| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) | |
| Senior - BHPian | Got the following info related with EPS from the Zen website Quote:
![]() What will be the after-effect if there is a need for quick manoeuver of the car at high speeds ? Will the car lose it control in the absence of traction control ? ![]()
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. | |
| | #2 (permalink) |
| BHPian Join Date: Aug 2006 Location: Pune
| Power assisted steering is dangerous on high speeds. Cozes when in speed a slight turn (which will be much softer due to power steering) can cause the vehicle to loose control and may be difficult avoid disaster. This is the reason the other safety features have been added to the high end vehicles. (ABS, EBD,… Etc) At high speeds the steering power control should shut off making the steering hard as per speed to manage the drive. The need for power steering is on the low speed and usually in city driving where you may need to drive vehicle at low speed and on most turns. The super cars like Ferrari, the Lamb .., does not come with Power steering installed in it. |
| | #3 (permalink) |
| Distinguished - BHPian ![]() | Mithun, PS is more required at slower speeds, esp in city driving conditions. To understand this, try to see the effect of the steering at low speeds and high speeds - but pls try in a ground. Also, at higher speeds, you would not be doing too much turning. |
| | #5 (permalink) | |
| Team-BHP Support ![]() | Quote:
Its a good thing that EPS switches off at high speeds else the steering will be too sensitive and light. Very dangerous at high speeds. Most cars have a speed-sensitive power steering, which makes the steering harder as speeds go up.
__________________ GTO Work backward from your imagination, not forward from the past!
| | #6 (permalink) | |
| Senior - BHPian | Quote:
__________________ "Keep your friends close, Keep your enemies closer" | |
| | #7 (permalink) |
| BHPian Join Date: Aug 2006 Location: Bangalore
| Mithun, I feel the most important time when one needs power steering is during parking and turning at very low speeds. Power steering controlled via EPS, is a kind of intelligent system, which nearly shuts down power assist to steering when on higher speeds. This enhances our safety actually. I drive the Alto that has powersteering, and I recently drove a Zen without power steering. The steering is hard in the beginning but on the drive i feel its better without power steering because it gives a good feel when turning as well. I believe the feel should be lessened as it happens with EPS so that turning effort is there during higher speeds than just a light wriggle with a finger which can prove quite fatal at times. |
| | #8 (permalink) |
| Senior - BHPian | Correct me if im wrong,but eps depends on the revs you are pulling rather than your speed.I say this coz in the baleno while revving at around 5500rpm while becomes quite difficult to turn.Try it and see....you might feel a difference even at 4k rpm I could be wrong though. binz
__________________ Advan Neova AD-07 Enkei RP-01 Suzuki Power! Last edited by binz : 24th August 2006 at 22:11. |
| | #9 (permalink) | |
| Quote:
Not too sure, will try on Alto and see, it has some kind of intelligent system I guess. | |
| | #10 (permalink) |
| BHPian | as far as i remember the eps shuts off at around 60 coz it is only needed at speeds below that in the city but at higher speeds its not needed and cause damage to you and your car!
__________________ 4get metrosexuals be a petrosexual.............:D TEAM-BHP.com pada pa pa IM REVVING IT!!! |
| | #11 (permalink) |
| Newbie Join Date: Aug 2006 Location: Mysore
| The Eletric power steering is completely speed dependant and not rev dependant at all. The steering only feels hard when you rev, perhaps psychology... I dunno, but I really don't see the use of RPM to decide steering assistance.. Else, a car with tall gearing which could hit 60kph at 2000rpm in fifth and 40 kph in 1st at around 4000rpm would have it's power steering switch on and off as the driver rises or drops revs... The electric power steering also has a direct drive mechanism; Even when the engine is switched off and assist from the electric motor is not available, the steering can be turned just like a regular rack and pinion.. Which is not the case with the hydraulic system. Thus, when the speeds exceed 60kph or any other speed decided by the manufacturer, the steering is essentially direct.
__________________ Blast from the past |
| | #12 (permalink) | |
| BHPian Join Date: Sep 2005 Location: Gurgaon
| Quote:
| | #13 (permalink) | |
I agree with your second point though.Steering should depend on speed and not upon revs because at 100kmph in 5th gear,the revs will be at around 3-4k rpm and if the steering depended on that,potential disaster. Just stating what happens in the baleno(hydraulic power steering).Eps in the NHC and swift is completely different.
__________________ Advan Neova AD-07 Enkei RP-01 Suzuki Power! | |
| | #14 (permalink) | |
| BHPian | Quote:
__________________ Market pulse and Sales volume are not something fanboys understand! | |
| | #15 (permalink) |
| Senior - BHPian Join Date: Feb 2004 Location: DL XX XX XXXX
| It doesn't shut off.. ... it is speed sensitive.. and thats it. Try switching off the engine at 80+... and you will still feel the sudden power loss in the steering. It can not be rpm sensitive... else while doing 120... if I go into neutral.. .. I'll most probably fly off the road. Its not just EPS... but some hydraulic steerings too are speed sensitive.
__________________ Č╠╣€€Я$ $£Қ |
« What are the benifits of Engine Torque Damper
Esteem steering getting very hard in the afternoon »
| Thread Tools | |
Similar Threads | ||||
| Strange sounds at high speeds | Surprise | Technical Stuff | 0 | 29th May 2009 09:29 |
| Why the Obsession with High Speeds? | vasudeva | The Indian Car Scene | 156 | 29th December 2007 12:38 |
| Taking cars to high speeds | Surprise | Shifting gears | 32 | 17th July 2007 00:56 |
| Hatches and high speeds | madan80 | Technical Stuff | 31 | 4th April 2007 20:32 |
| Which is better ?AC ON or Windows rolled down in high speeds | prince1a | Technical Stuff | 19 | 18th June 2006 12:54 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
