Thread Tools
Old 6th April 2007, 03:13   #16 (permalink)
v1p3r's Avatar
Originally Posted by ananthkamath View Post
I thought it just needs a lathe, a calculator and a weighing scale. LOL just kidding.
Lathe? Calculator? Weighing scale? Just use a hacksaw and hack off whatever you don't like!
__________________
Singh is king?! He's a bloody baadshah!
v1p3r is online now   Reply With Quote
Old 6th April 2007, 08:34   #17 (permalink)
viper's Avatar
Lol,
And end up with a busted flywheel and clutch plate.
@ Manveet - Bro simple genuine advice. Avoid it you will be happier.
Viper
__________________
NO ONE DARES COME CLOSE
viper is offline   Reply With Quote
Old 6th April 2007, 08:59   #18 (permalink)
Harrie's Avatar
The flywheel has to be dynamically balanced. At 7000 rpm a 2 grams out of balance will be equal to 5 Kgs (Well not exactly but you get the picture... )
__________________
Its like turbo lag. But funny there isn't a turbo.
Harrie is offline   Reply With Quote
Old 6th April 2007, 09:31   #19 (permalink)
manveet's Avatar
Or perhaps one could drill a few holes here and there .. damn, where did i keep that drill machine of mine
jokes apart - the above info has helped, i may have a few more queries with which i'll probably get back later .. need to rush out now ..
p.s.
@viper - not planning to get it done - just trying to understand the funda.
__________________
Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
manveet is offline   Reply With Quote
Old 6th April 2007, 10:57   #20 (permalink)
Bass&Trouble's Avatar
Originally Posted by rishibravo View Post
Our car engine makes the least torque at idle and low RPM, especially when cold (when there are more misfires.).... So when you release your clutch a little too fast, the engine torque is too small to overcome the inertia of the car, and it stalls. Thats where the flywheel comes to action ...
I think getting a lighter flywheel is not advisable for city driving. But if you want to burn the track then you can go for it .Still you have to be careful when you are shedding some weight of the flywheel ,it should be just right
Very well explained. Are you a mechanical engineer or something?
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 6th April 2007, 11:20   #21 (permalink)
manson's Avatar
whatever you use, lathe, hacksaw, shaping, shearing, etc just buy one from me !!
manson.
__________________
Robin
manson is offline   Reply With Quote
Old 6th April 2007, 13:41   #22 (permalink)
k36
k36's Avatar
So it seems a heavy flywheel helps drivability in city traffic.
Would this help a car with weak low end torque? (e.g. Swift Petrol)
How about having a heavy city-specific flywheel and the OE flywheel for highway use? How difficult is it to attach and detach a flywheel?
__________________
k36
k36 is offline   Reply With Quote
Old 6th April 2007, 13:51   #23 (permalink)
rishibravo's Avatar
He He He....No not a mechanical Engineer but did a few Applied mechanics courses during my B-Tech days...And there goes my 100th post .
__________________
Boyz will remain Boyz.......Only their Toyz change
rishibravo is offline   Reply With Quote
Old 6th April 2007, 13:56   #24 (permalink)
rishibravo's Avatar
If you have your own garage then you can go for it . I would still say dont do it as it will be too much of a hastle.
__________________
Old 9th April 2007, 02:54   #25 (permalink)
nitroxx's Avatar
a lightened flywheel on an N.A. car would drop low end torque..but improve mid range so unless you've had a few mods done i wouldnt suggest a lightened one.
__________________
"Aerodynamics is for those who cannot manufacture good engines"
- Enzo Ferrari
nitroxx is offline   Reply With Quote
Old 30th May 2007, 14:16   #26 (permalink)
manveet's Avatar
So suppose one wants to lighten the bottom-end of the car .. say from crank to wheel - what all could be worked upon, apart from the flywheel?
I've also heard of Tuners replacing the OE Pulley with lighter Alloy ones - is this correct? How many such Pulleys are there?
Can someone explain using a few pics or provide a linky perhaps?
__________________
Old 30th May 2007, 17:35   #27 (permalink)
elf
elf's Avatar
Yes, what would the advantage of lightened pulleys be over a shaved flywheel?
elf is offline   Reply With Quote
Old 30th May 2007, 18:14   #28 (permalink)
manveet's Avatar
I could be wrong Elf, but I don't think that people get the pulleys replaced without lightening the flywheel as well. IMO, as per common sense the complete bottom-end should be done together as a system i.e. flywheel, pulleys etc.
p.s.
long time buddy .. missed you
__________________
Old 30th May 2007, 18:25   #29 (permalink)
elf
elf's Avatar
Originally Posted by manveet View Post
... I could be wrong Elf ...
You are. You always are. That's the basic tenet of life.
... but I don't think that people get the pulleys replaced without lightening the flywheel as well. IMO, as per common sense the complete bottom-end should be done together as a system i.e. flywheel, pulleys etc. ...
I've heard of people replacing only the pulleys directly without shaving the flywheel. Personally, I'd like to do so myself - less headache.
Besides, I like hairy, macho flywheels. They're so smooth.
... long time buddy .. missed you
Sniff. Sniff. Hug. Hug. Kiss. Kiss. Sob. I missed you too. What to do... I was (**ahem**) 'away' & 'unavailable' for a week.
Old 30th May 2007, 18:44   #30 (permalink)
sbasak's Avatar
The auto engine manufactures are doing these calculations every time they design an engine. There are several parameters involved. The flywheel mass and weight comes from an optimum use point of view. How big and small one can go requires detail calculation engine operations. However, following links should be useful understanding what can happen in general.
Lightweight Flywheel - Pros and Cons | Kapital Moto
Why (or Why Not) to Lighten Your Flywheel
Lightened Flywheels
__________________
Life is a math which you need to solve without knowing the answer!
sbasak is offline   Reply With Quote
Thread Tools
Diesel engine noise reduction - How? Rough Square Modifications & Accessories 18 29th August 2008 00:32
Noise Reduction in Ikon benbsb29 Modifications & Accessories 18 30th November 2006 18:45
primary reduction and secondary reduction devsus Motorbikes 4 19th April 2006 17:35
Flywheel vipul261 Technical Stuff 3 11th February 2006 05:31
Lightened flywheel& underdrive pulley on esteem anybody? Stage3Monster Modifications & Accessories 8 18th March 2005 19:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
