital. Apart from marks left by the vice, nothing untoward was observed.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0145.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0148.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0151.jpg
Then we noticed that there was considerable space between the bearing cups and the retainer rings. Apparently, the UJ crosses were seated loosely and this seemed to be a likely cause.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0146.jpg
Shim washers were fabricated and inserted between the retainer rings and the bearing cups to ensure a snug fit.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0152.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0153.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0155.jpg
A quick test drive revealed no vibrations up to speeds of 80 kph. More thorough tests planned for later.
Old 27th January 2015, 10:29   #27
Thanked: 764 Times
Updates as of 27-Jan -
Noticed vibrations creeping in after crossing 85 kph. Will check the shims once again, will add a few more if needed.
The screeching noise has disappeared.
I suspect it was caused due to the loose & worn UJ cross.
Old 10th February 2015, 13:36   #28
Thanked: 764 Times
Updates as of 09-Feb-15 -
Posting updates which were long due.
(a) All three UJ crosses on the prop shaft have been replaced. The current ones do not have greasing nipples and didn't require shim washers for a tight fit.
Lesson learnt - Using correct parts can save a lot of heart-burn & effort.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0160.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0161.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0163.jpg
(b) Both engine & gear-box mounts were replaced. Earlier ones had degraded a lot and vibrations were creeping in.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0164.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0165.jpg
(c) Front & rear bumpers were straightened and sprayed with matt black paint. In fact, there was zero gap between the front bumper and the car body. As a result, it had scraped and damaged the paint. The co-passenger door at the front was also repaired & sprayed as there were a long gash which ran across the length of the door.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0173.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0175.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0176.jpg
(d) Both rear tyres & the spare were badly worn. In fact, the car used to slither sideways while negotiating turns on gravel/sandy surfaces at 10 km per hour. The spare wheel rim was also badly corroded & warped at a few places.
I had managed to source a spare wheel rim in reasonably good condition from one of my sources.
Finally managed to procure three new 5.60 x 13 cross-ply tyres (including tubes) from a local JK Tyre dealer and had them fitted.
Shall post pictures later.
To do
  • Attend to a rattling front door over the weekend
  • Pay more attention to my Premier Padmini. The battery needs a recharge owing to a long period of disuse.
bikertillidie is offline   (4) Thanks Reply With Quote
Old 14th February 2015, 12:03   #29
Thanked: 764 Times
Photos of the tyres.
My Premier 118NE Journey: Mechanical restoration in process-1423895598007.jpg
Old 14th February 2015, 12:07   #30
Thanked: 764 Times
The rattle being attended to..
My Premier 118NE Journey: Mechanical restoration in process-1423895822856.jpg
Fiat Palio S10 - Now, Restoration Complete! lucifer919 Technical Stuff 112 12th September 2017 00:59
DIY ECU : Megasquirting the Premier 118NE ilangop DIY - Do it yourself 75 15th April 2016 02:50
Premier 118NE 'VICEROY' - A RARE variant of 118NE. funkykar The Indian Car Scene 140 17th May 2014 21:46
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
