Old 2nd March 2015, 13:44   #1
Default Water leakage in Mercedes E350 (W212)
Hi everyone,
I have been facing this problem randomly for a while, the water is seeping inside the right side driver foot well. Also, the roof on that side is also wet, i suspect that the water is coming through the roof drains of the car. This morning it rained heavily in Delhi, and in the morning I almost cleared up 3-4 liters of water from inside the right side of the car.
Has anyone faced similar problem or heard of it?
I am really skeptical of sending the car to service center, I am sure they will just rip me off with loads of unnecessary replacements.
sidharthg is offline   Reply With Quote
Old 2nd March 2015, 14:02   #2
Thanked: 11,077 Times
Default re: Water leakage in Mercedes E350 (W212)
It is quite possible the drainage pipes are blocked. Open the roof, pour some water around the area and see if it drains, if not, you need to unblock the pipes. I do not know where it is for Mercs but google can help!
More on sunroofs here (ARTICLE: Sunroofs. India-specific Use and Maintenance Tips)
ajmat is offline   (4) Thanks Reply With Quote
Old 2nd March 2015, 14:09   #3
dark.knight's Avatar
Thanked: 3,388 Times
I'm not a MB owner but since this problem is specific to a particular model a simple search I did took me to a link in MB world http://mbworld.org/forums/e-class-w2...body-else.html This could help you out.
According to this the car has a storied history of leakage exactly as you've mentioned, accumulating in the driver foot well. Possibilities are a blocked drain pathway by debris like leaves, sand etc or one of the several interior plastic panels and joints connecting the outer metal shell which might've become loose over time and hence letting in water from outside when its being washed or when raining. The A-pillar panel seems to be trouble prone according to this.
dark.knight is offline   (2) Thanks Reply With Quote
Old 2nd March 2015, 16:17   #4
karan561's Avatar
Thanked: 10,554 Times
Default Re: Water leakage in Mercedes E350 (W212)
This can be cause mainly due to 2 reasons;
1) As everyone said that the drains must be blocked so best is to sort that issue and after the issue is solved see that the car is not parked under a tree cause, 'dried leaves' are one of the most common reasons for such blockage to happen.
2) The car must have been parked on a slope or an angle, this will sometimes not drain the water out and cause water seepage in the interiors. (Faced this in my Skoda Laura few years back)
All the best
karan561 is offline   (2) Thanks Reply With Quote
Old 8th March 2015, 10:56   #5
Hi everyone,
Thanks for all the support and suggestions. Yeah, I too googled and figured out the sunroof drainage problem. It was totally blocked. Fortunately I have air compressor in factory for high pressure jobs. So that did the trick. Simply plugged a nozzle in a hose pipe and inserted into the drain holes, and all the small debris came out of the bottom of the car.
So far the same problem hasn't occurred in these 2-3 days of rain!
sidharthg is offline   (1) Thanks Reply With Quote
2009 Mercedes Benz E350 cdi Avantgarde (w212) vs 2010 BMW 530d (f10) PlatzdaTurbo The Indian Car Scene 60 27th October 2010 12:05
New W212 Mercedes E Class and upcoming models from Mercedes India - Full details sidindica The Indian Car Scene 12 25th September 2009 15:05
W212 Mercedes E350 CGI in Pune EDIT : Launch on 5th October sidindica The Indian Car Scene 106 25th September 2009 09:45
Water Leakage in my OHC ~ H O N D A ~ Technical Stuff 11 16th November 2007 11:54
Water Leakage ~ H O N D A ~ Technical Stuff 20 4th October 2007 09:52
