Old 27th April 2015, 10:14   #1
Default Engine dead spot right after a cold start
Hi All,
I have a Honda City I-VTEC (MT) which has completed 35.5K of regular running. Serviced regularly at the ASC. For the last 4 months I'm observing a strange behaviour with engine and would appreciate any insights as the ASC technicians are clueless -
When the engine is started first time in the morning and if I start driving right away with the engine temp. blue light still on, everything is as expected till I switch from 3rd to 4th gear. At a speed of 40 Kmph, a shift from 3-4 gear leads to a slump in the engine RPM as if the engine was suddenly starved of fuel. It then picks up again but the behavior is consistent for the last 4 months.
The natural suspect was fuel quality in Hyderabad so I switched to Shell and other reliable outlets without any change. The ASC also ran a full diagnostic on the system and did a reset of the ECU. That too did not bring any change to the behavior. The air filter has been replaced too.
Any insights about what to look at or how to troubleshoot will be greatly appreciated as I really need to get this resolved.
-Thanks,
Ashish.
ashish_me2 is offline   Reply With Quote
Old 27th April 2015, 10:37   #2
Jaggu's Avatar
Thanked: 8,693 Times
Default re: Engine dead spot right after a cold start
Have you tried checking the throttle body, and idle system? Also do check if the injectors and fueling system for any minor blocks. Starvation seems to be a fueling issue hence suggesting these.
Jaggu is offline   (1) Thanks Reply With Quote
Old 27th April 2015, 11:28   #3
rakesh_r's Avatar
Thanked: 743 Times
What i can suggest-
1-Check fuel pump and fuel filter.
2-Injectors.
3-Fuel tank for debris and water.
Looks like a typical fuel starvation issue.
rakesh_r is offline   (1) Thanks Reply With Quote
Old 27th April 2015, 11:33   #4
Check the Fuel Pump,Fuel Filter and Injectors.
MrIncredible is offline   Reply With Quote
Old 27th April 2015, 11:54   #5
pramodkumar's Avatar
Thanked: 947 Times
Guys this happens during start and cold engine, The OP does not confirm of this behaviour when the engine reaches temperature. its the MAF sensor which might be causing the issue. Ashish can you replicate the issue? does it happen only during a certain conditions? If yes then please take the car to the A S S, ask them to swap the MAF sensor with a working one and try to replicate the issue. If it is gone then you know what is the culprit.
Pramod
pramodkumar is offline   (2) Thanks Reply With Quote
Old 27th April 2015, 12:06   #6
Thanks for the responses. Can you point me to some good DIY article and a MAF cleaner that can do the job?
Old 27th April 2015, 13:33   #7
S5157's Avatar
Thanked: 163 Times
Default Re: Engine dead spot right after a cold start
See this DIY article on Team-bhp on MAF sensor cleaning
http://www.team-bhp.com/forum/techni...-rs-120-a.html
S5157 is offline   Reply With Quote
Old 27th April 2015, 13:45   #8
Thanked: 1,171 Times
My Jazz displays identical behavior, despite injectors and throttle body being cleaned regularly. I find that using System G fuel additive helps. But the biggest part is played by the fuel itself. There are times when I get genuinely good fuel and it shows in the drive: pick-up improves and this flat-spot issue subsides on its own.
The important thing to note is that these iVTECs are tuned for 91 octane petrol (there is a bold sticker on the inside of the fuel tank lid of my car saying the same), hence are quite sensitive to substandard petrol which we, unfortunately, often have to make do with, even in Delhi-NCR.
Shreyans_Jain is offline   Reply With Quote
Old 28th April 2015, 17:51   #9
dhanushs's Avatar
Thanked: 4,505 Times
If the problem is only during cold starts then its the O2 sensor.
If you plugin an OBD, you'll get a P0141 or similar error.
Old 28th April 2015, 17:58   #10
kiku007's Avatar
Thanked: 1,482 Times
I've had this problem in the Fiesta petrol and it was due to faulty O2 sensor. The Fault code will tell this.
kiku007 is offline   Reply With Quote
RPM drops after cold start, and engine shuts off DCEite Technical Stuff 13 28th May 2017 01:33
Skoda Octavia engine shutting off, right after start gigy Technical Stuff 11 20th November 2014 08:33
Zen exhaust spitting lots of carbon powder at high revs after cold start!! devrajman Technical Stuff 32 20th June 2010 08:28
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
How many KMs after cold start the car will feel better sreenivass Technical Stuff 30 13th November 2009 12:14
