Old 21st August 2006, 15:52   #1
recently my car has started indicating that my brake fluid is low..i mean it indicates that way...so when i chkd it up it was pretty much in the normal limits...also chkd for loose connection ...but dint find any...it always lights up especially when im indicating...that is left or right...dunno wats the problem?
i also chkd for other oil levels but found that they all had condensed water...is it safe? is it normal? wont it affect the overall lubrication of the parts?...
babe_on_wheels is offline   Reply With Quote
Old 21st August 2006, 16:36   #2
veyron1's Avatar
Thanked: 38 Times
First, if the brake oil light is blinking in the console, check out the oil level switch that's attached to the brake oil reservoir. Also check the handbrake lever/switch.
Second, water in oil is NEVER good. If you found water in the engine oil, check it out at your nearest company workshop. Perhaps you just have a leaky head gasket.
Third; which car do you have? Might be easier to diagnose if you specified the model.
veyron1 is offline   Reply With Quote
Old 21st August 2006, 17:27   #3
esteem_lover's Avatar
Thanked: 451 Times
please specify what car u drive ...water (condensed or not) should not be present in the oil at any stage. please get the oil changed.
Old 21st August 2006, 20:24   #4
ikon flair...and the condensation is present in all the tanks...ive checked...the brake and the transmission...is it required to change the oil and get it dried up or some process like that to remove all the water droplets?
Old 23rd August 2006, 04:02   #5
SLK
SLK's Avatar
Thanked: 192 Times
I really don't understand..
How did you check water in transmission oil?
How can water condense in brake oil?
How do you see water droplets?
Is there no water in engine oil then?
SLK is offline   Reply With Quote
Old 23rd August 2006, 18:13   #6
it was indeed water drops...i askd the garage fellow who i showd it to that fellow said the gasket or seal was a lil faulty in both....the rubber was a lil damaged as i think the guys at ford dint chk for the quality after it came back frm the floods last yr...i mean they cleanedf it up but ignored the sealing....now will hav to take to wasan ford fellas and get it fixd...
Old 24th August 2006, 19:18   #7
Thanked: 451 Times
better get it fixed fast. u cannot have water mixed in oil.
Water found with Diesel in my Getz CRDi - Fuel Tank anarchist Technical Stuff 20 19th June 2017 13:53
Fluid leakage or condensation? k_nitin_r Technical Stuff 3 17th June 2012 18:33
ikon ac: water condensation & engine jerk silver_shadow Technical Stuff 2 5th May 2008 19:10
Windscreen condensation? adman77 Technical Stuff 22 14th August 2007 11:23
