Old 3rd June 2015, 22:31   #16
SPIKE ARRESTOR's Avatar
Thanked: 744 Times
Default Re: Diagnostic manual for Tata's 1.4 and 2.2 common-rail diesel engines: EDIT 4x4 codes also
Originally Posted by Shubhendra View Post
TTL (Tata Technologies Ltd) is big time into helping TML with automotive software and for that matter JLR group as well.
Possible, but neither TML nor JLR are ECU manufacturers. I'm talking about Bosch, Conti, Delphi and co.
A software can support / do only that much, what the hardware allows it to. TTL and JLR work only on "interface" level automotive software development AFAIK.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 12th June 2015, 14:43   #17
tsk1979's Avatar
Thanked: 15,646 Times
Originally Posted by apachelongbow View Post
I believe an OBD2 compliant scanner can read most of Safari's code. I can see EGT, MAF, coolant temperature, engine rpm, vaccum psi, boost psi and even bhp at rear wheel on my OBD scanner.
Is it a post 2009 safari. My OBD scanner can read codes off 2010 model, but my 2008, I get only coolant temp and some other basic stuff
Old 12th June 2015, 17:47   #18
Thanked: 2,025 Times
Infractions: 0/1 (4)
I guess that explains it then, I heard from my A.S.S that sometime in 2010 or near about, Tata changed to OBD2 compliant codes in their ECU software.
apachelongbow is offline   Reply With Quote
Old 16th May 2016, 11:07   #19
man_of_steel's Avatar
Thanked: 1,055 Times
Are you able to get the error codes as well? Which scanner hardware are you using?
man_of_steel is offline   Reply With Quote
Old 16th May 2016, 11:13   #20
tsk1979's Avatar
I bought an ELM 327 clone from Dx.com for about 8-9$ long time back. You can pick up any such generic scanner from ebay India too. Error codes are not a problem, but you have to take a look at the diagnostic manual to find what codes mean.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 16th May 2016, 11:15   #21
..Error codes are not a problem, but you have to take a look at the diagnostic manual to find what codes mean.
Thats a relief! I am guessing that the codes will be as per the OBD standards. If so, I do have the manual with me. Thanks!
Old 16th May 2016, 11:28   #22
tsk1979's Avatar
There are lot of Tata specific codes, you can look them up from the manual attached.
Old 19th May 2016, 15:38   #23
So I got the VGate OBD-II scanner from E-Bay and am not able to connect to it from the Android App. Tried almost all major apps including Torque Lite, OBD Doctor, Fun2Drive etc. The vehicle in question is a 2005 3.0 Dicor 4x4. All apps are trying to read many protocols but couldn't communicate with the device ( Although pairing is successfully done ). Has anyone been able to connect a similar BT device to the 3.0 Dicor successfully?
Common Rail Diesel Injection System dhanushs Technical Stuff 20 31st July 2011 20:22
Do non-common-rail diesel engines work better with warm air? Samurai Technical Stuff 35 23rd January 2010 09:34
Safari Common Rail Engine Launch? EDIT 010805 Now driven. Edit 190805 Now BOUGHT!!! Steeroid The Indian Car Scene 277 13th July 2009 23:14
Common rail diesel have the europeans/americans stung back rahul_intlad The International Automotive Scene 20 7th July 2007 00:14
TATA indica / indigo with Common Rail engines. hell_rider The Indian Car Scene 2 8th June 2005 10:57
