Old 21st August 2006, 19:47   #1
parimal_vb's Avatar
Need assistance on the GTX 1.6 Engine compartment wiring structure, as my GTX is having trouble while running the engine on normal working temperature. The vehicle shuts off after 10-15 minutes once it become cold it will run for more 10-15 minutes. Have checked the Fuel pump, the Throttle body, also the injectors all is fine. Only hope is by trying the ECM and cross check the wiring.
Can any one help or have similar experience to share.
Thanks.
parimal_vb is offline   Reply With Quote
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
Zen MPFI wiring manual/wiring diagram IndrojitSircar Technical Stuff 1 27th February 2012 00:21
Heat from the Engine compartment reaching the Passenger cabin !! Need Help xenxer Technical Stuff 13 10th February 2010 15:08
PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) karizma_devil Hatchbacks 18 28th December 2008 13:04
Under the Monster Volvo B7R Hood (Engine Compartment Pics) vishnugs Commercial Vehicles 7 6th May 2007 05:14
