| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) | |
| BHPian | Quote:
__________________ Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? | |
| | #32 (permalink) |
| BHPian | I guess lot of people are aware of the game known as 'NFS - Porsche 2000 unleashed'. In this game one can modify the cars which you will be racing. One of the options to increase the acceleration as mentioned in the game is to put in a light fly-wheel. But it is also mentioned that the top speed is decreased. Though I am a mechanical engineer, i dont have knowledge on this. Any performance tuner here, who actually did such a modification can clarify this thing. |
| | #33 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| Reducing weight of the flywheel is not advisable at all for the following reasons - 1. Car manufacturers would have put in an optimal flywheel based on experience and stringent design parameters 2. Reducing the weight will make cruising much more difficult unless you are an expert on the accelerator hence you will have a fluctuating speed/RPM on highways which is not desirable. 3. With lighter flywheel there would be more gear changes when you need to negotiate city traffic. |
| | #34 (permalink) | ||||
| BHPian | I disagree duee to the following Reasons: - Quote:
__________________ Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? | ||||
| | #35 (permalink) | ||
| BHPian | Quote:
Personally, I would treat GranTurismo as a good reference and not NFS. If you've played the game - I'm sure you'll agree on that count. But like you rightly said - perhaps someone more knowledgeable can clarify.
| | #36 (permalink) |
| BANNED | Actually, going by my reasoning, a lightened flywheel may actually reduce the top speed marginally. A heavier flywheel stores more energy & has greater inertia due to it's relatively higher mass. FOR EXAMPLE: Lets say that your 5 speed, non-governed, 130bhp car has a top speed of 200 km/h, with your 5th gear being overdrive. It gets to 190 km/h quite quickly, but the 200 km/h top speed is only attainable on a long stretch in 4th. My guess is the last 10 km/h is achieved due to a combination of the energy stored in the inertia of the heavier stock flywheel & the final production of 'fresh' energy from your engine. If your flywheel was lightened, it's mass would be reduced & therefore it's capacity for stored energy would also be reduced due to the reduced inertia, thereby only allowing a top speed of say 193 km/h, as the last burst of 'fresh' energy from the engine would be used to attain that speed & not much 'reserve' would be available in the flywheel. This entire process would only be possible with petrol, diesel, or some sort of fuel. Cars don't run without fuel. |
| | #37 (permalink) |
| BHPian | As some of the bhpians have correctly identified, one of the basic purposes of the flywheel is to store energy while the pistons go through the combustion cycle (4 stroke in most cars). The lesser the number of cylinders, the more crucial the flywheel becomes to the smooth running of the engine. For example, in a single cylinder engine, when the piston is at the bottom dead center, it is the inertia offered by the flywheel that forces the piston to the top again. Without the flywheel, the piston may stall at the BDC. At the very least, this would lead to a very jerky engine. So, lightening the flywheel is very likely to reduce the balance of the engine, and increase vibrations (unless of course, you have a V16 like a Cizeta Moroder). From whatever I have read, reduction in vibration was the reason the flywheel was added to the piston engine in the first place. |
| | #38 (permalink) |
| BHPian | well ive done my research on flywheels actually made a project on it! im going to leave out the technical terms and try and explain the concept to those who still have some doubts. the flywheel basically smoothens out the power transmission, the power from the engine comes in the form of thrusts which are smoothened out by using a flywheel of calculated weight and diameter. any reduction in weight would cause this delivery of power from the engine to wheels become jerky ! and as rightly explained by others it would lead to faster drop in rpm!! as per top speed the heavier flywheel helps the car gain momentum in the form of inertial energy stored in the flywheel hence it should lead to a reduction in top speed but i think it would be marginal! the bigger disadvantage being the uneven power transmission!! @manveet, steady throttle does not translate to constant rpm! if there were no external forces acting on the car constant throtle would lead to constant acceleration (increase in rpm) but since there are lots of external forces acting on the car this does not hold true! the flywheel also reduces this acceleration and hence at constant throttle the rpm increases quite slowly!! |
| | #39 (permalink) |
| BHPian | hey this is nicked from newcelica.org by FITGT I used Excel and a BMW website that explained the math behind finding how much a lightweight flywheel helps you. I just redid for the celica info, and I have a rapidshare link. The numbers in red are the ones you can change. Enjoy RapidShare: 1-Click Webhosting Here is the BMW link. http://www.uucmotorwerks.com/flywhe...wheel_works.htm EDIT: FYI The gear ratios are for a GT, you can find the GTS from searching. I didnt know a light weight flywheel can freeup so much hp.
__________________ Ashes to Ashes,clay to clay. If your enemies wont get you, your own folks MAY |
« Shifting to Neutral or Pressing the Clutch when Braking - Is this right?
Tuning Your Alto 800 CC into a monster »
| Thread Tools | |
Similar Threads | ||||
| Maximum Load / Weight | Vinay DL | Technical Stuff | 2 | 23rd November 2007 08:42 |
| Noise Reduction in Ikon | benbsb29 | Modifications & Accessories | 18 | 30th November 2006 18:45 |
| primary reduction and secondary reduction | devsus | Motorbikes | 4 | 19th April 2006 17:35 |
| Flywheel | vipul261 | Technical Stuff | 3 | 11th February 2006 05:31 |
| Lightened flywheel& underdrive pulley on esteem anybody? | Stage3Monster | Modifications & Accessories | 8 | 18th March 2005 19:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
