Closed Thread
Old 28th August 2006, 00:41   #1
Thanked: 57 Times
Has anyone had a coolant going down to min level in the recovery tank (reservoir) in Optra 1.6 (1500 kms) with no symptom of overheating , obvious leakage signs under the car? I have had my Optra Royale (1450 kms) - for the last two months and I noticed today that the coolant level was almost at the min level. I have never seen temp gauge going into danger zone . Oil seems clean (no frothing). Havent seen any white Exhaust or unusual smell.
Any thoughts. I am taking it to the service center tomorrow... But was wondering if any had similar problems with Optra.
Ravich is offline
Old 29th August 2006, 08:28   #2
yes i am facing with the identical problem,but my car has clocked 8400 kms,will be speaking with Fort Point since it will take a bit for my car to clock 10,000 for the 3rd service
vandan is offline
Old 29th August 2006, 09:22   #3
Thanked: 103,427 Times
Hi Ravich
Please do NOT open multiple topics for the same query. You had already opened an identical query previously, and that can be found here
This thread is closed.
GTO is offline
Closed Thread
Symptoms of tyre puncture in tubeless tyres joy_swift Technical Stuff 60 28th April 2018 18:33
What are the symptoms of suspension problem / failure? Shan2nu Technical Stuff 36 10th June 2017 21:45
Coolant level low, but no symptoms? Ravich Technical Stuff 53 13th November 2016 18:14
Pathetic EcoSport delivery (Shreeji Ford): Low coolant levels, charging over MRP etc. ACM Indian Car Dealerships 30 30th September 2014 15:17
What are the symptoms of a dying clutch plate on a bike xxaarraa Motorbikes 9 19th December 2008 21:11
