Old 26th July 2013, 21:11   #16
Thanked: 2,408 Times
Default Re: Audi Direct Shift Gearbox (DSG)
They can reverse as fast as they can go forward.
Stopped and restarted the engine in reverse?
How do the modern CVTs implement reverse.
Sutripta
Old 26th July 2013, 21:24   #17
Thanked: 9,026 Times
Sutripta
Ha, good one!
Reversible engines is more a marine engine type of solution.
Don't know how they do it on modern CVT's, but it must be very similar to the old method of a very simple gearing forward/reverse.
Jeroen
Jeroen is offline   Reply With Quote
Old 26th July 2013, 21:50   #18
Actually one of the bubble cars (Messerschmitt, IIRC) did use this method!
Sutripta
Old 26th July 2013, 22:37   #19
Sutripta
Quite right. Just found this link, stating that "if you were very brave you could go all four gears in reverse".
http://www.wild-bills.com/messerschm...hmittindex.htm
Cable Shift vs Direct Shift Gearboxes BlackPearl Technical Stuff 14 15th September 2013 13:35
Need advice:MM 550 BA 10 : 4x4 gear box direct Shift. swastikviji 4x4 Technical 53 21st July 2012 20:30
Seven speed DSG Gearbox breaks cover amit The International Automotive Scene 10 2nd June 2007 09:14
