Old 14th January 2015, 09:26   #1
Thanked: 168 Times
Default Engine Shuddering Issue
My family's CNG converted Hyundai Getz has been having some issues lately. Since about three weeks ago, the car sometimes shudders while driving, especially on sudden acceleration. (Feels as if the engine is being deprived of fuel or spark).
The issue appears irregularly, sometimes the car will run fine for days until it randomly starts shuddering/missing on acceleration. This happens on both CNG and petrol.
My dad got the car checked by a nearby garage, but the issue wasn't apparent when they test drove the car. They suggested just cleaning the throttle body. As we had planned a 300km trip that weekend and the issue had seemingly disappeared we decided to get this done when we got back. The car mostly ran fine during the trip.
Today, the car again started violently shuddering on acceleration. After a while there was a high pitched scraping sort of sound which we noticed at slow speed, but we could not detect it when we stopped the car to check under the hood.
Although we will be getting the throttle body cleaning done as soon as possible, I doubt that this is the cause of the issue. I had originally thought it could be an electronic issue such as a faulty throttle position sensor or crank position sensor; but now the sound seems to suggest a mechanical problem. Anybody have any experience with a similar issue?
RandomUsername is offline   Reply With Quote
Old 14th January 2015, 12:20   #2
Jaggu's Avatar
Thanked: 8,692 Times
Default Re: Engine Shuddering Issue
Shuddering can be either due to bad fueling or bad electrical. Now since the issue happens both on CNG and Petrol, i would first check for issues in electrical circuit. Start with the plugs, then coil pack and wires. I would suggest you take it to a authorized garage for hyundai, they will be able to identify such issues faster.
Ideally use Petrol mode to trouble shoot since it would be straight forward.
EDIT: Does this happen only when the engine is fully warmed up OR happens even during cold conditions?
Jaggu is online now   (1) Thanks Reply With Quote
Old 14th January 2015, 12:29   #3
SS-Traveller's Avatar
Thanked: 11,630 Times
Try taking the car on another long drive while running on petrol only (not on CNG), with a dose of 1ml/litre System-G or similar, mixed with the petrol. I suspect an injector issue due to extended running on CNG.
...high pitched scraping sort of sound ...
May be unrelated to the shuddering problem - check fan belts.
SS-Traveller is offline   (1) Thanks Reply With Quote
Old 14th January 2015, 13:09   #4
patron's Avatar
Thanked: 116 Times
This is usually a result of bad coils. Get them checked and replaced.
patron is offline   (1) Thanks Reply With Quote
Old 14th January 2015, 14:26   #5
Thanked: 8,989 Times
Any warning lights, or CEL (check engine light) showing on the dash?
Even without warning ligjhts, get your car/engine hooked up to a proper OBD analyser to try and figure out what is going out. Preferably one that can do live measurements as well.
Could be anything but going by the little we know I would think electrical (maybe coil as suggested). Injector maybe, although I would think that would pop the CEL pretty quickly.
I doubt it is the throttlebody. If cleaning is the remedy there should be visual evidence of it being contaminated in the first place.
Jeroen
Jeroen is online now   (1) Thanks Reply With Quote
Old 19th January 2015, 10:57   #6
Thanked: 168 Times
An update on the issue: the problem turned out to be a loose connector to one of the sensors (probably the crank position sensor).
We also got the timing belt, the alternator belt, and the belt tensioner pulley bearing replaced, so hopefully even the scraping noise issue has been solved.
Old 19th January 2015, 15:41   #7
If you would have hooked up to an OBD analyzer it would have shown which connector. I don't understand replacing all these parts in one go. Its very unlikely that all three of them were producing a scraping sound. I would have tried to troubleshoot a bit further. Look for obvious signs of something touching. Use a stethoscope to find the culprit. Maybe change the parts one by one.
Jeroen
Old 19th January 2015, 19:17   #8
Thanked: 14,608 Times
Spot-on Jeroen.
Rather than changing everything at a go blindly without knowing the root cause is like shooting arrows in dark.
What if the issue repeats, no one would know the real reason as all the said parts were changed at a go!
Jeroen
a4anurag is online now   Reply With Quote
Shuddering/Vibrations while braking! Need help! asethi Technical Stuff 76 17th February 2013 18:16
Shuddering of wipers in my Ford Fiesta ghodlur Technical Stuff 32 13th September 2010 00:00
Shuddering on Civic surfatwork Technical Stuff 18 9th February 2009 22:56
