Old 13th October 2015, 08:49   #76
bikertillidie's Avatar
Thanked: 585 Times
Default Re: My Premier 118NE Journey: Mechanical restoration in process
Hi Ilango,
Thanks.
The rubber tubes tend to develop cracks quite easily hence we got them replaced with reinforced plastic hoses.
Work on the car is on hold at moment and will resume in November.
bikertillidie is offline   (1) Thanks Reply With Quote
Old 27th November 2015, 13:07   #77
Thanked: 585 Times
A few more updates as of 26-Nov evening:
Fed up with repeatedly having to step out of my 118 NE every time the trunk needed to be opened up for inspection (at work, shopping malls etc), decided to incorporate remotely operated trunk & fuel lids.
The basic design was fellow team-bhp member ilangop's brainchild .
Here are a few pics taken during trial fitment.
The opening for the LPG tank inlet was patched up as kids from the neighbourhood kept fiddling with it. The inlet would be re-routed and should remain accessible from within the trunk.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0534.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0535.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0536.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0539.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0540.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0541.jpg
bikertillidie is offline   (2) Thanks Reply With Quote
Old 28th November 2015, 08:55   #78
ilangop's Avatar
Thanked: 577 Times
Originally Posted by bikertillidie View Post
[b]Fed up with repeatedly having to step out of my 118 NE every time the trunk needed to be opened up for inspection (at work, shopping malls etc), decided to incorporate remotely operated trunk & fuel lids.
That was the same reason why I had incorporated this & also reduce the no of keys in the key bunch. You will really feel relaxed that you don't have to get down at every check point to open the trunk. And thanks for acknowledging here.
Just a few question.
1) Which car cable have you used? Why is it cut and joined with a trunion. Instead you could have have made a longer L-plate for the base. Use a Nyloc nut for the latch lever pivot. Why is the anti-theft prong missing in the boot latch.
My Premier 118NE Journey: Mechanical restoration in process-trunk_mech.jpg
2) Which spring have you used for the fuel lid?
My Premier 118NE Journey: Mechanical restoration in process-fuel_lid.jpg
3) Could have located the levers little behind so that it doesn't come in the way during ingress & egress. Which car lever set is this?
How much did all parts cost you?
My Premier 118NE Journey: Mechanical restoration in process-leveronfloor.jpg
ilangop is offline   Reply With Quote
Old 28th November 2015, 10:23   #79
Thanked: 585 Times
The trunion makes it easy to compensate for slack.
The levers came off a scrapped Fiat Palio.
The springs were sourced from Nanapeth (there's a shop located bang opposite Pawar seat covers, which deals in springs of all shapes and sizes.
Sum total of all parts cost about 250 Rupees.
Old 28th November 2015, 10:25   #80
Thanked: 585 Times
Forgot to add, the cables are meant for a wagon R and costs extra.
Old 11th January 2016, 13:38   #81
Thanked: 585 Times
Updates as of 11-Jan-16
Thanks to inputs from Ilango (link - http://www.team-bhp.com/forum/indian...ml#post3888315 (The Premier 118 NE thread), I was able to make good progress with tidying up the wiring within the engine bay (in part due to some marathon sessions over the weekend of 9-Jan/10-Jan).
A few niggles still remain, which which would be worked on over the next couple of days.
Initial state -
My Premier 118NE Journey: Mechanical restoration in process-dsc_0438.jpg
The mess -
My Premier 118NE Journey: Mechanical restoration in process-dsc_0148.jpg
being sorted out bit by bit
My Premier 118NE Journey: Mechanical restoration in process-dsc_0149.jpg
Note: The bulky PMP relay has been replaced by a much more compact MINDA unit. The connections need to be tested i.e. whether high/low beams work properly, and may later be swapped in case of need. Hence, they have been left taped up for now.
The relay replacement freed up a lot of room on the right fender, which has been used to relocate the windshield washer reservoir.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0150.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0151.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0154.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0155.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0156.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0157.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0158.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0159.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0160.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0162.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0163.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0164.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0165.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0166.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0167.jpg
The engine bay light is yet to be hooked up to a power source...
My Premier 118NE Journey: Mechanical restoration in process-dsc_0168.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0169.jpg
The booster unit would be fitted today, followed by the radiator (and pulleys, fan and associated plumbing).
The plumbing for the air conditioner, condenser & drier bottle would be worked on once the car comes back after the paint job.
Old 11th January 2016, 21:19   #82
Thanked: 585 Times
And a few more pics from this evening ..
My Premier 118NE Journey: Mechanical restoration in process-dsc_0170.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0171.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0172.jpg
Old 14th January 2016, 14:00   #83
Thanked: 585 Times
Updates as of 14-Jan-16
The booster unit has been fitted.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0181.jpg
After a long hunt, the engine oil filler & radiator caps were finally located.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0182.jpg
Awaiting return of the air filter housing from the paint shop.
bikertillidie is offline   (3) Thanks Reply With Quote
Old 14th January 2016, 22:41   #84
Thanked: 585 Times
And the air filter housing is back...
My Premier 118NE Journey: Mechanical restoration in process-1452791481167.jpg
Old 30th January 2016, 22:25   #85
Thanked: 585 Times
Updates as of 30-Jan-16
The engine oil underwent a replacement.
The steering gearbox oil was also changed (EP 140).
My Premier 118NE Journey: Mechanical restoration in process-dsc_0189.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0191.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0192.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0193.jpg
And the engine was finally fired up. Aah, it was sheer music to my ears
My Premier 118NE Journey: Mechanical restoration in process-dsc_0196.jpg
The car was finally driven down to Javed's paint shop, where Firoz the denter attended to minor dents, cracks.
Silicone sealant was used wherever needed.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0220.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0221.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0222.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0225.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0226.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0227.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0229.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0230.jpg
The car is currently being stripped of all fittings and awaits attention from "Baba" the painter.
Hopefully, sometime next week ...
Old 5th February 2016, 15:42   #86
Thanked: 585 Times
More pics from yesterday -
My Premier 118NE Journey: Mechanical restoration in process-dsc_0238.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0239.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0236.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0235.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0233.jpg
bikertillidie is offline   Reply With Quote
Old 8th February 2016, 11:31   #87
Thanked: 585 Times
Updates as of 06-Feb-16 -
The body of the car is being sanded down and body filler applied wherever needed.
The trunk lid was scraped down to bare metal (using paint remover and some elbow grease).
My Premier 118NE Journey: Mechanical restoration in process-dsc_0250.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0249.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0248.jpg
Old 8th February 2016, 18:07   #88
KkVaidya's Avatar
Thanked: 253 Times
If trunk is scrapped down to bare metal, you better insist the bodyshop to apply anti-rust primer before paint primer. From the pictures, it seems the paint is not going to happen inside a booth. Which colour have you finalized?
KkVaidya is offline   (1) Thanks Reply With Quote
Old 9th February 2016, 23:31   #89
Thanked: 585 Times
Yes, we do intend to coat it with zinc chromate primer before starting off.
The vehicle is to be painted silver. The same shade has been used within the engine bay as well.
I find a paint booth too expensive and consider Javed's set-up/baba's skills good VFM...
Old 15th February 2016, 21:28   #90
Thanked: 585 Times
Updates as of 14th February -
My Premier 118NE Journey: Mechanical restoration in process-1455551769745.jpg
My Premier 118NE Journey: Mechanical restoration in process-1455551807864.jpg
My Premier 118NE Journey: Mechanical restoration in process-1455551827559.jpg
My Premier 118NE Journey: Mechanical restoration in process-1455551841274.jpg
My Premier 118NE Journey: Mechanical restoration in process-1455551863646.jpg
Fiat Palio S10 - Now, Restoration Complete! lucifer919 Technical Stuff 112 12th September 2017 00:59
DIY ECU : Megasquirting the Premier 118NE ilangop DIY - Do it yourself 75 15th April 2016 02:50
Premier 118NE 'VICEROY' - A RARE variant of 118NE. funkykar The Indian Car Scene 140 17th May 2014 21:46
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
