Old 16th August 2006, 15:59   #1
morten's Avatar
Default high fuel consumption in indica dls
hi guys, i have a 2002 model indica dls.i used to give me a mileage of 16-17 kmpl in local city driving in chandigarh.it has done 90000 km . some 7-8 months back i got the pump overhauled by lucas it was okay for some time but since last 4-5 months its average has dropped to 12-13 kmpl in local driving.i have been to every good mechanic they sometimes adjust the timing but the mileage hasnt improved a bit.the engine is consuming some oil also.what could be the problem guys for the low kmpl.please help guys because i cant figure it out.
morten is offline   Reply With Quote
Old 16th August 2006, 16:28   #2
WhiteKnight's Avatar
Thanked: 76 Times
Originally Posted by morten
it has done 90000 km . some 7-8 months back i got the pump overhauled by lucas it was okay for some time but since last 4-5 months its average has dropped to 12-13 kmpl in local driving.the engine is consuming some oil also.
90,000 Kms? No work on the engine yet?
WhiteKnight is offline   Reply With Quote
Old 16th August 2006, 17:28   #3
morten's Avatar
no buddy,some indicas engine last for 100000-150000 kms also without a need for overhaul.my engine is consuming 1 litre of oil in 5000 kms do i need to overhaul it or maybe i can squeeze some more kms.
Old 17th August 2006, 09:32   #4
Thanked: 76 Times
The oil consumption is a good indicator that all is not well with your engine.
One of our 407s ran around 180,000Kms before engine overhaul- But it had reduced load carrying capability and used to cry on being overloaded.
Time to overhaul? Suggest you better check with your mechanic, based on his comments you can make the call. Technically, yes, you can extract many more Kms
Indica V2 DLS -Indica V2 DLS - Electricals falling apart - 57,000 km update cyberwhizs Long-Term Ownership Reviews 5 25th April 2013 13:04
High-speed driving & fuel consumption carZest Technical Stuff 29 29th August 2011 18:13
Morel vs DLS {High End Tweeters - High levels of confusion} Mi10 In-Car Entertainment 5 8th September 2010 18:03
Indica DLS / DLS TURBO / DICOR?.....What BUY? musicmanaman Hatchbacks 20 8th May 2010 19:05
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
