Old 30th March 2016, 15:49   #106
ilangop's Avatar
Thanked: 591 Times
Default Re: My Premier 118NE Journey: Mechanical restoration in process
Originally Posted by bikertillidie View Post
In an attempt to clean up the wiring harness below the dashboard and mount two 4 inch speakers at the front of the car, project "dashboard removal" was undertaken last evening.
Shall share updates in due course ..
Tips for easy removal were supplied by fellow bhp-ian ilangop
Hi Anirban,
You can also remove the air distributor (the fibre piece with 4 vents) to gain access to the filter element in front of the evaporator (Cooling coil). In my case the filter was fully clogged and the AC mechanic got rid of it and the air flow is excellent.
The design flaw here is there is no filter at the suction side. You may take this opportunity to improvise a filtering method at the suction side.
While putting back the vents and other AC parts you can surround the hose couplings with a thin layer of sponge (No need to head for a rexin shop now. You can find one inside a brand new formal shirt packing). This way any air leak could be fixed. To me it appears like the factory fitted carpet material is good enough for thermal insulation. Just attend to a few places like the entry for the AC Aluminium pipes and near the pedal brackets. You may also think of extending a ground connection for the AC blower directly from the battery -ve itself.
ilangop is offline   (1) Thanks Reply With Quote
Old 1st April 2016, 15:01   #107
bikertillidie's Avatar
Thanked: 764 Times
Hi Ilango,
In my case, a few of the screws which held the air distributor in place were located at such an obtuse angle, that accessing them using a miniature screw driver proved impossible. Hence, I had to pass up the opportunity.
Thankfully, the air flow seems adequate.
Fitting a filter at the suction end seems a bit difficult. It would have meant removal of the entire AC unit. I' ll try to figure out a way to do something about it later, hopefully, which would render filter replacement a relatively easier process.
Thankfully, it was not required as all openings in the firewall through which the plumbing passed were sealed off with rubber grommets/appeared well insulated.
BTW, I managed to fit everything together starting early morning today (yesterday evening was devoted to watching the India vs WI cricket match).
My Premier 118NE Journey: Mechanical restoration in process-dsc_0387.jpgMy Premier 118NE Journey: Mechanical restoration in process-dsc_0386.jpgMy Premier 118NE Journey: Mechanical restoration in process-dsc_0385.jpg
The 4 inch speakers have also been fitted.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0390.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0394.jpg
My Premier 118NE Journey: Mechanical restoration in process-dsc_0389.jpg
The undersides of the bonnet have also been lined with heatlon sheeting.
My Premier 118NE Journey: Mechanical restoration in process-dsc_0393.jpg
bikertillidie is offline   Reply With Quote
Old 1st April 2016, 18:21   #108
KkVaidya's Avatar
Thanked: 277 Times
What is the purpose of fitting heatlon sheets on the bonnet? I doubt they would help in any significant sound deadening. And the NISSAN A12 is already a silent powerplant except the retrofitted radiator fan.
KkVaidya is offline   Reply With Quote
Old 1st April 2016, 18:34   #109
Thanked: 764 Times
The intent is to make the car "super silent" and secondly, to prevent the silicone body filler and paint underneath the bonnet from flaking off.
Old 13th April 2017, 20:07   #110
Thanked: 982 Times
What is the model number of the MIKUNI Carburretor which came in 118NE??
ajay99 is offline   Reply With Quote
Old 11th July 2017, 12:15   #111
pranavGTI's Avatar
Thanked: 42 Times
Sir, your car looks super good. Kudos to all restoration that you've done . I saw the cybercity sticker on your car. If you work inside Magarpatta city, i'd be happy to meet up with you and see your NE118 as I do come to Magarpatta city for work.
I'm sorry that I couldn't PM you, so this message.
Thanks,
pranavGTI is offline   (1) Thanks Reply With Quote
Old 11th July 2017, 12:48   #112
Thanked: 34 Times
Where did you source the rubber seals? I am after the seals for the door, bonnet and Boot.
autodoctor is offline   Reply With Quote
Old 12th July 2017, 21:24   #113
Thanked: 764 Times
Thanks,
Hi Pranav,
Yes, my organization has offices in Magarpatta. We can certainly meet up one of these days.
Autodoctor,
The seals used to be available at Kalpana Motors, Nanapeth.
In case these are not available readily, they can source it on your behalf.
Old 12th July 2017, 21:31   #114
Thanked: 34 Times
Thank you.i will try them.
I am based in Kerala. Any one here knows reliable shop to get 118ne parts?
Old 8th September 2017, 12:14   #115
Thanked: 764 Times
Per an old UCAL catalogue, the part number is
24-30DIDS-200
Fiat Palio S10 - Now, Restoration Complete! lucifer919 Technical Stuff 112 12th September 2017 00:59
DIY ECU : Megasquirting the Premier 118NE ilangop DIY - Do it yourself 75 15th April 2016 02:50
Premier 118NE 'VICEROY' - A RARE variant of 118NE. funkykar The Indian Car Scene 140 17th May 2014 21:46
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
