Old 28th March 2017, 22:45   #166
R2D2's Avatar
Thanked: 1,243 Times
Default Re: Honda Amaze: Oil leak, engine seized! A bad experience with Honda service
They claimed the sump wasn't cracked but the filter had been over torqued so replaced the filter, ran the engine for ten minutes on a ramp.
I'd pointed out a photo I took (attached) of a small crack near the oil filter area. They said it didn't look like a crack issue so just changed the oil filter and replaced the oil.
I have only driven the car some 15 odd km more today and already seeing a repeat of these leaks :(
This is a photo of the filter as fitted by the garage I had gone to, that the dealer says was over torqued. Note the small crack extending under it?
IMO over torquing would probably damage the oil filter threads & gasket rather than cause cracks in the engine block.
Was the dealership able to check for filter thread & gasket damage? May be the filter canister is just not screwed on or seated properly.
Last but not the least, have the sump gasket and drain plug crush washer checked out OK?
Maruti Ertiga VDi - Engine oil leak. EDIT : Issue resolved on Page 3 S5157 Technical Stuff 61 6th December 2015 17:55
Pulsar 220 engine oil leak ravi_23 Motorbikes 6 15th October 2013 13:22
5009 KMS-A'bad-Calicut-Bangy-Hyd-Aur'Bad-A'Bad-Report ramkya1 Travelogues 48 4th August 2010 00:04
A bad bad bad night for me.... Ranjan Sharma Street Experiences 38 8th April 2010 12:02
My accident - Bad brakes, bad rain, bad luck... vezj420 Street Experiences 41 22nd May 2007 10:49
