Old 10th April 2015, 09:32   #1
Thanked: 9,729 Times
Default Attn: BMWs with N47 engines (320d / 520d)
I came across this BMW service bulletin which seem to imply that timing chain tensioners might not be keeping up with the timing chain expanding/ extending in time leading to potential engine failure.
Might be worth printing this out and taking it to your dealer during the next service
10011540300.pdf
ajmat is offline   (1) Thanks Reply With Quote
Old 10th April 2015, 09:39   #2
lurker's Avatar
Thanked: 641 Times
Default re: Attn: BMWs with N47 engines (320d / 520d)
It would be a good idea if some list could be compiled or a thread started on which engines available in India were non-interference types, so that one could rest assured on performance or failure of timing chain not leading to damage to engine.
lurker is offline   Reply With Quote
Old 15th April 2017, 08:37   #3
Thanked: 622 Times
Default Re: Attn: BMWs with N47 engines (320d / 520d)
Attachment 1359055
I was toying with the idea of picking up a used 3 series or an X1 and came across this issue as I started my research.
And given my budget this means that the model years that I am considering (2008 - 2012) would fall bang into the cars that we more problematic in this regard. Is there any information on how badly cars in India were affected and whether recalls were made?
Drive on,
Shibu.
shibujp is offline   Reply With Quote
Old 16th April 2017, 12:22   #4
n.devdath's Avatar
Thanked: 1,714 Times
Even if BMW has this data, it would be tough to access it. I would suggest you shortlist a few cars, then check their engine types and see if this fix has been carried out on them. If not, it is best to take a printout of this document with the car to the service centre and take their opinion.
n.devdath is offline   (1) Thanks Reply With Quote
Old 16th April 2017, 12:35   #5
Do you really think BMW will give a balanced opinion on this? I would factor in the cost of replacing the chain and tensioners as part of the deal and get this done!
BMW 520d Initial Ownership Report EDIT: Transmission Breakdown in 520d androdev Test-Drives & Initial Ownership Reports 195 14th December 2017 07:41
BMW 325i,320d or 523i??? EDIT Bought 320D Highline morphin1 Luxury, Imports & Niche 67 13th April 2015 13:57
Merc E220 Vs BMW 520d Vs Audi A6? EDIT : Bought White 520D !! manujkansal Luxury, Imports & Niche 117 30th May 2014 16:15
Difference between old engines and new engines (petrol and diesel) srijit Technical Stuff 32 26th January 2011 10:20
VW Passat or BMW 320d Highline or New Audi A4 - EDIT : Bought BMW 520d Insane Devil Luxury, Imports & Niche 147 5th November 2009 00:59
