Old 5th February 2015, 18:13   #16
autonarr's Avatar
Thanked: 30 Times
Default Re: The Ogle Carburetor - 113 mpg from a V8 engine
Think of the loss in fuel tax revenue alone! So yet another brilliant invention that will not materialize.
Also such cars would not need the regular 3mon/3k mile (or their metric equivalents) service intervals either. All those "A.S.S."s would be near obsolete
autonarr is offline   Reply With Quote
Old 5th February 2015, 19:38   #17
Thanked: 8,938 Times
[quote=autonarr;3639109]
See, I told you so! The plot thickens! Definitely a conspiracy if I ever saw one!
Jeroen is online now   Reply With Quote
Old 5th February 2015, 19:54   #18
VCheng's Avatar
Thanked: 246 Times
It is quite evident that the Agha Waqar School of Engineering Excellence is opening branches internationally, not just in Pakistan.
Seriously, guys, the importance of energy, not just in the 21st century, is such that any breakthrough would be impossible to silence by any conspiracy. It is just that there are no magic solutions to obtaining supplies and to harness them for mankind.
If it sounds too good to be true ........
VCheng is offline   Reply With Quote
Old 5th February 2015, 20:41   #19
Thanked: 2,395 Times
Originally Posted by sudev View Post
@Professori sir, if I C engines today operate at 20% efficiency would'nt it mean max mileage in a friction less engine be restricted to some top figure??
There are theoretical upper limits for different cycles. Values depend on parameters.
The Diesel cycle is less efficient than the Otto cycle when using the same compression ratio. However, practical Diesel engines are 30% - 35% more efficient than gasoline engines.[7] This is because, since the fuel is not introduced to the combustion chamber until it is required for ignition, the compression ratio is not limited by the need to avoid knocking, so higher ratios are used than in spark ignition engines.
Little appreciated fact.
Everyone has heard of CR. Same cant be of Expansion Ratio.
It will be interesting to watch the development of the GDI.
Before that, there was also the Pogue carburettor...
http://www.project.nsearch.com/profi...retors-history
The Fish carb was a genuine piece of equipment. Had quite a few advantages in a forced induction setup.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 6th February 2015, 12:11   #20
alpha1's Avatar
Thanked: 1,035 Times
Originally Posted by SnS_12 View Post
The demonstration on the top floor of the Philips headquarters involved playing 16 movies at the same time from a box containing a 64KB chip, attached to his laptop - no hard drive.
Roel Pieper took Jan Sloot to the headquarters of Computer Associates in the States where he was told "you are going to be the richest man on earth"
But two days before the source code was to be handed over he was mysteriously found dead in his garden. The source code has never been found by the security agencies assigned to try and recover it, but the box was apparently previously opened by Philips without Jan Sloot's permission ... stolen?
Thanks for introducing me to a new stuff to learn!
I went through this site: http://jansloot.telcomsoft.nl/Source...m#.VNRg9fApq9Q
What is written there will only profit media reproduction companies like Philips and Sony (because of lock in to their specific schemes of coding-decoding hardware which will reduce the bits required to describe the arrangement) and firms like Computer Associates. I have not seen any such product come out from any of these companies since 1999.
Call me a skeptic, but it looks like a case of plain and simple cut and dried baloney.
And this site: http://ticc.uvt.nl/~pspronck/sloot.html just confirms my hunch about the absurdity.
For those who would like to know what the crux is:
A story about an alien that lands on Earth. The alien wishes to return home with the knowledge of all books on Earth. Unfortunately, his spaceship is so small that he can only take with him a small stick. So what he does is the following. First, he digitizes each book. This translates each book in one huge, but finite, number. Then he attaches all these numbers to each other, which results in an enormous, but still finite, number. In front of this number he places "0.", turning it into a fraction between zero and one. Setting the length of the stick to one, he makes a small cut in the stick at precisely the fraction. When he returns home, he only needs to measure the place of the cut, to get back the fraction, and thus the number, and thus the codes for all the books.
alpha1 is offline   (1) Thanks Reply With Quote
261 MPG from Diesel - Electric hybrid XL1 concept by VW! ph03n!x The International Automotive Scene 3 1st June 2015 21:58
esteem engine (carburetor) needed asap nitroxx Shifting gears 1 12th April 2015 16:22
The 65 mpg Ford the U.S. Can't Have - Hope India gets it soon anarchist The Indian Car Scene 31 12th September 2008 14:08
64 kmpl mpg Prius khanak The International Automotive Scene 1 21st October 2007 13:37
188 mpg kkr2k2 The International Automotive Scene 3 4th December 2006 11:32
