Old 14th August 2006, 06:56   #1
mithun's Avatar
Thanked: 58 Times
Smile Brand New Engine for M800/Omni for Rs.10,000 !!!
When I went to the Maruti Dealership, I've seen a banner about full engine replacement for M800/Omni for Rs.10,000 + Labour Charges. When I inquired more, they told me that the whole engine will be replaced and the engine will be brought back to the showroom condition.
Is it a better a option for those who are on a shoestring budget and don't want to part with their good old M800/Omni ?
Although I know that money should also be spent on suspension etc...
Team-BHP-ians opinions are welcome....
Old 14th August 2006, 08:17   #2
DCEite's Avatar
Thanked: 607 Times
Can i fit this MPFI engine (i suppose) onto my Carb M800?
DCEite is offline   Reply With Quote
Old 14th August 2006, 09:00   #3
viper's Avatar
Thanked: 9 Times
This scheme was being offered in Mumbai approx 2 years ago as well, do not know if it still is. You are basically going to get just the head and the block not the wiring, sensors, ecu etc, etc.
@Mithun - If your engine is not in a good shape and needs overhaul then this is a very good option since you are getting a fresh block. 100% recommended.
Viper
viper is offline   Reply With Quote
Old 14th August 2006, 09:26   #4
moralfibre's Avatar
Thanked: 6,532 Times
Can someone find out if this scheme is available in Pune too?
Old 14th August 2006, 09:46   #5
Thanked: 10,997 Times
how does one sort out the RTO formalitieis re: engine change
Old 14th August 2006, 09:49   #6
viper's Avatar
Thanked: 9 Times
The old engine number is stamped on the block and the new one erased/smudged out. Very common practice used by all those doing engine swaps.
@ Moralfibre - Just call any maruti service centre and he will confirm. BTW are you not from Poona.
Viper
Old 14th August 2006, 10:31   #7
humyum's Avatar
Thanked: 2,502 Times
Originally Posted by viper
Viper
Yup as viper mentioned u get only the block,pistons,crankshafts,connecting rod.The valves+head remain the same.This is know as "Half Engine"in the service station terms.
Old 14th August 2006, 12:48   #8
esteem_lover's Avatar
Thanked: 451 Times
why not ?? why not, i say, if u r that senti about the old hag, keep her & have fun...good luck, pal
Old 14th August 2006, 14:08   #9
Hi friends,
Will tell you about my experience of engine overhaul on my 800 (travelled about 120k km. 1987 Japanese model). It used to give out black smoke from the exhaust / carbon deposit on spark plugs / sluggish pick up / engine oil vanishing from engine oil within 1 week of top up. We got it overhauled from MASS and after 6~7 days, we got the car back. After some do's and don'ts for few initial 2000 km, I started noticing that car's oil is still vanishing, but no smoke / no carbon deposit etc.
I would PERSONALLY recommend that you go for a NEW ENGINE BLOCK. I have personally seen this since 1999 in Delhi, but you will have to go to a BIG MASS WORKSHOP like COMPETENT MOTORS on Gurgaon/Mehrauli road. Price is same - Rs 10K + labour and it takes about 1~1.5 days for a change (i.e if they have the part readily available).
Thanks & regards
Passion4cars
Last edited by GTO : 17th August 2017 at 09:17. Reason: Old post, but removing SMS lingo
passion4cars is offline   Reply With Quote
Old 14th August 2006, 14:42   #10
DCEite's Avatar
Thanked: 607 Times
My question wasnt answered. Can my carb engine be replaced by MPFI engine under this scheme?
Old 14th August 2006, 14:45   #11
viper's Avatar
Thanked: 9 Times
Which part of my reply did you not understand. i think I clearly spelt it out to you. In simple english NO.
Viper
Old 14th August 2006, 15:09   #12
DCEite's Avatar
Thanked: 607 Times
Viper
Ok. Didnt read the head and block part properly.
Thanks for reply.
And i dont think this scheme is available in Delhi anyways..
Old 14th August 2006, 16:20   #13
Thanked: 451 Times
from what i know, the entire wiring needs to be replaced, if u opt for a mpfi engine..best thing to do would be to replace with the same type
Old 15th August 2006, 10:40   #14
mithun's Avatar
Thanked: 58 Times
Even after getting a fresh block, will it create any headcahe in the long run ?
Old 15th August 2006, 12:17   #15
sajo's Avatar
Thanked: 1,064 Times
Any idea how much a total engine swap will cost? (mine is a carb '92). Though the engine in mine is basically in good shape. But would love to swap it with the 4 valve engine which used to be available. (But,sadly, I think the total cost of the engine+new gearbox would exceed the cars entire resale value :().
sajo is offline   Reply With Quote
Engine Rebuilt 1997 model M800 at 1,93,000 km ambarshante Modifications & Accessories 15 7th May 2013 20:42
Incoming Euro IV takes first casualties - The M800 & Omni sgiitk The Indian Car Scene 60 16th October 2009 14:45
Nano effect? Maruti to phase out M800, Omni GeekSrik The Indian Car Scene 4 1st April 2009 17:53
Omni & M800 - A Comparative Study mithun The Indian Car Scene 26 8th May 2006 19:17
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
