Old 25th March 2015, 15:24   #1
zenren's Avatar
Thanked: 1,725 Times
Default Maruti Swift: OEM Clock LCD problem
The dashboard clock (OEM fitment with the car) in my 2008 September Swift VDi has started showing symptoms of LCD panel issues recently. When starting in the morning, most of the segments are not lit up and some of them eventually light up by the time I reach office. Here is a sample of how it looks like after reaching office.
Maruti Swift: OEM Clock LCD problem-wp_20150325_002.jpg
This is dependent on the temperature I guess, since the display is fine if parked in hot sun. Home parking is in the basement and is much colder.
Now to the question: Could this be caused by a weak battery nearing the end of its usable life? The battery was replaced in 2012 January and has crossed 3 years now - same as the previous stint. My brother recollects some issue with the clock just before the old battery was replaced, which got corrected automatically with the new battery. If this is a likely explanation, what could be the underlying reason, since a small LCD display like this should only take a very minimal current?
If no, what else could be the issue? In my other car which is another 2008 Swift, I came across this issue in 2011 and I ended up replacing the clock through MASS for ~1700 after placing an order with the factory. At that point, I thought it to be a one-off issue and didn't bother much about replacing the same. However, seeing the second Swift also develop same symptom made me wonder if this is something that other Swift owners have also faced. Anyone else with similar experience?
In our case, both the cars used to be parked in hot sun during most days.
zenren is offline   Reply With Quote
Old 25th March 2015, 16:51   #2
NetfreakBombay's Avatar
Thanked: 402 Times
Default re: Maruti Swift: OEM Clock LCD problem
One possibility is moisture. Have see this behavior in other cal electricals that was traced to moisture. Heat evaporates it and makes the problem go away.
That could indicate to a settings issue. Removing batters resets settings.
NetfreakBombay is offline   (1) Thanks Reply With Quote
Old 25th March 2015, 23:39   #3
AkMar's Avatar
Thanked: 1,377 Times
Our 2010 Swift has exactly the same issue for over a year. During the last service in 2014, we inquired with the dealer for a replacement of the clock but it wasn't available. The car is due for servicing this month, will check again about the availability.
I don't think that battery is the issue. We are using the car for more than a year with this issue in the clock, and it is running absolutely fine. There is no problem with the battery (our car is still running with the factory fitted battery).
In addition to your observation of clock getting normal after being exposed to sun, I have also observed that sometimes it gets normal even after gently pressing on the display.
AkMar is offline   (1) Thanks Reply With Quote
Old 26th March 2015, 12:54   #4
Thanked: 103,495 Times
Default Re: Maruti Swift: OEM Clock LCD problem
Going by posts on this thread (Help regarding digital clock installation in Swift.), you could've bought 3 clocks for that money . I'd suggest just replacing it. Availability isn't an issue either.
GTO is offline   (1) Thanks Reply With Quote
Old 26th March 2015, 13:11   #5
zenren's Avatar
I gave the benefit of doubt to Maruti the first time as a possible one-off issue with just my particular piece and thought it is okay to stick to original one since the Rs. 500 MGA needed cutting the wires to the clock and changing the connector pins. Also, I had liked the auto-dimming of the clock when I turned on the park light so that it is bright during the day and not distracting during the night.
When it becomes 2 out of 2 in my case, it it clearly due to sub-standard quality of the part which is going to exist even in the replacement piece that they charge exorbitant rates. So no more OEM replacement.
At this point, I'll pad something inside the frame of the clock from the inside to keep it pressed which worked for me last time for a few months. After that the pressure was not sufficient and I ended up replacing it.
zenren is offline   (2) Thanks Reply With Quote
Old 26th March 2015, 15:35   #6
Jaggu's Avatar
Thanked: 8,685 Times
Seems the connector to LCD or LCD is failing, you can try to dismantle and check if terminals of LCD can be accessed and cleaned using some alcohol based cleaner, as a last option. If not you need a new unit.
Jaggu is online now   (2) Thanks Reply With Quote
Old 30th June 2016, 11:58   #7
sourabhzen's Avatar
Thanked: 1,290 Times
I have similar issue in my 8 years old Swift. The issue is there for 3 years now. The connectors are fine as I got that checked a number of times.Sometimes, applying pressure on LCD helps.
Finally today, I got original OEM from MGA shop. Question is, can I change the clock myself?
sourabhzen is offline   Reply With Quote
Old 30th June 2016, 12:30   #8
Jaggu's Avatar
Look at the new clock, if it is held in place using clips then you can just pry gently out the current one (careful don't scratch the dashboard) and replace the same. Wiring usually is a snap on just ensure that the connectors are at a place that is accessible, most likely you will have to open the HU part to access the same if otehrwise.
If you are a DIY person, you can give it a try or any accessory shop will fix it in 10 mts.
Jaggu is online now   (1) Thanks Reply With Quote
Old 4th July 2016, 11:59   #9
sourabhzen's Avatar
I am a DIY person for everything but my car. I get too scared to fail in my attempt and thus rely on the experts on car related issues. However, yesterday I took a chance to change the clock myself. It was piece of cake and the whole process took less than 10 minutes. Only issue is the short cable that connects with the clock. It was impossible to look behind the clock and attach the connector but the guess work helped and connected it in two attempts.
sourabhzen is offline   (1) Thanks Reply With Quote
Swift Vdi - Failed turbo under 5K on the clock!! intoxicangel Technical Stuff 44 9th April 2015 15:12
New Swift 2011 How to set-up clock in Instrument cluster? bala_chennai Technical Stuff 1 10th November 2011 09:47
Help regarding digital clock installation in Swift. emkay456 Modifications & Accessories 39 20th December 2010 08:26
LCD TV or (LCD montior+VGA Box) for Wii? ashwin489 Gadgets, Computers & Software 0 20th July 2009 14:33
Problem with wide screen LCD monitor resolution bill1182 Gadgets, Computers & Software 23 30th May 2009 02:29
