Old 2nd February 2009, 14:22   #76
Ravveendrra's Avatar
Thanked: 405 Times
Originally Posted by vnabhi View Post
Are you referring to your Fiat petrol cars, or the diesel Laura? Do you consider 2T better than iftex system d or system g?
I used the 2T oil in all my previous cars, the Fiat 1100, the 118 and the Corsa. In the Corsa, the 2T oil went in along with the Iftex additives that Opel prescribes.
I tried the Iftex additives in the carburetted cars too but did not find much improvement. I found the 2T oil addition to be very effective in the carburetted vehicles. In the injected Corsa the 2T oil addition was effective, but not as much as in the carburatted engines.
I am a little wary of fiddling with Diesel engines as I have never owned one before and in case of any trouble would not even know where to start. I have seen the posts here about addiing 2T oil to other Diesels but am held back by the strict warning handed out by Skoda Dealer not to add Iftex additives.
I therefore am yet to try the 2T in the Laura (maybe on the next TBHP drive when there are some experienced persons on hand to iron out any trouble that I may face). In the meanwhile I am awaiting responses to my post of 30 Jan here:
"Hi,
I used to use 2t (Castrol super TT) for several years esp. on long drives. I wonder if anyone has used it in the Skoda Diesel engines and what the results were.
Cheers and thanks in advance."
Cheers,
Ravveendrra is offline   Reply With Quote
Old 2nd February 2009, 15:18   #77
Raccoon's Avatar
Thanked: 105 Times
Well, if you want to use 2t in your cars, at least don't use Castrol Super TT. It was one of the oils I found to smoke to most... and very likely leave more residue. There are better products!
As for IFTEX... their 2 wheeler additive is compatible with 2t oil. No mention is there of the compatibality of 2t with System G... so you have to use it at your own risk.
Old 3rd February 2009, 10:18   #78
HIGHNOON's Avatar
Thanked: 56 Times
results out on my experiment !
Had filled the INDIGO with power with 2T oil. Achieved 17.23 kmpl on mumbai pune highway without AC. ( with 1 passenger )
Had achieved 18 kmpl twice before but had seen a drop to 14/15 kmpl in FE for last 2500km.
I believe this increase in FE apart from noticeably better performance , smoothness as well has to do with the additive., with no change in other parameters.
In fact i drove faster yesterday on the winding road than i ususally do.
So shall post updates on the next fill ! so keeping my fingers crossed and hoping not do any damage to her ''' airways'''
till then...
HIGHNOON is offline   Reply With Quote
Old 3rd February 2009, 10:55   #79
Thanked: 405 Times
Default Which 2t oil?
Thanks for the tip. Now this leaves me with the question - If not Castrol, which one?
Thanks in advance, cheers
Old 3rd February 2009, 12:11   #80
alstonvaz's Avatar
Try Castrol Power1 Jetx, its a little costlier than Super TT and atleast i find it better. Its my regular use 2T in the RX.
alstonvaz is offline   Reply With Quote
Old 3rd February 2009, 15:18   #81
Raccoon's Avatar
Thanked: 105 Times
Unfortunately, since the 2 stroke market is a shrinking one, there arent too many options. But still there are few... and some possibly better and cheaper than Castrol -
Motul
Veedol
Gulf
Shell
BPCL
About Motul - you get both mineral and fully synth easter base stock. Its supposed to be the cleanest burning! Will in all probablity the safest and cleanest for use in cars. But the fully synth product is pricy! You can get it direct from Motul dealers.
Old 3rd February 2009, 15:31   #82
lohithrao's Avatar
Thanked: 163 Times
Never knew if we could use 2T in the cars, at least the new once(MPFI)??
Am not very sure if its recommended?
lohithrao is offline   Reply With Quote
Old 3rd February 2009, 15:36   #83
Raccoon's Avatar
Thanked: 105 Times
Gosh dude, you should read the thread properly first! It is not recommended by any manufacturer I know. But some people here have found it to be beneficial. Its upto you to decide!!
Old 3rd February 2009, 15:43   #84
lohithrao's Avatar
Thanked: 163 Times
Raccoon, yes i dint read through the thread properly but after going through few it looked as if many are using. so wanted to know if someone has used 2T on a fuel injected car?
Old 3rd February 2009, 16:29   #85
someone has mentioned using it in an FI car.
silver_shadow is offline   Reply With Quote
Old 3rd February 2009, 19:19   #86
I m already using acetone+2T+xylene combo in our wagonR since last 10k Km.Its a newer car having driven 21k Km.There is noticeable difference in smoothness and performance.Haven't came across any ill effect on exhaust system.This car runs so silent that its difficult to find any engine sound & vibration once windows rolled up.
finetuning is offline   Reply With Quote
Old 17th April 2009, 17:53   #87
Thanked: 195 Times
Does this engine performance trick applicable to 4-Stroke bikes also. I have a Honda Unicorn? Your Views
tj123 is offline   Reply With Quote
Old 18th April 2009, 01:23   #88
Raccoon's Avatar
Thanked: 105 Times
^^^Yes I'v heard that it makes bikes feel smoother too. But I'm not ready to try it in my bike... so no personal experiences.
Old 18th April 2009, 20:28   #89
HKS
HKS's Avatar
@finetuning
Which car have you tries it in?
Petrol or Diesel?
If Petrol then,
Carb or Fuel Injection?
If Diesel then
Crdi or the IDI?
HKS is offline   Reply With Quote
Old 19th April 2009, 12:21   #90
gd1418's Avatar
Thanked: 656 Times
I've a TCIC Safari & a DI Scorpio. Am using in both with acetone. Runs smoother.
Originally Posted by HKS View Post
@finetuning
Petrol or Diesel?
If Petrol then,
If Diesel then
Crdi or the IDI?
Adding Engine oil with Diesel. chanapli Technical Stuff 42 5th July 2017 02:05
My Experience With Adding Acetone in Petrol finetuning Technical Stuff 471 24th May 2017 12:11
My Experience With adding Boric Acid in Engine oil finetuning Technical Stuff 426 19th November 2015 20:35
Adding Ethanol in Fuel narasimha raju The Indian Car Scene 12 10th June 2013 14:42
