Old 18th February 2016, 11:31   #91
bikertillidie's Avatar
Thanked: 764 Times
Default Re: My Premier 118NE Journey: Mechanical restoration in process
Updates as of 17-Feb
The interiors of the car have been cleaned up.
Was planning to use some sound deadening material like "Dampomat" on the flooring but couldn't source it locally.
Used asphalt sheets instead (available at most hardware stores). In time, we will know whether it was a correct decision.
The door sills & insides of the doors have been painted.
The locks & door latches are being cleaned up and would be fitted soon.
Latest pics given below.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0259.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0258.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0263.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0264.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0265.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0266.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0269.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0272.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0273.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0274.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0271.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0270.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0268.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0267.jpg
bikertillidie is offline   (2) Thanks Reply With Quote
Old 18th February 2016, 18:08   #92
KkVaidya's Avatar
Thanked: 277 Times
The excitement is building up. Are you coating the floor with a rubber paint? That should help fight corrosion.
KkVaidya is offline   Reply With Quote
Old 18th February 2016, 23:26   #93
Thanked: 764 Times
Well, the underbody was given a coating of rubberised paint last year. Am not sure whether it's really required here ...
In all probability, I will settle for the same shade of silver as the exterior.
bikertillidie is offline   Reply With Quote
Old 19th February 2016, 00:31   #94
Thanked: 764 Times
A few pictures from today -
My Premier 118NE Journey: Mechanical restoration in process-1455822037099.jpg
My Premier 118NE Journey: Mechanical restoration in process-1455822050324.jpg
My Premier 118NE Journey: Mechanical restoration in process-1455822064408.jpg
Old 19th February 2016, 06:48   #95
Thanked: 20 Times
This is me with car no. 1641 bought from BCMA, Opera House.
but couldn't resist myself.
Was this photo taken at Shivaji Park?
Inner Voice is offline   (1) Thanks Reply With Quote
Old 22nd February 2016, 23:56   #96
Thanked: 764 Times
Updates as of 22-Feb -
Finally, the car has been painted.
Fitment of all trim commences tomorrow.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0278.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0279.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0284.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0285.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0286.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0287.jpg
Old 23rd February 2016, 22:21   #97
Thanked: 764 Times
A few more pics from today ..
My Premier 118NE Journey: Mechanical restoration in process-dsc_0289.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0290.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0293.jpg
bikertillidie is offline   (1) Thanks Reply With Quote
Old 23rd February 2016, 23:09   #98
ilangop's Avatar
Thanked: 591 Times
Wow. Reminds me of Premier 1.38D brochure pic. Remember seeing a silver color and a red color car
ilangop is offline   (1) Thanks Reply With Quote
Old 24th February 2016, 09:06   #99
greenhorn's Avatar
Thanked: 1,516 Times
if you are applying asphalt to the floorplan, might as well do it to the doors. - they'll close with a satisfying thud.
also have some thick felt to go on top, plus the wurth rubber paint for the underbody
Old 24th February 2016, 11:46   #100
KkVaidya's Avatar
Thanked: 277 Times
Are you planning to retain the LPG kit? Sincere request to omit if possible.
Old 25th February 2016, 08:54   #101
Thanked: 764 Times
The door panels are already lined with sound absorbent material. Besides, they have already been painted and any attempt to stick on asphalt sheets (via heating) would induce a great deal of rework.
I am planning to smear it with grease to serve as added rust protection.
Unfortunately, I do not have much of an option here ...
The RC book contains an endorsement to this effect and I don't want to fall foul of the authorities / run around unnecessarily to undo all of this.
A few more pics from yesterday -
A tragedy has occurred ... despite exercising the greatest of care, the wind shield has cracked during installation
My Premier 118NE Journey: Mechanical restoration in process-dsc_0299.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0301.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0300.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0297.jpg
Old 29th February 2016, 11:19   #102
Thanked: 764 Times
Updates as of 28-Feb-16 -
The NE is finally back home.
Tons of things still to be worked on -
  • Doors are not closing properly. Needs more work.
  • Driver side door glass winder broken. Needs a replacement (plus a new cable)
  • Indicators don't work
  • Reverse gear switch broken
  • Rear suspension
  • Polishing
  • just to name a few
My Premier 118NE Journey: Mechanical restoration in process-dsc_0307-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0308-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0309-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0310-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0311-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0312-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0313-copy.jpg
Old 12th March 2016, 15:56   #103
Thanked: 764 Times
Wheel rims are being painted silver, wheel wells are being painted black...
My Premier 118NE Journey: Mechanical restoration in process-1457778340999.jpg
My Premier 118NE Journey: Mechanical restoration in process-1457778362055.jpg
Old 28th March 2016, 11:24   #104
Thanked: 764 Times
Updates as of 27-Mar-16 -
Most of the niggles have now been sorted out ...
I' ll let the pictures do the talking.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0373-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0374-copy.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0372.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0379.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0376.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0371.jpg
bikertillidie is offline   (4) Thanks Reply With Quote
Old 30th March 2016, 13:21   #105
Thanked: 764 Times
In an attempt to clean up the wiring harness below the dashboard and mount two 4 inch speakers at the front of the car, project "dashboard removal" was undertaken last evening.
Shall share updates in due course ..
Tips for easy removal were supplied by fellow bhp-ian ilangop
My Premier 118NE Journey: Mechanical restoration in process-dsc_0382.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0383.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0384.jpg
Fiat Palio S10 - Now, Restoration Complete! lucifer919 Technical Stuff 112 12th September 2017 00:59
DIY ECU : Megasquirting the Premier 118NE ilangop DIY - Do it yourself 75 15th April 2016 02:50
Premier 118NE 'VICEROY' - A RARE variant of 118NE. funkykar The Indian Car Scene 140 17th May 2014 21:46
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
