Old 24th August 2006, 16:23   #31
ess_a's Avatar
Originally Posted by kpzen
Stock rims 14"
Stock tyres 165/80-14"
Got upsized tyres 185/70-14" on stock rims....
Can one upsize that much on stock rims??? Isnt that a bit too wide???
ess_a is offline   Reply With Quote
Old 24th August 2006, 16:29   #32
Shan2nu's Avatar
Thanked: 89 Times
It's usually limited to 20mm over stock so 185 is fine.
Shan2nu
Old 24th August 2006, 16:43   #33
kpzen's Avatar
Thanked: 1,655 Times
One reason why i'd rule out low tyre pressure.
This was how "Morten" had described the tyre wear on his car.
"" the tyres go from the outside towards the inside and the whole tyre is gone and the steel wires come out from outside of the tyre. The strange thing is rear tyres also go the same way.the tyre pressure was always maintained to 29-30.the alignment and camber was always ok.i guess the car is defective but cant tell what is wrong.""
Using low tyre pressure should wear out both the inner and outer shoulders. But in this case, the wear starts from the outer shoulder and then moves inwards. This can only be caused due to positive camber or very hard cornering (like what we do on racet tracks).
This diagram will help understand what i'm talking about.
Positive and Negative Camber
As you can see, when a car has +ve camber, the outer shoulder of the tyre is taking most of the cars weight. This will also cause the contact path to reduce and make the tyre heatup and wear out faster than usual.
Shan2nu
Great explanation by a technical guru...
regards
KP
Old 24th August 2006, 17:00   #34
rks
rks's Avatar
I agree with Shan2nu's explanation. I has misread morton's description of the tyres wearing from "the outside to the inside" to mean "from the shoulders towards the centre". So I guess morton should clarify what he meant -- is there wear on both shoulders or on only one? The fact that this is happening on all four tyres suggests that there is a systematic error involved. So possibly checking the alignment (including camber) at two different ASC's might do the trick --it is unlikely that both of these would commit the same errors. If excess wear is happening on both shoulders of the tyres, low tyre pressure is probably the culprit.
Old 24th August 2006, 17:51   #35
rks
rks's Avatar
Using low tyre pressure should wear out both the inner and outer shoulders. But in this case, the wear starts from the outer shoulder and then moves inwards. This can only be caused due to positive camber or very hard cornering (like what we do on racet tracks). [...]
Good explanation. I have one more issue here. If there is a misalignment due to positive camber, the outside shoulder of the tyre should wear out faster, but the inside shoulder of the tyre should show much less wear than normal -- because the inside shoulder is taking a lower load than normal. But from morten's description, "the whole tyre is gone" in as little as 8000 kms in one case and 13000 kms in the other. So my guess is that morton's description is not quite accurate -- he might have meant that all four tyres wear out from "the shoulders towards the centre", rather than from "the outside towards the inside". This would be consistent with "the whole tyre is gone" within such a low mileage. Also, as I said earlier, the fact that this is happening to all four tyres strongly suggests a systematic error that affects all four tyres in the same way. E.g. the tyre pressure readings could be way off due to a faulty gauge in the case of two-sided wear, or the same alignment mistake is happening at all four wheels due to faulty equipment (in the case of one-sided wear).
Old 24th August 2006, 17:57   #36
Shan2nu's Avatar
Thanked: 89 Times
Maybe, but my reply was based on how the wear was described. A few snaps of the worn out tyres would solve the whole mystery.
Shan2nu
Old 25th August 2006, 11:55   #37
rks
rks's Avatar
I agree. The more I think about this, the more convinced I am that there is something wrong with morten's description of the problem. He needs to check with his friend as to what exactly happened and post a detailed description with snaps before any analysis can be made.
It seems that the car (a Jan 2006 Swift) has already done an awful lot of running (at least 21000 kms) till date -- so it must have seen a lot of the highway. There is a very serious danger of a tyre burst if the car is driven at speed on the highway with this problem unsolved. I hope morten's friend has been adequately warned. With all the free services that the car must have gone through at an ASC, I cannot understand how the problem still remians unsolved.
A Guide: Eating out in Mumbai khanak Shifting gears 1151 1st July 2018 07:54
A Guide: Eating out in Bangalore Hatari Shifting gears 3626 23rd May 2018 20:18
A Guide: Eating out in Pune abhijitaparadh Shifting gears 564 31st January 2018 18:57
Fiat Palio Stile 1.6 - Fender eating the tyre RAINMAKER Tyre & Alloy wheel Section 14 15th June 2010 15:28
my OHC vtec 1.5 ... eating up fuel.. help four_tire Technical Stuff 20 12th May 2006 10:45
